Old Oct 06, 2012, 12:10 PM
RCCrashTestDummy is offline
Find More Posts by RCCrashTestDummy
Finding Creative Ways To Crash
RCCrashTestDummy's Avatar
Joined Jun 2012
rexless,
Which video editor do you use for your #16?
-Pat
Originally Posted by rexless View Post
I almost bought the DH9117 too. At the last minute I opted not to and I've been very happy about that!
I use the 808 #16 camera for 720p video. All the on-board flying footage in this video is from this camera.
http://youtu.be/viEJG0MM0hg
RCCrashTestDummy is offline Find More Posts by RCCrashTestDummy
Old Oct 06, 2012, 09:19 PM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Originally Posted by RCCrashTestDummy View Post
rexless,
-Pat
I'm using adobe premiere elements only because I haven't found anything else I like.
rexless is offline Find More Posts by rexless
Old Oct 06, 2012, 09:27 PM
jeffteeh is offline
Find More Posts by jeffteeh
Joined Dec 2009
Lost binding from time to time
Originally Posted by OldOz View Post
Jeffteeh -
Frankly, I think this is bloody awful advice. If the batteries were really the LiPo MJX claims, you'd stand a good chance of destroying them this way imo. As it is, you can't have done them much good.
However, it's extremely difficult to think of a sensible plan of attack. The problem could be in the Tx or Rx: if the mode (slide) switches are OK, I'd bet on the Rx PCB in the heli. My solution would be to simply buy another heli, which would enable you to make a fast diagnosis - however, if you're on a tight budget this will be impractical.
A replacement Rx would be around $20, express postage would be cheap, and would be handy to have anyway. If you live in Aust, I could send you a spare TX.
TL, DR? - my money's on the RX PCB.
Good Luck, and maybe someone else can shed more light on this. Haven't heard of this exact problem in 237 pages(!)
- John
Edit: have you actually checked the battery voltage after a cutout? - if it were faulty, or had a high internal resistance it could cause the problem - that part of BGs advice I do agree with.....but haven't had a faulty one yet.
Thanks John for your kindly offer!
I didn't really blindly rotate the heli till LVC ( I don't know whether F45 has LVC
or not). Actually, I used the multimeter to measure the battery every 2 or 3 mins.
Anyway, the binding kept lost from time to time. So I will let the battery only go
down to around 7.0V, and considered it as empty and recharged it till green LED
on charger shown. The voltage shows as 8.44V when it's fully charged. This
process (rotating) took around 12 to 15 mins. Hence I thought that battery is in
good shape, otherwise, it can not support the rotating so long.
I reported all my tests back to Banggood. They decided to send me a pair of
new Rx and Tx to help me to fix it. This may take several weeks.
I will report back here of the results. Appreciated all advices I got here from your
folks!
Regards
jeffteeh is offline Find More Posts by jeffteeh
Old Oct 06, 2012, 11:13 PM
OldOz is offline
Find More Posts by OldOz
John
Australia, QLD, Brisbane
Joined Aug 2012
Jeffteeh
Glad to hear you didn't go the whole hog with the discharge!
Though the Li Ion batteries are more tolerant to extremes. Actually accidentally discharged one to 3v total (not per cell) - after recharge, worked fine.
A shame you have to wait for BG's spares to arrive - but (so far) I've found them very helpful when things go wrong. Unfortunately, really slow too: but all part of the rich tapestry of buying from China.
One or the other will fix your heli, for sure - wait to hear how it goes.
Cheers
- John
PS - The LVC to loss of bind is a bit over 5v (benchtest PSU) if of interest to anyone.
OldOz is offline Find More Posts by OldOz
Old Oct 07, 2012, 12:15 AM
slothy89 is offline
Find More Posts by slothy89
Head in the clouds
slothy89's Avatar
Australia, VIC, Sebastopol
Joined Apr 2012
My guess is the core of the PCB electronics run at 5v, so when the battery gets too close to 5v the voltage converter can no longer supply the steady 5v.
slothy89 is offline Find More Posts by slothy89
Old Oct 07, 2012, 01:51 AM
Tumppi T is offline
Find More Posts by Tumppi T
Registered Crasher
Tumppi T's Avatar
Finland, Tuusula
Joined Mar 2012
Originally Posted by Stoersender View Post
It's done
Brushless main motor mod:
F45 - goes brushless. Read more
Completed it yesterday... it works like a charm
Brushless tail parts are ready to be used:
Hi guys,
I bought same BL tail modification parts. I was not able to make them function well, until i changed the tail FET from the PCB. The power of the BL tail motor was cut off when i pushed more than 50% power
I took little bit bigger FET from my DH9104:s board and now it works perfect....and it was pretty easy to change. I didn't fix the new FET straight to board....its behind 2cm wires.
Tumppi T is offline Find More Posts by Tumppi T
Old Oct 07, 2012, 04:19 AM
OldOz is offline
John
Joined Aug 2012
Slothy -
That's it, exactly
Tumppi T -
Congratulations! - along with Hinnerk, another (but different) path is beaten to the fully BL F45.
I've ordered most of the bits, but would appreciate a link to the prop if you have it handy. Good tip on the FET, found the same problem with the bench mockup. Using a STP16NE06 for tests - seems good so far.
- john
Old Oct 07, 2012, 04:29 AM
Stoersender is offline
Find More Posts by Stoersender
Germany, BW, Göppingen
Joined Aug 2012
Slothy -
That's it, exactly
Tumppi T -
- john
That's the prop:
http://www.ebay.de/itm/320957119364?...84.m1439.l2649
Stoersender is offline Find More Posts by Stoersender
Old Oct 07, 2012, 04:32 AM
OldOz is offline
John
Joined Aug 2012
Ordering! - ty
Old Oct 07, 2012, 04:36 AM
Joined Aug 2012
Ordering! - ty
Since I'm not such a big electronics geek, what are the specs a replacement mosfet needs?
Old Oct 07, 2012, 04:47 AM
OldOz is offline
John
Joined Aug 2012
For my mockup, 60V N-chan 16A (STP16NE06), but this hasn't been tested IRL yet. At a pinch, I'd think you could probably reuse the mosfet driving the old (brushed) motor too.
Also -
A 'green' use for the old horizontal stab support tubes - go really well as landing skids, especially with coathanger wire shoved up the middle. Haven't broken yet!
Old Oct 07, 2012, 05:30 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
For my mockup, 60V N-chan 16A, but this hasn't been tested IRL yet. At a pinch, I'd think you could probably reuse the mosfet driving the old (brushed) motor too.
Also -
I am also confused. I though you would only be using the original tail motor output as the signal through the signal converter and supplying the power to the tail motor from the ESC. Why would this cause the fet to cutout?
BThirsk is offline Find More Posts by BThirsk
Old Oct 07, 2012, 05:42 AM
OldOz is offline
John
Joined Aug 2012
Frankly, I don't know yet. Only got the bench mockup going yesterday, with a dummy load in place of the prop. Also, am not using the same converter as Tumppi T: bit of a homebrew.
But I did run into the same problem, which the higher power mosfet cured similarly.
I'll revisit the project when my 'proper' bits get here
- John
Old Oct 07, 2012, 05:51 AM
OldOz is offline
John
Joined Aug 2012
The bits I've ordered -
http://www.hobbyking.com/hobbyking/s...or_3800kv.html
http://helidirect.com/xtreme-brushed...er-p-19238.hdx
And from Tumppi T
Hope these do the trick.
Edit: I'll recheck the old tail rotor mosfet: perhaps I just damaged it when wiring/ experimenting with the PCA. Was tired!
Old Oct 07, 2012, 05:56 AM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
I have a 1500kv and a 2000kv to try. I have the same converter.
I was going to modify the stock prop just to see if that will work.
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
