couple of quick questions, maybe with obvious answers but since I've not had an F45 in my hands yet I have to ask. I've read that for the above battery to fit, you need to modify (remove) the tabs on the battery holder. Once they have been removed, can you still use the stock battery? When I get my F45 I don't want to be limited to 2 flights a day, but also don't want to have a stock battery which I can't use ![]() I've also been looking at the 2100mAh which measures 80 x 44 x 16mm rather than the 2000mAh 90 x 42x 16mm (10mm shorter but 2mm wider). Is this also a viable option and, if so, do the battery tabs also have to be removed to fit it? http://www.hobbyking.com/hobbyking/s...tter_Pack.html Cheers Tigg |
Joined Oct 2012
Unbalanced cells in stock battery?
Hi,
There is a 0.1 V difference between the two cells as indicated by the lipo voltage tester and buzzer. Is this a problem or within limits? I still get about 6-8 minutes flying time (using stock motors). My Accucell 6 is still not here, but I do have a Skyartec balance charger. Previously I was just using the supplied wall charger unit, could that have damaged the battery, or was a cell just not matched when the battery was manufactured? How do I revive this battery, if its even possible? |
United States, HI, Hilo
Joined Oct 2012
7shaped dog bones
I have one F45 with the 7 shaped dog bone connectors and one with the straight ones. The straight bones show a slight wear spot where they touch the loops while the 7 shaped ones do not. The geometry of the dog bone attachment points is slightly different for the 7 shaped bones versus the straight bones. The placement of the blade mounting mechanism on the main shaft is also slightly different for each bird. Makes me wonder if the loops break when parts from the two configurations are mixed, but the breakage may also just occur due to the pressure exerted by the straight bones. Performance-wise, I see no difference in the flights of either bird.
Joined Oct 2012
In the meantime I have two more questions. Can I use the stock charger to charge the Turnigy batteries or do I need a separate charger? ...and as far as I remember reading, the Turnigy and the stock battery have different connectors. @ hawaiichopper Did you buy/make some kind of adaptor? If you made one, do you have it down somewhere what's needed and how you did it? If I do wait till spring to buy the heli, at least I've got plenty of time to practice my soldering skills ![]() Cheers Tigg |
Joined Oct 2012
Before I went to 11.1v I used the 2000mah Nanotech battery and I loved it. I had to remove the stop tabs at the back and add twist-ties or velcro to hold it nicely in place. I liked that I could shift weight slightly forward for a bit more forward flight ability in a small wind. Now I'm using a 1000mah 11.1v 3s for the EH200 BL motor and an old ~500mah 2s (from my defective S022 heli) for the PCB/Tail. I've mounted the small 2s right under the main motor/gear. I have a pretty good balance (I think - I haven't learned how to test that yet) as it flies quite nicely in this setup.
Power wise - I get a solid 10m of flight with this configuration. I must have lost track of time yesterday though. I didn't time the flight and was barely able to clear the fence and land in my yard! I checked the voltage on the 2s after that and noticed it was sitting at about half it's usable capacity. I guess a 1300-1400mah 3s would be a better balance if I wanted to keep going for longer flights. For me, I don't get many chances to fly and my time is very limited so 10m is usually all I can afford. I don't bother keeping extra batteries at this point. My only desire is to have only a single 3s power everything though. I dislike charging 2 different batteries. |
I'm with you on the one battery. It would be nice, but I haven't figured out how to do that yet. I had mine up in the breeze yesterday for the first time since the brushless tail install and the new flybar. The tail held like a charm and I have it de-tuned. The cyclic is still almost too much for me. It is like flying my HK250. I need a lot of practice or more tuning to soften the response. |
That 2100mAh pack you linked is NOT a LiPo!! It is actually a LiFePo4 which is 6.6v not 7.4v. Also the chemical makeup is totally different and you would need a charger capable of charging LiFePo4 batteries. I seriously recommend the 2000mAh Nanotech Receiver pack as this will be the easiest solution. The 2100mAh pack you linked is designed for Tx's which usually run off 4 AA batteries (6v). This is NOT a flight pack at all. |
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax | LMF5000 | Electric Heli Talk | 7 | Apr 26, 2011 08:33 AM |
| Question Upgrading from Co-Axial to FP Single Rotor | Judo JoNny | Electric Heli Talk | 57 | Sep 20, 2010 12:10 PM |
| Discussion Best FP single rotor 4 CH Heli? | helinewbie617 | Micro Helis | 76 | Oct 31, 2009 07:16 PM |
| For Sale will trade my orbiter coaxial for a fp or cp single rotor heli | micro heli | Aircraft - Electric - Helis (FS/W) | 3 | Sep 05, 2007 01:36 PM |
