Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Jul 2012
Thanks for the credit Mate... Well, what do you know! my 2 1/2 cents thought turned out to be not bad at all!... ![]() ... and just for your info, not necessarily caused by a longer tail boom, bobbing or jerking usually associated with a weak / malfunction or overheated tail motor.. If you often encountered this problem, try to use heat sink just to prolong the life span of the tail motor..
I think the main drawback of a longer tail is that during forward flight, it acts more strongly like a wind vane, and will take more effort to make it turn.
A shorter tail will improve responsiveness since it has less front-to-back resistance. Also a longer tail mean larger turning circle for the tail, so while the tail will have more "leverage". Even stationary pirouettes will be slower as it has to travel further to complete a rotation. Food for thought
Joined Jul 2012
The Netherlands, ZH, Rotterdam
Joined Aug 2012
Going brushless
Hi Guys
I'm going brushless, the main motor seems a little weak. I want to keep the stock 2 cell battery and stock tail motor. I'm thinking this motor, since the EH200 is hard to find. http://www.hobbyking.com/hobbyking/s...or_4200kv.html Can I use this ESC, or do I need a other one? http://www.hobbyking.com/hobbyking/s...ontroller.html Any thoughts, do I need something more to get this setup working. |
OK HERE's one
and here s another if you understand german ![]()
In terms of the Motor, the one you linked will work, however, you will need to modify the body of the F45 either by cutting or bending, or both, as it only has a 24mm space where the motor sits, and that motor you chose is 26mm wide. Other than that it is just fine. Oh and you will need a new pinion as well, such as this: http://www.hobbyking.com/hobbyking/s...dproduct=11198 As the stock is only 2mm, where as you will need a 2.3mm pinion. Might have better luck on eBay though as HK is out of stock
Germany, BW, Göppingen
Joined Aug 2012
Some time ago word was going around that a heat sink won't be able to lower the heat significantly.
Today I measured the temperature of two more flights, giving a total amount of 6 times flying with heatsinks installed head and tail. It does help a lot! Not only during the flight, but the cool-off effect after landing is also much faster... I didnt look at the temperature at each flight. But the head + tail motor are still running smooth after a total of 48 flights. ![]() more interesting are the temperatures measured at the main motor because i didnt measure the tail motor's heat until i installed the heatsink. the temperatures of the first few flights were lower because i was very carefull not to destroy the mjx instantly. The first higher peaks indicate when i was able to fly harder. data sheets: main motor ![]() ![]() tail motor ![]()
Joined Aug 2012
![]() Now I understand why the EH200 is a better option, only 23mm wide should fit easier :-) maybe it's better to wait a while until I find one of those. |
Greetings
In that video with the Park 370 Brushless Motor the helicopter is running the stock blades. Would that make sense if he is sticking with the 7.4v power supply? http://www.horizonhobby.com/products...100kv-EFLM1000 That's an expensive motor! I think I'm going to order the EH-200 from another vendor depending on their shipping costs. I'm trying to decide if I should try the 5000kv version with stock voltage like in the video or go for the 4100kv version and get a new 3C Lipo. I think I can convert for ~ $50-$75. My hope is that will tie me over until I pick up one of those Carbon Fibre frames and start building one of those up, or go for the same in a Quad. |
Of course the heatsink helps to lower the temp, but essentially at the outside of the motor (housing and magnets of the stator) But what gets the hotest are the rotor and the brushess, wich are not in contact with the heatsink, and are therefore just marginally cooled by the heatsink. On my first F45, both motors have heatsinks, tail motor died after 50 flights, and main motor after 55 flights. But again, just my 2 cents |
I used that in my firefox CP and it did not work well. With full battery, it was OK. When battery got to about 7.8 to 7.9 volts, the power was hardly enough to keep in the air and that heli is half the weight of the F45. |
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax | LMF5000 | Electric Heli Talk | 7 | Apr 26, 2011 08:33 AM |
| Question Upgrading from Co-Axial to FP Single Rotor | Judo JoNny | Electric Heli Talk | 57 | Sep 20, 2010 12:10 PM |
| Discussion Best FP single rotor 4 CH Heli? | helinewbie617 | Micro Helis | 76 | Oct 31, 2009 07:16 PM |
| For Sale will trade my orbiter coaxial for a fp or cp single rotor heli | micro heli | Aircraft - Electric - Helis (FS/W) | 3 | Sep 05, 2007 01:36 PM |
