Old Oct 04, 2012, 05:10 PM
noname2x is offline
Find More Posts by noname2x
Joined Jul 2012
Originally Posted by rexless View Post
I try to balance the blades so the helicopter flies as smooth as possible. Then I mount the camera so it is very tight to the bottom of the helicopter. The velcro is just to set it in place, the zip tie is to hold it down really snug, and the twist-tie through they keychain loop is just to keep it from falling off if the first 2 fail.
I've had some videos come in with vibration and I have to check over the helicopter and the camera mounting to smooth things out again.
how to balance helicopter blade . I've never heard . just heard about balance prop
noname2x is offline Find More Posts by noname2x
Old Oct 04, 2012, 05:25 PM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
Park 370 Continued
Today I received my Park 370 4100kv inrunner brushless motor along with a Turnigy Basic 25A speed control. I went with 25A because I heard that the BEC can get very warm and I wanted the extra capacity. The motor is a complete "plug-n-play" so to speak as it bolts right to the heli with the included bracket, without having to drill out the holes. It even comes with mounting screws and 10T pinion. Photos attached for those not familiar with this motor..
I should have up and running as soon as the programming card shows up and I pickup some Dean's plugs.
arrowshooter is offline Find More Posts by arrowshooter
Old Oct 04, 2012, 05:30 PM
Schiksie is offline
Find More Posts by Schiksie
Schiksie's Avatar
The Netherlands, GE, Weurt
Joined Sep 2012
Originally Posted by noname2x View Post
Why there 's no vibration with you clip . My F45 has a lot lot of vibration . I can't even see any with keychain camera
Strange mine is not realy vibrating that much either...maybe your keychain mounting is causing it ? Second one is not in HD btw
MJX F45 back garden flight.mp4 (2 min 36 sec)
Flying my MJX45 (no crash) (3 min 35 sec)
And my little mods.....just my Gyro is complety %$#@@ so its grounded till my new board is here
MJX F45 little mods (1 min 35 sec)
Schiksie is offline Find More Posts by Schiksie
Old Oct 04, 2012, 05:31 PM
Joined Aug 2012
I use a scale set to grams. You also want to make sure that your Balance Bar is straight. You will see any out of balance while the copter is just starting up on the ground. If it is dancing a little, it's time to look it over.
I just received my MJX bolt on camera today and have no vibrations in the playback.
Old Oct 04, 2012, 06:15 PM
PCloud is offline
Find More Posts by PCloud
Ol' Chap. MJX F45!
Canada, ON, Toronto
Joined Sep 2012
Would a key chain camera be better than the camera built for the MJX F45 ?
PCloud is offline Find More Posts by PCloud
Old Oct 04, 2012, 07:22 PM
Flyor is offline
Find More Posts by Flyor
The Netherlands, ZH, Rotterdam
Joined Aug 2012
Eh200
Hi Guys
I've got the EH200, today, hookt it up to the PCB to try it.
When I set the throttle around 12% the motor just jiggles a bit forward/backward, is this normal?, when I move the throttle up the motor starts to run normal, backwards from a running motor I can keep it running until I reach 8%
Another question is: what is the correct setting for the timing mode of the turnigy ESC for this motor?
TIA
Flyor is offline Find More Posts by Flyor
Old Oct 04, 2012, 08:26 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Originally Posted by Flyor View Post
Hi Guys
TIA
Set timing at low.
Have you set up your throttle end points as per the instructions that came with the ESC. The motor should start between 10 and 17%. The jittering is when you have just enough current to tickle the motor, but not really start it spinning.
BThirsk is offline Find More Posts by BThirsk
Old Oct 04, 2012, 08:29 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
It would be better quality as you can see from markkona's video. The stock camera gets a little out of focus when not moving smoothly or too fast. It's just cheap and fits the Heli, but that is the only benefit.
Old Oct 05, 2012, 01:33 AM
Rollmops67 is offline
Find More Posts by Rollmops67
Eternal beginner
Rollmops67's Avatar
France, Alsace, Strasbourg
Joined Jun 2012
TIA
Hello !
Noramally, in case of the Turnigy ESC, the default settings it comes with are OK for us.
As BThirsk said, you have just to set the 100% and 0% throttle positions, that's all.
Roland
Rollmops67 is offline Find More Posts by Rollmops67
Old Oct 05, 2012, 01:49 AM
Stoersender is offline
Find More Posts by Stoersender
Germany, BW, Göppingen
Joined Aug 2012
Originally Posted by Rollmops67 View Post
Hello !
Roland
A little while back you said, that with setting up the throttle positions you're motor starts at around 10%... am I right?
When I set it up it starts at 22%
I don't get it why my value is so much higher than your's.
Can the throttle positions even be programmed two times? Or is it only possible to do this once? Because at the first time I tried to do it I got a little confused and didn't do it properly
Stoersender is offline Find More Posts by Stoersender
Old Oct 05, 2012, 01:54 AM
Joined Aug 2012
Boy I was stumped there for a bit until I figured out that you still had to hook the original PCB wires to the battery too. ALL I can say now is "HOLY C**P BATMAN!!!" . Almost put the darn thing up through the roof of my garage. Gotta love the motor wine.
Can't wait to get to the park tomorrow.
Old Oct 05, 2012, 01:58 AM
Joined Aug 2012
You can program the throttle positions as many times as you want, but I believe the difference is be between the "normal" and "very soft" start modes that you have the program the SC to.
Old Oct 05, 2012, 03:02 AM
Joined Aug 2012
Start mode is set to normal
The difference between these modes is, that the throttle still starts at 22% but you will have to remain longer in that position to get the motor turning.
Old Oct 05, 2012, 03:32 AM
Eternal beginner
Rollmops67's Avatar
Joined Jun 2012
Yes you're right.
Me neither.
I don't remember very well, but I think this was about what I had on my heli before I programmed max and min throttle.
I think you can programm it as many times as you want.
Try again !
Happy flying and smooth landing !
Roland
Old Oct 05, 2012, 04:05 AM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
When you program for stick, make sure your tail motor is unplugged.
Program the stick positions and after you hear the final beeps to signal done as in the instructions, unplug the power to the pcb.
Leave the tail unplugged and bind again. Make sure you are getting just the 2 beeps for cell count when it binds and initializes the ESC.
I had issues with one ESC that it would often enter program mode on binding. I don't know if it was the ESC or. The way the pcb functioned.
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
