Old Feb 29, 2012, 11:40 AM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
sounds great, i look forward to sending others to your site.... my bank account is not going to like this
Adidas4275 is offline Find More Posts by Adidas4275
Old Feb 29, 2012, 12:23 PM
SeismicCWave is online now
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
Originally Posted by Adidas4275 View Post
yeah is a good point.
my battery cable is tight.... i build my harness not for the gimbal.... so that might be part of it as well.
i installed the isolators like you described.... however it is possible that I twisted them too much..
what size battery are you using?
4s 5000 mah. Probably same as yours.
SeismicCWave is online now Find More Posts by SeismicCWave
Old Feb 29, 2012, 12:27 PM
AMA 46133
Hawaii
Joined Feb 2003
Newest video. Still dealing with vibrations at hover. Got some supplies in today so tomorrow I will go to work. Thinking about salvaging my droidworx landing gear rails and vibration grommets to use on this....
It looks pretty good. Hard to tell vibration in low light. You may have aerodynamic vibration on the multi rotor. I noticed vibration when you are staying still or descending. If you listen carefully when you fly you will noticed that the props make a different noise when you are hovering or descending. That is from the prop wash.
I know I will get some vibration when I hear that noise.
Old Feb 29, 2012, 04:50 PM
recep is offline
Find More Posts by recep
recep
recep's Avatar
Ankara, TURKEY
Joined Sep 2005
Hi Adidas4275 how heavy is your y6 and how are your flight times Im building a similar y6 with carbon from scratch and Im using graupner 11x5 props and hope to get less vibration. I also use some scratch dampeners which have worked well on hexa.
recep is offline Find More Posts by recep
Old Feb 29, 2012, 05:00 PM
AMA 46133
Hawaii
Joined Feb 2003
Your frame is blocking a lot of airflow.
Old Feb 29, 2012, 05:03 PM
recep is offline
recep
recep's Avatar
Ankara, TURKEY
Joined Sep 2005
SeismicCWave that is the part that will float under this frame
Old Feb 29, 2012, 08:07 PM
AMA 46133
Hawaii
Joined Feb 2003
LOL, now that makes sense. I thought your plate is your frame.
Old Feb 29, 2012, 09:33 PM
Adidas4275's Avatar
Joined Mar 2011
looks great man
i dont know my flying weight.... but i will check tomorrow for you
Old Feb 29, 2012, 10:27 PM
wac is offline
wac
Find More Posts by wac
wac
Joined Jun 2005
Originally Posted by askman View Post
well. I am finally getting my website put together. www.AskmanProducts.com I just got the barebone structure up. I will add to it as I have time. I am building samples this week to take pics. (and probably next week as well) lot of combos. while non custom multicopter stuff will be sold through gary's and dji-usa website, I will handle all the rest directly. (airplane, pole, etc)
I will update things on my blog here as well.
wahooooooooo!!!!!!!!!!!!!!!!
This is great news
wac
wac is offline Find More Posts by wac
Old Mar 01, 2012, 09:47 AM
askman is online now
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
thanks for the welcome back wac. I should have full line up of product very soon. I have most of the designed done, and starting to make sample for pic and testing. Every piece will be updated design.
askman is online now Find More Posts by askman
Old Mar 01, 2012, 06:16 PM
recep is offline
recep
recep's Avatar
Ankara, TURKEY
Joined Sep 2005
looks great man
Thanks Im waiting for the input I have nearly finished my y6 but my auw will be about 2500gr and now Im concerned about the motors wont be enough for that mass
Old Mar 01, 2012, 07:25 PM
Adidas4275's Avatar
Joined Mar 2011
your right, i didnt notice that... when flying forward there is very little vibration and when hovering there is a lot more.
I am not convinced that I am balancing my props well.... yet....
so I got the dubro balancer so I can test it vs my topflite
we will see, i might move the camera back some, i notice my CG is fairly far forward.
Old Mar 02, 2012, 10:53 PM
Adidas4275's Avatar
Joined Mar 2011
okay so I did some more work today on the gimbal.... I added 12-14 rubber grommets to the mounting points between the frame and gimbal. I then added 4 more rubber isolators to the battery/camera tray.
I also bought the dubro prop balancer and rebalanced my props.
I noticed that I had one prop adapter that was slightly bent and not spinning true.
Then i mounted the nex-5n on moongel on the camera tray.
after all this i have fairly good results. not perfect (yet) but inching closer!!!!
Aksman's Gimbal Test Night Time Nex-5n Hoverfly Pro (2 min 34 sec)
Old Mar 15, 2012, 12:23 AM
Adidas4275's Avatar
Joined Mar 2011
well... sorry for the lack of videos lately.
I have been sport flying with my Y-6 Rusty's frame to try and improve my flying skills and I have started my 1st of 2 RC Carbon Builds.
Here are some pictures
Thread
Old Jun 04, 2012, 12:52 AM
Adidas4275's Avatar
Joined Mar 2011
here is a test with a WKM as a flight and gimbal controller (this has some post stabilization)
AG0555n Gimbal Test with DJI Wookong M WKM gimbal control Hexacoper Sony Nex-5n (2 min 25 sec)
here is with the HoverFly pro controller. (this is 100 completely RAW)
Askman and Gary's Gimbal Test MKS Servos Sony Nex-5n Aerial Video Y-6 Hexacopter HoverFly Test (3 min 23 sec)
the HoverFly Pro controller is smoother and has better gimbal controls.... but the WKM has more features and better GPS control
both of these are on the same Rig, with everything the same except the flight and gimbal controller.
there is some bounce that is from the gimbal G10 not being strong enough.... askman is making new, thicker battery trays for the gimbals now to address the issue. Great customer service!
Question 2 Axis Camera Gimbal fordarrick Multirotor Talk 2 Feb 02, 2012 04:03 PM
Sold DIY camera gimbal 2 axis without servo noppita Aircraft - Electric - Multirotor (FS/W) 10 Feb 01, 2012 06:27 AM
Sold Prototype 2 axis small camera gimbal for sale (UK) Joshbb Aircraft - Electric - Multirotor (FS/W) 7 Nov 28, 2011 03:15 PM
Sold 3 axis pan/tilt/roll Belt Driven Camera Mount techcapsule FPV Equipment (FS/W) 3 Jun 28, 2011 05:58 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
