Old Oct 11, 2012, 03:34 AM
Stoersender is offline
Find More Posts by Stoersender
Germany, BW, Göppingen
Joined Aug 2012
Originally Posted by Tumppi T View Post
Hi,
It's the smaller one close to the tail-motor plug (installed horisontal). I don't understand either why it doesn't work with the original FET, but i fried accidentaly the original FET......replaced it with the DH9104:s FET...and now its running
The FET is: CEP73A3G
It was very easy to install. Just cut the original FET:s connectors and then solder the FET away (It's soldered to the board from it's back). Solder 2 cm wires to the original FETs connection points (2) and one 2cm wire to the area where the original FET was fixed to the board. Solder two wires to the new FET in same order as the original. The third wire goes to the center connector. Then put some sticky tape behind the new FET and attach it in some good place. I put mine just onto the main circuit
Is it the first or the second one in the photo?
Just now I unsoldered number 1, but there was no third connection
And the left little connector came off... now nothing is working anymore, even when I soldered everything back together.... umpffff... I know why I don't like that complicated electronic stuff
so for now I think I'll need a new PCB board... or how can I attach the left connector to the board again?
Stoersender is offline Find More Posts by Stoersender
Old Oct 11, 2012, 03:58 AM
slothy89 is offline
Find More Posts by slothy89
Head in the clouds
slothy89's Avatar
Australia, VIC, Sebastopol
Joined Apr 2012
I'm not sure what FET they are talking about, but I have a question... What do you have connected to the LED socket on the board? those wires don't look like the LED wires
slothy89 is offline Find More Posts by slothy89
Old Oct 11, 2012, 04:14 AM
Joined Aug 2012
I've modded the normal searchlight cause I didn't like the white LED mounted to the canopy.
I've put two LEDs to the side, one is red and one blue.
They're signaling the binding status and are working as positioning lights when it's darker outside
Here you can read more about how I did it:
F45 - modded "searchlight" mod
Old Oct 11, 2012, 04:42 AM
slothy89 is offline
Head in the clouds
slothy89's Avatar
Joined Apr 2012
Oh yes, I remember reading that now. Cool Just making sure you weren't trying to use that to power the Tail ESC or something silly :P
Old Oct 11, 2012, 04:57 AM
Joined Aug 2012
nono never^^
for now I'm grounded because my pcb board is done... I tried to unsolder the FET and the left contact came off. Now I'm unable to solder it back together...
And the tail motor doesn't work because of that...
I hate myself for trying such a stupid thing
Old Oct 11, 2012, 06:00 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Give me a minute and I'll test it for you
if it's not true I'll just have to resolder the cut wire...
edit:
so I just tested your theory, but nothing happend.
The ESC just beeped the "no signal" beep.
I tested both wires, red and black.
Haven't had to cut anything... I remembered that the pins can be pushed out of the plug
now I'm soldering a new FET to the board...
No, I did not expect that would fix your problem. I am just wondering if that is what created it in the first place. If the ESC is supplying power to the converter via the BEC circuit, is the power being fed back to the PCB causing an overload on the FET and burning it out.
I saw a write up on a blade conversion and all that fellow did was use the signal wire to the ESC. He said the only thing that did not happen is the LEDs on the converter did not light up, but otherwise it functioned fine. He specifically stated, DO NO LEAVE THE POWER HOOKED UP. He removed both the red and black pins, but never stated the reason.
BThirsk is offline Find More Posts by BThirsk
Old Oct 11, 2012, 06:11 AM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Originally Posted by rexless View Post
Well after over 30 days waiting for the slow boat from China to arrive, my 1000mah 3s battery arrived today. So, I soldered an adapter together and hooked it up to my the ESC for my EH200 - mounted the Walkera #4 blades and did some tests. First test - spinning up to about 75% throttle was fine. The power was amazing but something strange happened after 75% - the blades lost their strength and started to twist and flap resulting in a massive drop in thrust. So I figured with me sitting there holding down the helicopter sure but what about outside flying? It's dark so I took it out front of my house and flew around a bit over the pavement. Again, things seemed pretty smooth up to about 75% throttle. When I climbed much past that (had to do it quick due to a small space) the blades had destabilized and the F45 came flying at my head. I ducked and it smashed nicely into a rock wall. The blades shattered and the flybar was bent a little but otherwise no damage. Since the blades couldn't handle the motor and the flybar bent back easily I would say it was no big deal but a great lesson. Mostly it was hilarious!
So now I'll have to fly stock blades until I try the ones Brent suggested in the first place.
While you're ordering stuff, oldoz suggested a 9 tooth pinion, blade part number BLH1609. I would get one of those as well. It will slow things down just a little and will give you more spread and feel on the throttle. I am going to pick one up as well.
Be carefully with the stock blades. They will flutter as well at high speed.
Old Oct 11, 2012, 08:43 AM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
I think this is good advice. I shall look for a 9 tooth pinion, thanks Brent!
rexless is offline Find More Posts by rexless
Old Oct 11, 2012, 09:41 AM
Tumppi T is offline
Find More Posts by Tumppi T
Registered Crasher
Tumppi T's Avatar
Finland, Tuusula
Joined Mar 2012
Oh damn Number 1 is the right one.
Ok.....now i think i understand what happened to you. When you were removing the FET, the "silver" area was cut away. You can solder the third wire behind the PCB (white wire in my photos .... and it goes to the mid connector of the new FET).
Tumppi T is offline Find More Posts by Tumppi T
Old Oct 11, 2012, 10:30 AM
Joined Aug 2012
ok I figured something like that. I just wasn't sure if I got rid of the right one
I put the soldering iron a little bit to long on the connector and it peeled off
But thanks for the pics they help a lot
maybe I'm able to get working again by tomorrow...
Old Oct 11, 2012, 11:16 AM
Lentar is offline
Find More Posts by Lentar
Joined Oct 2012
HELP: Is my upper plastic head broken?
Is the linear cut which I've circled normal or has it been broken? (Was going to apply CAL to it, but it seems like it may have been engineered)
Please help!
Lentar is offline Find More Posts by Lentar
Old Oct 11, 2012, 11:49 AM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
Originally Posted by BThirsk View Post
It might work just fine.
Do we know what the rpm is for the stock brushed tail motor is?
arrowshooter is offline Find More Posts by arrowshooter
Old Oct 11, 2012, 11:55 AM
Rollmops67 is online now
Find More Posts by Rollmops67
Eternal beginner
Rollmops67's Avatar
France, Alsace, Strasbourg
Joined Jun 2012
Please help!
The cut is not normal, next step will be a broken loop.
And when a loop breakes, the heli becomes barely controlable.
So if I where you, I wouldn't fly with this loop
This is a common issue here (i had it 4 times) but some people have solutions.
For me I tried Oldoz's one :
http://www.rcgroups.com/forums/showp...postcount=3115
It works perfectly, no broken loop since i did the mod !
Look some pages back, others have also similar solutions.
Nice flights and smooth landings !
Roland
Rollmops67 is online now Find More Posts by Rollmops67
Old Oct 11, 2012, 12:10 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Not for sure. I will try to get a good reading tonight. I was having issues with my optical tach. I'll try again to get an exact reading.
Old Oct 11, 2012, 02:27 PM
Joined Aug 2012
Thanks. Kinda like an idea where it is at compared to other styles of motors.
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
