Old Nov 18, 2012, 06:14 AM
fantomphish is offline
Find More Posts by fantomphish
gold coast
Joined Jan 2010
Well looks like of joined this family of F45 owners as I just picked one up in oz for $85, now to do the mods and get in the air..!
fantomphish is offline Find More Posts by fantomphish
Old Nov 18, 2012, 08:54 AM
Flyor is offline
Find More Posts by Flyor
The Netherlands, ZH, Rotterdam
Joined Aug 2012
Welcome Fantomphish, you won't regret it, its a fun heli
Regards
Flyor is offline Find More Posts by Flyor
Old Nov 18, 2012, 09:56 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Same here! Mine just showed up from Banggood.
baddb1 is online now Find More Posts by baddb1
Old Nov 18, 2012, 11:10 AM
gold coast
Joined Jan 2010
Sweet...
I looked at banggood but found a local seller hear in Oz, have motor heat sinks and lipo's ready to go. Still weighing up the rotor replacement and I'm not overly concerned about brushless as I'm slowly building up a 450 CP anyway..
Just have to sort out a cam for it..
Old Nov 18, 2012, 01:24 PM
hawaiichopper is offline
Find More Posts by hawaiichopper
United States, OR, Portland
Joined Oct 2012
OldOz and Flyor, thanks much for the description and schematic. Those help so much to sort out the connections needed. I was under the impression that a BL main motor would require the brushed to brushless converter, but it appears not. The converter is only needed for a BL tail motor then? OldOz, your brain is working just fine - I bet my "old brain" is older than yours! Flyor, I spent some time in Rotterdam many years ago as my mother-in-law is (was - she passed away) Dutch. Really nice place and people. One of these days I'll get to Australia also - Hawaii is part way there! Now for a parts order.......and wait.
hawaiichopper is offline Find More Posts by hawaiichopper
Old Nov 18, 2012, 01:44 PM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
Looking to order paddles for my V911 from miracle-mart.com and thought I'd have a look at batteries for the F45 (which I don't have yet) while I'm in there. Just wondering if anyone has any experience with these...
http://www.miracle-mart.com/store/in...oducts_id=6798
... and whether there's any reason they couldn't be used on the F45. I'm clueless on things like discharge rates and stuff, but where the nano-tech 2000mAh are 2S1P 20~40C, these are 2S (don't know what the "1P" means) and 40C discharge rate.
Physically they are about 17mm longer than the nano-tech, so I don't know if there is enough room to fit them when the tabs are removed, even if they could otherwise be used. Not sure about weights either, as this one is 145g, but the nano-tech is either "98g (including wire, plug & case)" or 154g if you believe the figures on the Product Config Table.
Any replies which further my slowly-accumulated knowledge would be appreciated.
Tigg
tiggertoo1962 is offline Find More Posts by tiggertoo1962
Old Nov 18, 2012, 02:24 PM
Joined Oct 2012
Tigg
While I have not used the above brand, I have a Sky Lipo of nearly the same dimensions. It required the removal of the rear battery holder stops and the front battery tab to make a long flat surface. Also had to relocate (or lengthen) the red and black wires from the PCB as there was not enough room to slide the battery past the wires. The battery overhangs the front of the battery holder by about 15mm which keeps the center of gravity close to neutral. I also use the Nano-tech 2000mah and can't tell any difference between the two. Batteries are held in place by a strap of velcro. Got the Sky lipo because it takes so long to get items from Hobby King, but the Nano-tech didn't require as many mods, even though they are minor.
Old Nov 18, 2012, 10:57 PM
jeffteeh is offline
Find More Posts by jeffteeh
Joined Dec 2009
Lost binding from time to time
Originally Posted by jeffteeh View Post
I reported all my tests back to Banggood. They decided to send me a pair of
new Rx and Tx to help me to fix it. This may take several weeks.
I will report back here of the results. Appreciated all advices I got here from your
folks!
Regards
After around 1 month waiting, I received spare parts from Banggood.
When I bound my heli with the new Tx, everything goes wonderful.
So it's clear now that the original Tx was lemon.
I have flied heli with this new Tx for 5 or 6 times, up to 10 meters high
50 meters far, no problem at all.
My experience Banggood is REALLY wonderful. They quickly responded
to all my inquiry and help to solve the problem. Except shipping takes longer
time, otherwise, they are as good as e-flite.
jeffteeh is offline Find More Posts by jeffteeh
Old Nov 18, 2012, 11:07 PM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Congrats JeffTeeh! I've had mine out around 150m away and ~100m high many times and other than straining to see what direction I'm facing or fighting wind etc. I've had no problems with signal loss. Just be careful of wind... I nearly lost mine in to an industrial compound when a wind came up. Since I've upgraded to brushless main motor, 3s battery and reduced pitch blades I find I can handle 20km winds with no problem. I even was able to scoot in and land on a man hole cover easily a couple of days ago.
rexless is offline Find More Posts by rexless
Old Nov 19, 2012, 12:55 AM
future88 is offline
Find More Posts by future88
Joined Oct 2012
hic hic
everyone had forgotten my question, I need help from you
can replace motor brushless equivalent EH 200 ?
future88 is offline Find More Posts by future88
Old Nov 19, 2012, 01:14 AM
rexless is offline
rexless's Avatar
Canada, BC
Joined Apr 2012
Originally Posted by future88 View Post
hic hic
I am only familiar with the EH200 myself... Is there a reason you don't want this one?
Old Nov 19, 2012, 02:07 AM
future88 is offline
Joined Oct 2012
the reason I want to replace motor Eh 200 is because I have a lot of motor wing aircraft, and some motor helicopters for size 450
I want to take advantage of what I have
who have upgraded the main motor for F45 with another motor EH200?
Old Nov 19, 2012, 03:29 AM
Whizgig is offline
Find More Posts by Whizgig
Eugene
Whizgig's Avatar
Australia, VIC, Delacombe
Joined Oct 2006
StormForce ( Mick ) will be sadly missed
My Best Mate Mick.
For all of you who new Mick and followed this thread and many others that new him from other threads that he had posted in.
I got a phone call today from his partner who informed me about my best mate Mick.
It is with my deepesed regret and sadness to have to infom you all that on the 26th of July Mick passed away very suddenly at night with a masive heart attack.
He will be sadly missed by me as he was a dear freind and mate that I spoke, joked and worked out heli faults ect everyday.
Rest in peace Mate.
Eugene.
Whizgig is offline Find More Posts by Whizgig
Old Nov 19, 2012, 03:42 AM
Scotsman in Germany
Joined Oct 2012
Originally Posted by Whizgig View Post
My Best Mate Mick.
He will be sadly missed buy me as he was a dear freind and mate that I spoke, joked and worked out heli faults ect everyday.
Rest in peace Mate.
Eugene.
sorry to hear it Eugene, my condolences
Old Nov 19, 2012, 06:01 AM
S4ntai is offline
Find More Posts by S4ntai
Sloooooow Flyer
S4ntai's Avatar
Australia, NSW, Glenfield
Joined Aug 2012
Front servo. Vs rear servo
Hello. Just curious any difference between front and rear servo? Cause banggood selling at difference price for front vs rear. Advice please
S4ntai is offline Find More Posts by S4ntai
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
