As you can see in the picture I edited of yours, the pink line shows where the Blade holder should ALWAYS line up with and NEVER be able to shift from that angle. If the feathering shaft is completely missing, what happens when you add throttle, is the lift from the blades lifts the whole assembly, causing the swash to lift with it. Find the feathering shaft (or make a new one from Alu or steel rod) and you should be back in business
Australia, QLD, Brisbane
Joined Aug 2012
Noname -
To make it a bit clearer, here's a pic of a (not F45) blade holder. Yours should have a similar steel pin through the centerline to keep the blade assembly at 90 deg to the shaft, as BThirsk picked out - and I missed! - from your stills. Reinstall/replace/repair, and you should be gtg . As Slothy says, or a paperclip might work if you've lost the original.BThirsk - did you HAVE to keep us all guessing that long? (!) |
The Netherlands, ZH, Rotterdam
Joined Aug 2012
But one thing I noticed is that the rotor head is not level, you might want to check if the pin in the main shaft is ok, this angle suggest that there is someting wrong there. I made an image roughly in the same position of my own working F45, notice the red lines. Regards Edit: Took a while to examine your images and prepare an image of my own, but after posting I see that others came to the same conclusion :-) |
On my original with the 7 shaped links, with everything straight at bind up position, I had at least 3/8 inch or about 10mm from the eye to the hoop. The eye on mine would never touch the hoop even on full cyclic. Most of yours are close to touching with the swash plate level. when I converted my flybar to paddles, I used all new parts in the head with the straight links. My clearance was reduced when I did this. With full cyclic, the eye would contact the hoop and actually push on it causing it to bend slightly. Because I now do not require near as much travel in the swash and have the servo travel set to 80 % , I am not having this contact issue. I wonder if that is the reason why some have had so much issue with the hoops breaking and others of us have never broken a hoop. Or are these hoop breaks cause by crashing? |
BTW, I did file out for the motor vent holes and have double hood scoops on the canopy. |
Very interesting failure
Today, I had a weird issue, I want to share it with you in case it happens on your helicopter.
While I was flying my EH200-modified F45 over a freshly harvested corn field, the rotor suddenly simply stopped to rotate and the heli fell from about 15 meters (45 feet) like a stone. Not a very pleasant vision, believe me... ![]() After the crash the heli seemed still to be bound with the transmitter, the white led was on. Damaged parts : - bent flybar, but okay it's not the first (neither the last) time, I bent it straight. - slightly bent tail boom, I straightened it with no problems. - a crack in the canopy beneath the skids (the F45 felt on the nose) - biggest damage : a broken gyro on the RX board. I tried to understand what happened. The transmitter worked fine, batteries were charged. I tried to bind to the helicopter to the TX, all was OK, the white led became steady as allways, even whith the broken gyro. But each time I spooled up the heli, after a few seconds the main rotor stopped and the white led began to blink slowly. The tail motor didn't run, I tought this was because the gyro was broken. And each time I put the throttle to 0 on the Tx the white led became steady again, and I could spool up the rotor, which stopped again with blinking led, and so on... First I thought the ESC had a problem (short-circuit ?). Then while playing with the RX board, I noticed that each time I tried to spool up, a surface mounted electronic component next to the tail motor connector became hot. Aha. ![]() I disconnected the tail motor to see what happens, and now the helicopter spooled up whithout problem and the main rotor worked normally. So the culprit was the tail motor wich had a short. I think the RX board has a protection circuit wich detects an overcurrent in the motor and the "switches off" with the white led blinking. The motor had just about 30 flights ![]() I replaced the RX board, the tail motor, and now it flies again. ![]() Roland |
Joined Sep 2012
A little help regarding how to replace the flybar...
What should i do to replace it ? There is a pin but how do i remove it ? Edit: Yes... i crashed again.. not proud of it... but i solved my earlier problem by increasing the throttle to 70 % in stead of 40 %... There was simply not enough power... When ever i want it to move against the wind, i'll keep giving a little throttle and let of again.. like when you spin the engine in your car.. this way it will not go higher and you will give the bird momentum... My 2 cents: This bird is all about momentum..when you give it a cyclic command and it does not move.. then give a little throttle and let of.. just for half a second.. and keep doing so until you build momentum... and the bird shall go where you want it to move without gaining altitude.. |
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax | LMF5000 | Electric Heli Talk | 7 | Apr 26, 2011 08:33 AM |
| Question Upgrading from Co-Axial to FP Single Rotor | Judo JoNny | Electric Heli Talk | 57 | Sep 20, 2010 12:10 PM |
| Discussion Best FP single rotor 4 CH Heli? | helinewbie617 | Micro Helis | 76 | Oct 31, 2009 07:16 PM |
| For Sale will trade my orbiter coaxial for a fp or cp single rotor heli | micro heli | Aircraft - Electric - Helis (FS/W) | 3 | Sep 05, 2007 01:36 PM |
