Apr 28, 2012, 02:40 PM
USA, MA, Swansea
Joined Mar 2003
Keenan
Thanks, Don't get any ideas yet on another build.. you still have to finish and fly the present jet before the Ant. Saw your pics and it is coming along fine.
Joe, I was contemplating built up cowls but I did not want to spend the time and the use of balsa. There are at least a half dozen ways to do it. For me, carving out of wood was the easiest. It hasa good hard base and will not break easily. My way was fast. Just over an hour for 4 inlets on top. The bottom coolers are balsa and the same time also. I also could have made a plug and out of glass also. That air coming in over the top of the firewall gives a better circulation.
Rawy, I was thinking of adding a whistle to my FW-190 and the Bf-109 to get that supercharger sound they have. Such a nice sound on a real plane flyby. J. Morgan is my idol and Mentor. You will see many of his styles of building in my planes.
David, I weighed the plane and I am up around 11lbs with motors and battery right now. I have no fear of the weight. My "Emily" is 20 lbs. and a 100" wingspan. It is a higher wing loading by far. This plane will be under 15 lb. I just got my ESC's, 4 - 4mm shafts, a 6amp UBEC, and 4 - 4mm collets. Heavy little box. Thanks. Lots of hours. 12 hr days at times. Mostly about 8 hours is common though.
**Neons** Bob
