Joined Jun 2012
Hd Key Cam arrived
Hi
it weekend the cam arrived from china in 10 days ![]() I did fly with it but is was to windy and my face was in a close up so you will have to wait for a movie but it will come. I bought this one : http://www.ebay.com/itm/ws/eBayISAPI...m=160719435901 I attached a printscreen made with media player, it is in 1280 resolution (60 fps) I will follow up (no heli part arrived yet) |
Joined Jun 2012
it is the heli, if I see my movie made (external) it is not straight flying, I did see it on more movies. jeroen |
The lean to the right is due to the sideways push of the tail motor, which in order to maintain a steady hover, the main rotor needs to be angled to make the heli want to push back to the right, this creates the slight lean. The smaller the aircraft the more pronounced this is as the force to weight ratio increases. Even a real life full scale helicopter will have a slight tilt to the side when hovering due to this. |
Mods on my F45 so far
Here are somme photos of what I changed-modified on the heli :
- Bigger 2200 mAh battery, weights 133 gr versus 98 gr for the original. (Turnigy batteries with 25C constant discharge current, bought them at Hobbyking) - EC3 connectors for the battery. - Heatsinks on main and tail motor (I discovered that the tail motor becomes also very hot) The main motor heatsink is an E-flite EFLH1309 (cut in two, otherwise it would be to high) The tail motor heatsink is an E-sky EK-002447. After cutting 3 of the plastic "branches" that cover the tail motor, it fits perfectly. Heat-conductive grease (originally for computer CPU) has been applied before mounting the heatsinks. Here are some photo, maybe they can give you ideas. Have nice flights and no crashes ! ![]() Roland
Can you give me a direct link for the tail motor heatsink mine does get hot too but not as much as the main motor used to!!! Now that I have converted my main to brushless I have no need for the heat sink but I'll keep it with the main motor coz you never know I might use the BL motor for a 450 kit that I am considering of getting for a future build!!
So I finally had a chance to shim my blades yesterday - using the plastic reinforcements for binder pages. My first try with 3 stuck together created a weird front-to-back rocking effect. I checked it over later and found one of the main blades wasn't as free as the other, so I switched that one to 2 stuck together and now the weird effect has gone and if flies just fine. To be honest I can't yet tell if it's made much of a difference. I think my expectations may be skewed by flying the V911's which respond so quickly in most situations. In about the same winds, same field, same day I seem to get stuck in a hover on the F45 with full elevators forwards. On the V911 if I do the same I end up in a nose dive but I can at least get the nose down long enough to punch the throttle and get some forward movement. I don't expect the F45 to be as fast - in fact that might just freak me out - the fields I have here are not big enough for that!.. I'm just wanting a bit more confidence fighting a light breeze.
http://www.best4fun.be/esky-tail-mot...nk-002447.html But I don't know if thet ship to Malta. Roland |
Does anyone know what the centre blue wire does on the stock battery?
I have some extra batteries from another source and I have a bunch of connectors. I don't want to take apart my good battery to confirm the wiring and where to solder the wires. Does anyone have a photo of the wiring of the battery so we can see where all the wires go? I would guess Black to - and red to + (seems logical) but the blue one is where I get confused... |
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax | LMF5000 | Electric Heli Talk | 7 | Apr 26, 2011 08:33 AM |
| Question Upgrading from Co-Axial to FP Single Rotor | Judo JoNny | Electric Heli Talk | 57 | Sep 20, 2010 12:10 PM |
| Discussion Best FP single rotor 4 CH Heli? | helinewbie617 | Micro Helis | 76 | Oct 31, 2009 07:16 PM |
| For Sale will trade my orbiter coaxial for a fp or cp single rotor heli | micro heli | Aircraft - Electric - Helis (FS/W) | 3 | Sep 05, 2007 01:36 PM |
