Old Mar 19, 2012, 10:38 PM
payne9999 is offline
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
payne9999 is offline Find More Posts by payne9999
Old Apr 17, 2012, 11:40 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Finally got back on the project. Needed to get a new roof started on the house and work went into high pressure mode. Anyway tonight I finally figured out a way to connect the cowlings that is easily removed so I spent some time mounting them and spacing the motors correctly to clear the cowls.
I am anxious to get back into it so I can finish and do the maiden.
Dave
Old Apr 26, 2012, 09:33 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Hit sort of a flat spot where I was not motivated to work on the DC-6. Back on it now and anxious to maiden it. built and installed the tail assemblies and red beacon on the fin. I need to figure out the rudder, elevator and steering servos and pushrods next.
This build has been a bigger effort than I expected.
Dave
Old May 02, 2012, 05:51 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
This plane is going to have nice visibility with the additional size. I have trouble with orientation on smaller models and I am looking forward to this one and being able to see it better.
Working on the retractable nose gear installation. Here is a comparison photo with the original 60" model next to it:
Old May 02, 2012, 01:45 PM
Robert R is offline
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Dave,
Your fuselage is a beautiful, orderly forest of sticks. Nothing looks better. Really.
Re visibility: Silver-Gray plane in the Pacific Northwest sky. I feel your pain. My sport plane high visibility markings are as close to black as possible on the bottom and as close to white as possible on the top. Unfortunately, that thought doesn't help a bit when your scale subject color is a variant of Washington/Oregon sky gray. I make gray planes too. Ah, the price of beauty.
Best,
Robert R
Robert R is offline Find More Posts by Robert R
Latest blog entry: Mustang Sally Sea Trials
Old May 02, 2012, 03:31 PM
4stroker is offline
Find More Posts by 4stroker
Closed Account
Joined Dec 2004
Dave
How did you get those beautiful filets between the Nacelles and wing ? I stand in awe of them !
4stroker is offline Find More Posts by 4stroker
Old May 02, 2012, 07:30 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Originally Posted by Robert R View Post
Dave,
Best,
Robert R
Robert,
Thanks, Pat Tritle ( the original designer of the plane) calls it 500 lineal feet of balsa in formation.
Yep, the Sky gray thing is an issue but at least with this size plane it is a little easier. I also added srobes on the wingtips, red and green position markers, landing lights and a red tail beacon. I have two other models with this marking system and on a gray day it really helps.
Dave
Old May 02, 2012, 07:39 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
4 Stroker,
The fillets are no big deal, kinda came to be by accident. The plans come with fillet patterns that you would make from paper that is painted silver. I tried it that way and couldn't make it work. So, I decided to make a compromise and just cover the nacelles and the wing panels and have no fillets. So, I covered the nacelles first and really sealed the edges and wrapped the ParkLite around the edges of the stringers. Then I cut a "U" shaped piece that would fit around the nacelles and cover the adjacent wing panels. I sealed those down extra good as well to the nacelle covering that was already there. Then when I hit it with the hot air gun the magic just happened and the covering where the nacelles join the wings pulled up and away from the framing but remained bonded to each other and formed these awesome little fillets that are very consistent but totally by accident. I believe this would work with any plane with nacelles. If you go too crazy with the heat they will eventually pull apart.
Anyway, once in a while dumb luck strikes. Not as often as "Murphy" though.
Dave
Old May 02, 2012, 08:17 PM
4stroker is offline
Closed Account
Joined Dec 2004
4 Stroker,
Dave
Thanks much Dave . I have an Acme 48" Beech D18 that I will try that on . I couldn't think of anyway to make the fillets look good and still be light (no green putty !) Walt
Old May 02, 2012, 11:08 PM
Herman Munster is offline
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
In saving weight, don't use the green putty, instead use Light weight spackle.
Herman Munster is offline Find More Posts by Herman Munster
Old May 04, 2012, 07:03 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Installed and tested the nose retract and steering servo. I need to figure out a way to put in some sheeting to form the opening. I am getting close to being ready to cover the fuselage and the balance the airplane to determine where the battery bay will need to be.
Old May 04, 2012, 03:13 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Rough carving the paulownia wood nose block. I hate trying to get all the curves just right but it usually comes out nice in the end....
Old May 06, 2012, 11:09 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Well, made some decent progress:
-Completed the tail linkages and tested them
-Installed a fairing around the nose gear opening
-Completed the nose cone
-Completed the pink foam fill over the cockpit
-Added servo extensions for nose gear retract and nose steering servo
-Tested the receiver and all control surfaces.
I suppose it is time to do some final sanding and cover the fuselage.
Old May 06, 2012, 12:10 PM
Parkk is online now
Find More Posts by Parkk
Parkk's Avatar
Near Austin, TX
Joined Dec 2008
Very Cool !
Parkk is online now Find More Posts by Parkk
Old May 06, 2012, 05:56 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Made the cowling that goes in front of and under the windshield and started the windshield patterns.
This piece and the nose will be flat black
Discussion The 60" DC-6B is Finaly Underway!!! P. Tritle Scale Kit/Scratch Built 556 Nov 20, 2013 10:43 AM
Contest Funbuild 5 DC-6B (C-118) Pats Custom kit payne9999 Scale Kit/Scratch Built 25 Feb 03, 2012 08:08 AM
Discussion Tritle DC-6B (C-118) payne9999 Scale Kit/Scratch Built 9 Jan 02, 2012 02:13 PM
Build Log 26.8in Paperplan DC-6B Durobatics build for PZ/Kyosho brick meatbomber Scratchbuilt Indoor and Micro Models 38 Nov 15, 2008 08:06 AM
Build Log Douglas DC-6B Project, UAL, 60" Wingspan ZRS4 Scale Kit/Scratch Built 46 Feb 10, 2008 11:40 AM
