Germany, BW, Göppingen
Joined Aug 2012
I didn't buy the 18A ESC, but the 30A... Was cheaper when I ordered it and has the same dimensions (and 6gr heavier, but that didn't matter). Plus I wanted to be on the safe side, not overheating the ESC under full throttle. Maybe since you got the 18A ESC, there was a better manual send with it. Mine was crap
Hi, My ( electronic) stock F45 was consuming to much energy, battery was warmer than usual and flight was lasting half than usual. I changed the PCB and everything is back to normal now, hope it can help someone.
I changed my tail boom for a carbon 10 mm tube from Hobbyking. Fit is stiffer but great. Didn't have a crash yet, the real test is coming. The nice orange cab from the S031, available in others colors, is quite easy to fit to the F45. The carbon tail fin of a V2 450 is also easy to fit. I got more agility with a reduction of the weight of the flybar, I really recommend this mod. January 2013: I don't recommend the CF tail boom, both broken in two in a small crash. A lot less robust then stock boom. |
Joined Oct 2012
Drop-in replacement for main motor and battery?
What are the preferred choices if you do not want to make any modification, and get at least the same performance as the original main motor (though a motor that would last longer would obviously be preferred!). Also what battery choice of the correct dimension and at least 1500 mAH like the original?
Best wishes, |
Joined Jul 2012
. Yeah ... i try to balance with the tape at you said , but not sucess . I think the vibrate comming from motor itself and maybe from the big gear . because i did crash sometime .
Very nice. |
Joined Aug 2012
it looks interesting
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax | LMF5000 | Electric Heli Talk | 7 | Apr 26, 2011 08:33 AM |
| Question Upgrading from Co-Axial to FP Single Rotor | Judo JoNny | Electric Heli Talk | 57 | Sep 20, 2010 12:10 PM |
| Discussion Best FP single rotor 4 CH Heli? | helinewbie617 | Micro Helis | 76 | Oct 31, 2009 07:16 PM |
| For Sale will trade my orbiter coaxial for a fp or cp single rotor heli | micro heli | Aircraft - Electric - Helis (FS/W) | 3 | Sep 05, 2007 01:36 PM |
