Old Jul 10, 2012, 02:27 PM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Nevermind... I see it now. 2 3.7v batteries in series, blue goes to the "middle" on the end where you connect them in series.
rexless is offline Find More Posts by rexless
Old Jul 10, 2012, 03:18 PM
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
Originally Posted by rexless View Post
Does anyone know what the centre blue wire does on the stock battery?
I have some extra batteries from another source and I have a bunch of connectors.
I don't want to take apart my good battery to confirm the wiring and where to solder the wires. Does anyone have a photo of the wiring of the battery so we can see where all the wires go? I would guess Black to - and red to + (seems logical) but the blue one is where I get confused...
If you have a voltmeter you can tell which ones are positive and which ones are negative. There should be two positive and one negative I think,
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Jul 10, 2012, 03:48 PM
Rollmops67 is offline
Find More Posts by Rollmops67
Eternal beginner
Rollmops67's Avatar
France, Alsace, Strasbourg
Joined Jun 2012
I think you're speaking about the white connector with the red, blue and black wire ?
The red wire (+ of the battery) is connected to the (thicker) red wire of the JST connector, and the black wire (- of the battery) to the black one on the jst connector.
Your battery has 2 cells (2x3,7V=7,4V)
The blue wire is taken between the 2 cells, and is necessary to balance the battery while charging.
On other batteries, in 99% of the cases, the color of the red and black wires is the same, it's just the blue cable wich can have another color (on my turnigy batteries it's yellow)
If you need more information about balancing, type something like "lipo battery balancing" on google...
Rollmops67 is offline Find More Posts by Rollmops67
Old Jul 10, 2012, 04:04 PM
Eternal beginner
Rollmops67's Avatar
Joined Jun 2012
F45 windy flight
This evening a flew my F45 with some wind, I think about 20-25 Kmh. (12-16 Mph)
Sometimes I had to have the elevator full forward to be able to hover without flying backwards...
While testing the helis behaviour in the wind I noticed a funny thing :
When placing the heli perpendicular to the wind and using aileron, it has less trouble to fight the wind, especially when it comes from the left side (maybe the tail rotor helps a little bit).
The settings of the links on the servo arm are still stock.
This was the fifth flight outdoors, and each time I learn a little more
Old Jul 10, 2012, 04:23 PM
rexless is offline
rexless's Avatar
Canada, BC
Joined Apr 2012
I have found this as well.
The blue wire is taken between the 2 cells, and is necessary to balance the battery while charging. On other batteries, in 99% of the cases, the color of the red and black wires is the same, it's just the blue cable wich can have another color (on my turnigy batteries it's yellow)
Thanks!
Old Jul 10, 2012, 07:20 PM
douglas2950 is offline
Find More Posts by douglas2950
1 can 't have 2 many heli's
Belgium, Vlaams Gewest, Kapellen
Joined Jul 2012
450 Swashplate
Hello,
I managed to adapt the swashplate from a 450heli and use it on the F45 .
The cyclic movement has almost doubled and the F45 reacts like it gets kicked in the when I push it forward.
I only made a short testflight because it's dark right now, I will give it an extensive testflight tomorrow .
douglas2950 is offline Find More Posts by douglas2950
Old Jul 10, 2012, 07:54 PM
Joined Jul 2012
The third pic I should have called :Full extended RIGHT aileron
Old Jul 10, 2012, 08:08 PM
Whizgig is offline
Find More Posts by Whizgig
Eugene
Whizgig's Avatar
Australia, VIC, Delacombe
Joined Oct 2006
Originally Posted by douglas2950 View Post
Hello,
I have thought about doing this mod myself just to see if it worked and it dose you have proven that it can be done and it looks like it works better that the standard.
Good work Douglas.
Whizgig is offline Find More Posts by Whizgig
Old Jul 10, 2012, 11:05 PM
slothy89 is offline
Find More Posts by slothy89
Head in the clouds
slothy89's Avatar
Australia, VIC, Sebastopol
Joined Apr 2012
The heli will push into the wind better sideways when still stock as the aileron link is further along the servo arm allowing a longer throw. Without the Elevator mod, this will always be the case and the F45s forward motion will not be as strong as its sideways movement.
For those curious about how LiPo/Li-Ion batteries are wired, here is a good site that explains it all with pretty diagrams. Make sure to tick the "Show Balancer wire hookup" to see the second connector as well.
LiPo Wiring Info
For motor heatsinks I have ordered the EK-000208 tail heatsink and the EK-000209 main motor both from the HoneyBee V2 FP.
I did look at the CP3 tail heatsink but thought the fact it doesn't have the flat spot like the tail motor does, it wouldn't be as effective.
slothy89 is offline Find More Posts by slothy89
Old Jul 10, 2012, 11:08 PM
Heli Mania
PNW
Joined Dec 2010
What is the "elevator mod" ... guess I don't recall reading about it. I know the servo arm for the elevator is short to fit inside the frame, and the link is already on the outer most hole. So what's this mod do?
Old Jul 10, 2012, 11:42 PM
slothy89 is offline
Head in the clouds
slothy89's Avatar
Joined Apr 2012
You replace the current servo arm with a new one that is uncut, and cut it yourself. But since there is a bit of room between the frame and the servo, you can get an extra hole or 2 out of it if you cut carefully. This gives you just that little more throw.
Alternatively you could cut the frame so a full length arm could fit and get even more throw.
Old Jul 11, 2012, 12:23 AM
Heli Mania
PNW
Joined Dec 2010
That's probably the way to go ... has anyone here done the mod that way? If so, any photos showing how it turned out?
Old Jul 11, 2012, 01:06 AM
slothy89 is offline
Head in the clouds
slothy89's Avatar
Joined Apr 2012
I have a question, what type of connector is used for the Camera connection? I want to know if it has a specific name, as I am thinking of using it to power an LED Lighting setup that I can turn on/off with the TX.
If anyone has any idea that would be great for me, the Spotlight just isn't enough to help with orientation, especially for Dusk flying.
Old Jul 11, 2012, 01:18 AM
Mitch332 is offline
Find More Posts by Mitch332
V911 F45 Super CP
Joined Apr 2012
If your light setup has the same type of 2-pin connector as the stock LED, you can plug it into 2 of the 3 camera pins. Use the pins closest to the stock light connector
Mitch332 is offline Find More Posts by Mitch332
Old Jul 11, 2012, 02:13 AM
slothy89 is offline
Head in the clouds
slothy89's Avatar
Joined Apr 2012
Thanks for the tip, but this will be a custom from scratch LED setup, so I need to buy the bits and pieces. Knowing the name of the connector will make this easier
But knowing I can use a 2 pin connector for the front most 2 pins is good. But the 3 pin is preferable, as the plastic is stretched to fit the 2 pin plug in.
If worst comes to worst, I'll just cut the current LED connector off, and include that LED in the custom circuit.
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
