Chuck, some connectors (with Deans being the poster child) can be so hard to unplug that you risk yanking the leads and breaking stuff, especially if they come unstuck very suddenly. I do use Deans plugs and I've solved the problem, but a lot of people continue to grab them by the wires and just hammer away till they separate. Obviously not a good idea...
I think soldering difficulty for beginners a big part of the problem with Deans, though. If heat is applied too long, the plastic will warp a bit and make them way harder to separate than necessary. Things like bullets can be all over the map. I've had some that might as well be soldered once they're plugged together, while others literally fall apart if the wire shifts a bit... I haven't messed with anything else, really. I've got Deans down to an art and I like them a lot. |
USA, MO, Florissant
Joined Nov 2010
After the current issue (who said 3.5mm are only good to 15 A?, I use them to 50A all the time), the next deciding area would be ease of use. As noted above, some low quality bullet/banna conns of non-standard diameters, 1-2.5mm, are too tight and some are too loose, avoid them at all costs. I've been using 4mm and 3.5mm bannas for over 12 years, only once have I got a set of 3.5s that were both too tight & too loose, they were from a batch from China. Never seen them again, the market took care of them very nicely.
Although not mentioned, the non-gold plated conns are for small children's toys and cheap household appliances, not for more than 1 amp at best! The tin or zink plating wears out very fast, and the springyness of the metal is soon gone too, ask the car guys about the Tamaiya plugs! One thing about 4mm is that they are the standard Banna connectors for electronics, and as such the supply chain has many of them in various styles of shanks and fittings, all of very high quality, even at Radio Shack. As I said, I prefer the 3.5 mm in most applications as they are easy to solder, plug & unplug, and acceptable pricing. They must be polorized and insulated by the user, so if this puts you off, don't go that way, get something else. There are many choices out there. As for T Conns, originally made by Deans and called Ultra Connectors, the Chinese knock-offs are terrible and provided free of cost on LiPo battery packs, if you can tollerate them so be it, go use the heck out of them, they are nicely polorized and will carry a lot of current, 100A+ in bursts. For F5B and other Very, Very High currents 300+ Amps!, 6 mm are the only way to go, they won't heat up and the solder won't melt and let the wire fall out! They are difficult to work with in every way, not for the in-experienced at all. Hope this helps, Crunch |
Joined Feb 2012
Joined Jul 2006
1) Ease of fabrication 2) Ease of usage (how easy they are to plug into each other) What other variables can be introduced into the equation? |
Joined Feb 2012
This is why I was considering 4mm ones. I thought maybe they were more "standard" than 3.5s. As for these "various styles of shanks and fittings"... you don't mean the actual metal connector, right? You're just talking about the plastic harnesses? (Sorry, I just want to be clear.) |
I suppose for a modeler with an established connector infrastructure, another factor would be plug compatibility... Which is a no-brainer.
I do know that I mostly fly planes where something like an XT60 or EC3/5 would be too physically big to fit in the fuselage. The only thing smaller than Deans that I've found is 3.5mm bullets, but I don't like them due to possible shorts... But for most applications, the size of the connector probably doesn't matter all that much. Price? Doubt it. Really, if you can't afford connectors....
Joined Feb 2012
For me, at least these things are factors:
- Will it handle the job? - Is it a set standard? - How long will it last? What happens as it ages? - Is it a good idea to use it for the given application? Does it make sense? - Is it safe to use? (Haha, yeah. I said that.) - Can I get it from various manufacturers? Am I going to get "monopolized", so to speak? (Forget the knockoffs.) - Is it easy to use? Is it practical? |
Joined Jul 2006
Eugene, Oregon
Joined Feb 2011
I use EC3s on everything using 1300mah batts and larger.
JSTs are on the smaller batts. I have never had an issue with pulling apart EC3s. I do put in the female bullets (on the battery power leads) a small amount of white lithium grease (using a tooth pick) every new battery. EC3s are very easy to solder using a piece of wood with small holes drilled to hold the bullets during the soldering process. I have never had a cold solder issue on my solder connections. I have had factory cold solder issues on a new airplane. |
| Thread Tools | |
| Question Solder or use bullet connectors when making my ESC wires longer | justy g | Power Systems | 4 | Sep 29, 2011 08:02 PM |
| Sold XT60 Bullet Connectors Plugs - 5 Pairs - $7.50 each pack | JimG_AZ | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | Sep 29, 2011 08:01 PM |
| Sold XT60 Bullet Connectors Plugs - 5 Pairs - $7.75 each pack | JimG_AZ | Aircraft - Electric - Batteries & Chargers (FS/W) | 15 | Sep 09, 2011 08:50 PM |
| Discussion Need some advice on Hyperion EC5mm Bullet connectors. | JEFFRO503 | 3D Flying | 3 | Mar 01, 2010 01:04 PM |
| Wanted Looking for some 5.5mm Bullet connectors | Raydee | Aircraft - General - Miscellaneous (FS/W) | 1 | Jul 25, 2009 05:07 AM |
