Old Nov 28, 2012, 12:52 AM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Originally Posted by Twelvizm View Post
Hello all. I'm just checking in before I spend the weekend reading through this long thread and working on my F45. I absolutely love this thing and now have two. I'm a videographer and have been bitten by the aerial video bug. I've been working my way up to something capable of flying a gimble and a DSLR. So far I've found the f45 quite capable of flying a gopro with a little modification. This little heli has taken a beating as I learn more and more. Here's a video of my most expensive lesson to date.
http://vimeo.com/54289298
I'll be rebuilding the heli featured in that video and have ordered a second that'll use with another gopro. I'm planning on changing out the servo arm and upgrading to a 2200mah battery along with some heatsinks.
Well enough posting, I have lots of reading to attend to. Cheers.
Ouch! I nearly lost mine in a treatment plant due to wind. Do you have the stock motors?
rexless is offline Find More Posts by rexless
Old Nov 28, 2012, 01:55 AM
Zarrick is offline
Find More Posts by Zarrick
THE TRUTH IS OUT THERE
Zarrick's Avatar
Slovakia, Veľké Kapušany
Joined Nov 2012
Originally Posted by Vladicopter View Post
How about this as main motor for mjx f45
http://www.banggood.com/Wholesale-Em...r-p-50622.html
Nope, as a main motor You need at least a 3500KV-4000KV one. A 24mm. wide inrunner or a 23mm. outrunner
Zarrick is offline Find More Posts by Zarrick
Old Nov 28, 2012, 07:39 AM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
Some lovely aerial footage there. Hopefully it'll bring in enough to cover the 300 bucks for a new camera. Maybe a 808 #16 with wide angle lens would be worth considering in the meantime til you have more flying experience...? Then again, if you do this professionally it probably wouldn't give you the field of vision that most of us "mere mortals" content ourselves with
As a matter of curiosity, what 2200 mAh battery are you considering?
tiggertoo1962 is offline Find More Posts by tiggertoo1962
Old Nov 28, 2012, 07:47 AM
Twelvizm is offline
Find More Posts by Twelvizm
Joined Nov 2012
Still have the stock motors and I lucked out, the camera made it through the crash without damage. I've ordered this battery:
http://www.amazon.com/gp/product/B00...w_bottom_links
Seemed like a decent deal.
Twelvizm is offline Find More Posts by Twelvizm
Old Nov 28, 2012, 08:31 AM
Zarrick is offline
Zarrick's Avatar
Joined Nov 2012
How about a Turnigy Nano-tech 2200mAh 7,4v for $10 from HK? That seems better for me..
Old Nov 28, 2012, 09:39 AM
Twelvizm is offline
Joined Nov 2012
That does sound good. Got a link? What's HK?
Old Nov 28, 2012, 09:47 AM
Zarrick is offline
Zarrick's Avatar
Joined Nov 2012
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Old Nov 28, 2012, 10:39 AM
wellhead is offline
Find More Posts by wellhead
Joined Nov 2012
Battery charging time
Can you confirm the battery charge time.
wellhead is offline Find More Posts by wellhead
Old Nov 28, 2012, 11:03 AM
Scotsman in Germany
Joined Oct 2012
Just so you're aware, if you go the nano-tech route you'll have to mod the battery tray, but I don't think that'll be a problem for you. By all accounts (don't have a F45 myself yet) it's an easy mod and highly recommended. HK is Hong Kong. You'd have to wait a while for delivery, but if you're not in a hurry...
Old Nov 28, 2012, 12:22 PM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
HK is Hobby King which is in China just the same.
arrowshooter is offline Find More Posts by arrowshooter
Old Nov 28, 2012, 12:36 PM
Scotsman in Germany
Joined Oct 2012
Oops! Geography never WAS my strong point
Old Nov 28, 2012, 03:54 PM
Junior Basilio is offline
Find More Posts by Junior Basilio
Starting in R/C Helicopters
Brazil, MT, Juara
Joined Oct 2012
BThirsk, could make the change servo! I'm asking other arm, so I can make a change servo lift.
But a question, I modified my main motor to brushless, I will use the available connector on the PCB to connect the ESC that engine. However, if you change the tail motor to brushless, I have to use an ESC, correct? And where will I connect this ESC?
Junior Basilio is offline Find More Posts by Junior Basilio
Old Nov 28, 2012, 04:59 PM
Joined Aug 2012
Yes you have to use a separate ESC for the tail. You need to use a Brushed to Brushless signal converter of which you plug the current blue and white tail motor wires from the PCB then the 3 signal wires from the esc go to the other side.
Old Nov 28, 2012, 05:03 PM
Vladicopter is offline
Find More Posts by Vladicopter
Joined Nov 2012
Its depend how much current you put in to the battery.it like filling up a tub...
If battery capacity 2000mah and current you charging 500ma it will take 4 hrs if current 200mili ampere then 10 hours...etc
Vladicopter is offline Find More Posts by Vladicopter
Old Nov 28, 2012, 05:12 PM
Joined Nov 2012
Dear twelvizm.
Feel you pain it was scarry to watch your video!
Just interesting how long is your experience flying helicopters.
Honestly wind was not looking that strong i saw heli was roking few times but that was it...
Would it be possible your center of gravity was not set properly?or swashplate so you did not have enough movement of it to tilt the helicopter?
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
