Old Feb 18, 2012, 10:05 PM
**neons** is offline
Find More Posts by **neons**
5,200 Led Lighted Bike-Bob P.
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
Build Log
Martin XPB2M-1 Mars 1943- Scratchbuild
Last year 4- 2011 I scratchbuilt the Kawanishi H8K2 Japanese "Emily". It was a 3 month project with plenty of interest. (http://www.rcgroups.com/forums/showthread.php?t=1417974)
This year, 2-2012, I have started the new build of the early version of the Martin Mars that had the twin rudder. I have the fuselage framing started. I am basing the model on Ivan Pettigrews plans.
You can contact Ivan by emailing him. Here is his email address:
ivanp@dowco.com
Scale 1/20
Wingspan: 120 Inches
Length: 72 Inches
AUW: 13 pounds. as I estimate.
Wing Area: 1515 sq. in.
Wing Loading: 15.7 oz/sq. ft.
Airfoil: Eppler 197 with NACA with washout built in on outboard wing sections.
Power: Hex DT-750 brushless. MAS 10x7 with opposite rotations Nanotech 4s 5000Mah 14.8v Lipolys
The model will not be true scale as there are modifications on the plans that are not exact. I am going to divert from the plans some to use a mix of Depron foam and wood with some carbon fiber also I am first going to upload some pictures and drawings and maybe some notes of this version Mars.
**Neons** Bob
**neons** is offline Find More Posts by **neons**
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
After all the trials were over the Mars XPBM-1 was redesignated for carrying cargo and personel. There was a problem with control of the plane with the twin rudders using the flaps. I guess it affected the rudders by disrupting airflow on landings. There was an R-1 Designation and a 3 later before the present JRM's flying as water tankers these days in Canada. I am concentrating my build on the XPBM series as I like the look it commands. Here are some more drawings of the JRM series for study. The tail is the most prominent change along with the gun turrets. When the JRM's came out thet added more power and new 4 blade props. So basically these drawings apply to the early versions also.
**Neons** Bob
Old Feb 18, 2012, 10:47 PM
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
The Build Log is here. The plane has been finished. It was taxi tested and has not been flown at this time. The season has run out and I will try to fly her next spring. The video will be added after the flight here.
Log
http://www.rcgroups.com/forums/showt...5#post22206438
Taxi Testing
10 17 2012 Martin Mars Water Test (4 min 12 sec)
Updated 12-04-2012
Maiden Flight
9- 6 -2013 Martin Mars Maiden Flight (4 min 10 sec)
Update: Flew Sept.8, 2013 ........Another latest video - 5th Annual John Nicolaci Float Fly - Mars flight
9- 8 -2013 5th Annual J. Nicolaci Flo Fly - Martin Mars Flight #2 (5 min 19 sec)
Old Feb 18, 2012, 11:15 PM
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
First off. There is another thread building the same plane in the JRM format by Rudderman a few years back. It is a very good build log if you follow Ivan's plans closely. As I mentioned I will follow some what closely. My plane will probably be slightly heavier. I am deiviating with different building materials here.
http://www.rcgroups.com/forums/showt...ght=ivan+plans
The framing was started with some fresh cut clear hard pine wood. I cut strips from 1/4inch thick pieces in 3 sizes. 1/4x1/4, 1/4x3/16, and 1/4x1/8th inches. Most framing was laid out with 1/4 square along the bottom longerons. The rest is mostly 1/4x 3/16inch. I used 1/8th inch balsa reching above the waterline. Progress went along good for the 2 days here.
**Neons** Bob
Old Feb 19, 2012, 07:30 AM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
Iam sighned up Bob ,i can remember my solent fuse at this stage . joe
cracksmeup is offline Find More Posts by cracksmeup
Old Feb 19, 2012, 07:33 AM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Subscribed Buddy!
martys is offline Find More Posts by martys
Old Feb 19, 2012, 12:45 PM
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
I find a few measures do not match but I can build a plane from 3 view drawings so I can manage these plans easily. I found the nose off on measures but it will be ok though.
**Neons** Bob
Old Feb 19, 2012, 01:34 PM
LukeZ is online now
Find More Posts by LukeZ
LukeZ's Avatar
Joined May 2001
Hi Bob, I've added this thread to the Ivan Sticky. Will be interesting to see a twin-tail version.
Everyone must be tired of hearing it by now, but try to keep it light! Ivan's designs don't need any reinforcing. I've never seen a model built to his plans break from weakness, but I've seen a few that didn't fly so well due to excessive weight.
Luke
LukeZ is online now Find More Posts by LukeZ
Old Feb 19, 2012, 02:27 PM
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
Luke, Thank You. That will be nice to link relatives together for others to see a different version. Although I will have a some what different materials in the construction, there may be some that accept it and the true all wood nostalgic people may frown on it.
**Neons** Bob
Old Feb 19, 2012, 04:52 PM
cracksmeup's Avatar
Joined Jun 2009
**Neons** Bob
Foam ,wood or balsa,paper we dont care as long as it floats and flys Bob. Who's frowning ! lmao joe
Old Feb 20, 2012, 12:25 PM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
i have pulled up a chair...
will be watching this one over the top of my Sunderland build
David
how much is offline Find More Posts by how much
Old Feb 20, 2012, 09:53 PM
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
V hull formers , Water Rudder, Modified tail sector
David. Welcome. There are days I move along and then some that drag as I figure out how I want to do something. Of course there are days I just go fly. I am just guessing and I think a rough estimate would be 3 months. Enjoy. Pass the popcorn.
Luke, Thanks.
I will be making modifications as I build my plane. The plane is built light as Ivan designed it. He has a nice floater as seen in all his videos. Great flying. I will probably be flying in some windy weather here in the warmer months. 90% of our days are windy about 18MPH in mid day and all afternoon. See my Avatar and look at my Emily and you see maybe 15mph and choppy waters in fluctuating breezes. I think a slightly heavier plane is acceptable for me.
Here is what I did in the last couple days. I curved the nose section by making fine slits in the sticks and pinching in the sides to give it some round shape . The plans were showing flat. The photos look round. I laid all the V formers in place. I used a 1/4 x1/4" square for the keel. Tied it down in the nose and bent in the curve and CA'd in place. I put in a support gusset behind the plywood nose bulkhead. Next I installed gussets all along the chine corners inside. There just was not enough glue contact in that sharp angle. Here is a weak point I strengthened. Another point of stress that I wanted strengthened was the area under the wing trailing edges on the fuselage. I have seen many planes break right at that area in a crash including mine. These were all gusseted also.
The next thing I wanted is a water rudder that would conform to the original profile lines. I made the mount and cutout a rudder from the existing hull taper on the bottom. Using brass tube and a shaped copper end I soldered and then inserted that tube end into the hollow rudder. The outer housing was fitted into the hull and then a new former was installed with another gusset. The curved outer balsa hull shape was glued in place also. The bottom of the hull and rudder will have a thin plywood flared in place. All I have to do is solder a copper servo arm on the rudder post when ready.
The rear picture shows the rudder dropped in. There were additional formers installed in the tail section. I changed the keel angle to a slow curve rather than the straight run on the plans.as the real photos show. The stern post was widened to accept a tail gunner station. It will also help the elevator seating too.
Next I am looking at getting the elevator and rudder cables in place. The side sheating will go on first so I will also get better gluing access also. Then the bottom sheeting can be done.
**Neons** Bob
Old Feb 22, 2012, 01:02 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Excellent I'll be following along...
Gree is offline Find More Posts by Gree
Old Feb 22, 2012, 07:41 AM
PS1 is offline
PS1
Find More Posts by PS1
PS1
Joined Jan 2012
Luke, Thanks.
**Neons** Bob
...Hi Bob / Hi joe and all...
....God!...This it is Super structure , that beautiful and should lightly
( Pretty since still not finished) ....Very nice work..! Bob
PS1 is offline Find More Posts by PS1
Old Feb 22, 2012, 08:51 AM
Keenan smith is online now
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
subscribed
Keenan smith is online now Find More Posts by Keenan smith
Martin Mars Project Rudderman98 Scale Kit/Scratch Built 454 Feb 11, 2012 02:23 AM
Sold Scratch Built Martin Mars RTF 120 In. Wingspan Rudderman98 Aircraft - Electric - Airplanes (FS/W) 15 Jun 17, 2011 01:25 PM
Discussion Martin Mars and Philippine Mars Photo Documentation Isaiah 40:31 Giant Scale Airplanes 3 Nov 18, 2009 01:12 AM
Video 1:20 scale (3.1m wingspan) Martin Mars alexcmag Electric Plane Talk 10 Jun 04, 2006 10:17 PM
Martin Mars FLIES!! Rudderman98 Scale Kit/Scratch Built 1 Sep 22, 2003 05:25 PM
