Well , its been fun in here, but I'm gettin dizzy. I think I'll just enjoy my F45 as is and replace the occasional cheap motor. I,ll check in from time to time and see how you guys are making out with your 'improvements'.
Good bunch of guys in here, take care and have fun flying and moding. Later |
If I had not had issues with ESCs going into soft cutoff after about 4 minutes of hard flying, I probably would have been satisfied with the 2s battery setup. It had enough power and speed. Try the 2s setup and if it works for you, no need to go 3s. In my case, I had the same issue with several different ESCs, so I tried the 3s with an 800mah battery and the problem went away. I got almost 6 minutes with that little battery before it got weak but never had the soft shutdown occur.
Joined Jul 2012
I'm using the AEORC 20amp with the EH200 and I don't recall any sort of soft cut-off with it using the 2s 2000mah battery. It's been quite some time since I programmed it so perhaps I don't have this feature or it works differently? I do remember there being some sort of voltage protection option. Now that it's set up I haven't had to touch the programming since.
Great video - I see you like skimming the ground too eh? |
All that is modified on the servos is to move the link on the servo are one hole further out from the center. You can do this on the AIL arm easily, but you need a new arm for the ELV servo. On that one, you have to cut the arm off just after the new hole you are using to clear the frame. It's a very simple mod to do. Just make sure when pulling off the servo arms that the heli is powered off. You need to power it up before putting on the arms to center the servos. Put the arms on and power down before tightening the servo screws so as not to damaged the servos.
Camera port output.
Could someone do me a favour and measure the camera port outputs.
I believe one is ground and one is 5 volts. It is the signal that I am not sure of. What are the voltages and is it constant when the camera is enabled in the TX. I don't have the stock RX and am going to hook up to the 6 channel RX I am now using. ps. For anyone running a different RX with external gyro, let your gyro aclimatize before flying in cold weather. I flew mine the other day and went right from inside a warm house to -5C outside. Everything was great for about 4 minutes until the gryo went nuts and the heli became a top. I read up on the temperature effect and it was suggested at least 15 minutes was required for large temperature adjustments. |
Brazil, MT, Juara
Joined Oct 2012
Another thing, you asked for the measurements, I do not know if certain measures, but goes into the connector is approximately 3mm x 3mm -------------------------------------------------------------------------------- Here is the video of my first flight with my MJX F45. I know it's not to see it fly because it is the camera, but I wanted to share! =) Another thing, I realize that to turn to one side, if I'm not mistaken, contrary to helice back, he does not turn well! Is this normal?
Camera off Pin 1 negative Pin 2 positive voltage 4.95v Pin 1 with Pin 3 shows -0.04v Pin 2 positive Pin 3 negative voltage 5.00v Camera on Pin 1 negative Pin 2 positive voltage 1.68v Pin 1 with Pin 3 shows 3.31v Pin 2 positive Pin 3 negative voltage 5.00v I'm not sure if I'm doing this correctly or not, but that's what I get. |
http://www.rcgroups.com/forums/showp...3&postcount=10 |
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax | LMF5000 | Electric Heli Talk | 7 | Apr 26, 2011 08:33 AM |
| Question Upgrading from Co-Axial to FP Single Rotor | Judo JoNny | Electric Heli Talk | 57 | Sep 20, 2010 12:10 PM |
| Discussion Best FP single rotor 4 CH Heli? | helinewbie617 | Micro Helis | 76 | Oct 31, 2009 07:16 PM |
| For Sale will trade my orbiter coaxial for a fp or cp single rotor heli | micro heli | Aircraft - Electric - Helis (FS/W) | 3 | Sep 05, 2007 01:36 PM |
