Old Oct 13, 2012, 06:57 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Originally Posted by Tumppi T View Post
I agree you 100%. That's the way it should be ...but...
today i made a test:
- I have two PCB:s. One with original FET and one with bigger FET (CEP73A3G).
- I disconnected first the (+) and then the(-) wire from the PCB to signal converter. In both cases the converter didn't say anything
So....the only way i got this combination function was with the bigger FET and both signal wires connected from the PCB to converter....weard
Right now im struggling with the efficiency of the BL tail motor. It flyes smooth and stable but when i push full throttle .... the Turnigy 1811 kV2000 cannot keep the tail straight. If i put bigger tailpropel the tail kind of waves.....
....next step is to try 9T pinion to the main motor and maybe new BL tailmotor (Turnigy 1811) with more kV:s.
This is crazy....but i just love to do these modifications and solve problems
No those are not the wires I am referring to. You need the + an the - from the PCB to be hooked to the signal converter. It is the + wire coming from the ESC to the signal converter in the 3 wire servo plug the needs to be removed from the plug and taped off. The 2 wires coming from the PCB that originally power the tail motor supply the variable voltage that the signal converter changes to a signal the ESC can use so you need both wires hooked up.
The power wire coming from the ESC supplies 5 volts that would normally be used to power a receiver and servos. That is the wire that should not be required. It is the red wire on the center pin.
BThirsk is offline Find More Posts by BThirsk
Old Oct 13, 2012, 09:17 AM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
I think someone on here posted that they thought it might help to add resistance to the original tail circuit. Perhaps the brushless converter is too free the power?
I'm not sure how that all works and don't have the pieces to test it.
rexless is offline Find More Posts by rexless
Old Oct 13, 2012, 03:49 PM
Lentar is offline
Find More Posts by Lentar
Joined Oct 2012
Originally Posted by arrowshooter View Post
Today I received my Park 370 4100kv inrunner brushless motor along with a Turnigy Basic 25A speed control.
Where exactly did you get this from?
Lentar is offline Find More Posts by Lentar
Old Oct 13, 2012, 06:17 PM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
Ebay USA
arrowshooter is offline Find More Posts by arrowshooter
Old Oct 14, 2012, 01:09 AM
Lentar is offline
Joined Oct 2012
Anyone have any thoughts about this instead of the EH200 (not available) or Park 370 (expensive):
http://www.hobbypartz.com/elite-370-...ess-motor.html
Old Oct 14, 2012, 01:18 AM
Tumppi T is offline
Find More Posts by Tumppi T
Registered Crasher
Tumppi T's Avatar
Finland, Tuusula
Joined Mar 2012
I tryed that today....the tail ESC didn't function without that red wire from converter to ESC
Tumppi T is offline Find More Posts by Tumppi T
Latest blog entry: VCTRC 450 Pro V2 (T-Rex clone)
Old Oct 14, 2012, 02:22 AM
slothy89 is offline
Find More Posts by slothy89
Head in the clouds
slothy89's Avatar
Australia, VIC, Sebastopol
Joined Apr 2012
looks like a good contender
slothy89 is offline Find More Posts by slothy89
Old Oct 14, 2012, 02:31 AM
Lentar is offline
Joined Oct 2012
Modified Old Oz Rotor Hoop reinforcement
Its modified since I've actually encased the paper clip in epoxy. I had a clean break at the edge of one of the hoops (see first pict.) which I sealed with cyanoacrylate. Then I used a large paper clip, using the handle of a paintbrush to give the two ends the correct bend. Finally applied 5 minute metal filler epoxy to the side and top and bottom edges, such that the clip is no longer visible. I don't know if this is going to be any stronger than the original Old Oz version. No crash after this to test, but heli did flip to the side while the blades were rotating (but power off) during a landing, and hoops intact.
Old Oct 14, 2012, 03:40 AM
mumilove is offline
Find More Posts by mumilove
Joined Sep 2012
Servos
Are the servos interchangeable ?
The front servo cost 17$ and the rear cost 7$.. but they look exactly the same to me!
Can I buy two rear servos and be done with ?
mumilove is offline Find More Posts by mumilove
Old Oct 14, 2012, 04:24 AM
slothy89 is offline
Head in the clouds
slothy89's Avatar
Joined Apr 2012
Yes they are, just get two rear one's. I checked and the image shows a full length servo horn so you should be ok. If not claim a refund on the grounds they inaccurately described the item
Old Oct 14, 2012, 07:34 AM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Well, you guys are doing better than me. I can't get it to work at all.
I tried with both the red wire hooked up and not hooked up. The ESC arms properly, but never supplies power to the brushless motor when moving the throttle and rudder.
I checked the ESC/motor using my servo tester and they function fine.
I checked the PCB tail plug and it has power when the throttle/rudder stick is moved. The blue with is positive and white negative and that is how I have hooked the the converter. Either I am missing something, or my signal convertr is a dud.
Old Oct 14, 2012, 07:53 AM
freezywilly is offline
Find More Posts by freezywilly
Joined Jan 2012
The question was asked about this: http://www.hobbypartz.com/elite-370-...ess-motor.html
I bought several of them and put one on one of my f45s. The motor ran so hot that I could not touch it. The EH200 on my other f45 is so much better.
I did not get one of the park motors so I can't give a comparison there.
My feeling is to stay away from those hobbypartz motors.
freezywilly is offline Find More Posts by freezywilly
Old Oct 14, 2012, 09:51 AM
Lentar is offline
Joined Oct 2012
Does anyone know if this can be substituted for the stock motor and pinion:
http://www.horizonhobby.com/products...-bcp-EFLH1110C
Old Oct 14, 2012, 10:15 AM
mumilove is offline
Joined Sep 2012
Perfect.. just ordered one to get hold on a servo arm (and have the servo as backup.. live in Denmark and there is 3 weeks delay on shipping - better be safe)
I almost bought a Walkera master cp and a mini cp today.
I flipped the coin.. three times negative... clean sign not to buy them... think the wife will kill me or something :0)
Old Oct 14, 2012, 10:21 AM
mumilove is offline
Joined Sep 2012
BTW... i crashed again... last night... 15-20 meters..
Dusted it off and went flying again (only the tail support roads were bent)..
Man, this machine is almost indestructible
The same problem i always have... it flies away from me.. i give 100 % reverse cyclic... nothing... i give very, very little throttle.. it moves back a little but gains more hight... i have the throttle on 45 %.. rudder on 60 % ... the rest on 100%...
I think i just need to use the rudder and fly nose in to get it back... i have no problem with forward and left cyclic... only reverse and right... hmm
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
