Old Feb 18, 2012, 05:02 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
Question
GForce G40 says 700KV, but now sold as 800-something
I have a Gforce G40 700kv (sticker on the motor), nowadays they are sold as 890- did they change the spec, or maybe this isn't a G40? (No tagt etc says G40 on it)
http://www.valuehobby.com/gforce-g40-890kv.html
CNY_Dave is offline Find More Posts by CNY_Dave
Old Feb 19, 2012, 12:55 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Value Hobby's "GForce" motors are manufactured by XYH (Shenzhen XingYaoHua Industrial Co). The C5045 is produced in two different winds - 720Kv and 890Kv.
Apparently some time ago Value Hobby switched from one wind to the other. The 720Kv version is still listed here. Note that the product image shows a motor labeled '700Kv', but it was tested at 720Kv. It is not unusual for the actual Kv to be a bit higher than spec.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Feb 19, 2012, 01:01 AM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
For cheap Chinese motors it is unusual for them to be somewhere NEAR spec.
flydiver is offline Find More Posts by flydiver
Old Nov 17, 2012, 07:34 AM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
What experience do you have with the G-Force 700? Are they reliable as I'm looking to find a cheap alternative.
jw357_23043 is offline Find More Posts by jw357_23043
Old Nov 18, 2012, 07:02 PM
CNY_Dave is offline
Joined Sep 2010
I have not tried using it yet, so can't help.
I have buried both my other motors into the dirt and they just cleaned up and kept on truckin '
Old Nov 18, 2012, 07:14 PM
Shut up and Fly!!!
Joined Aug 2011
Sounds like they are durable!
Old Nov 19, 2012, 10:10 AM
CNY_Dave is offline
Joined Sep 2010
One is an Infinite 3025 (or is it a 4025?)-770, infinite being out of business, the other is a turnigy 5055-580 for which I better never break the bolt-on (rotor-side) prop adapter.
Old Nov 19, 2012, 07:02 PM
Shut up and Fly!!!
Joined Aug 2011
Look at the bottom of the page. You can get replacement prop adapters for the 5055 here: http://milehighrc.com/brushlessC5055-8.html
I have a Turnigy and they are compatible.
Old Nov 20, 2012, 11:23 AM
CNY_Dave is offline
Joined Sep 2010
Oh man, put one in the cart, went to check out, item is sold out/unavailable.
You don't happen to know what size bearings the turnigy takes, do you?
Old Nov 20, 2012, 10:39 PM
Shut up and Fly!!!
Joined Aug 2011
When I get a chance I'll try to measure mine and let you know.
Old Nov 29, 2012, 08:10 PM
Shut up and Fly!!!
Joined Aug 2011
Sorry it has taken so long to get back to you but the bearing size is 8mm inside dia and 12mm outside dia.
Old Nov 30, 2012, 08:14 AM
CNY_Dave is offline
Joined Sep 2010
That matches for the front bearing, was the rear the same?
Someone elsewhere posted this info, that the 5055-380KV bearings fit:
ID 8mm x OD 12mm x Width 3.5mm Dimensions
2 Front
ID 8mm x OD 16mm x Width 5mm Dimensions
1 Rear
Old Nov 30, 2012, 08:45 AM
Shut up and Fly!!!
Joined Aug 2011
2 Front
1 Rear
The specs you have here are in fact correct sir. Go with ceramics and you will see the difference in amp draw. More efficient. That's what I had in mine.
Old Nov 30, 2012, 08:57 AM
CNY_Dave is offline
Joined Sep 2010
Sweet, I think the rotor-end adapter match has been found, and now the bearings.
Early christmas!
Old Nov 30, 2012, 09:36 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Should you break another prop adapter you might want to consider fitting a longer shaft and a collet type adapter. Just abandon the more proprietary/only fits one brand bolt on prop adapters. Both types are pretty easily easily bent and broken but the collet type are much easier to find and more universal in use.
Jack
jackerbes is offline Find More Posts by jackerbes
Sold GForce G40 700 kV Brushless Outrunner Thumbolino Aircraft - Electric - Power Systems (FS/W) 2 Feb 11, 2012 08:42 PM
Discussion It says Infared on the page, but I think its wrong, what do you think? Trainz222 Micro Helis 2 Dec 23, 2011 07:53 PM
Alert Champ for Sale - Cheap as Chris says :) rpstar Atlanta Area RC 8 Aug 07, 2011 02:17 PM
Discussion GWS Islander as VTOL,only a dream right now but soon! MustangAce17 VTOLs 133 Aug 03, 2009 05:15 PM
Discussion Discussion - GWS Islander as VTOL,only a dream right now but soon! MustangAce17 Foamies (Kits) 0 Jan 29, 2006 08:29 PM
