Old Mar 13, 2012, 10:49 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Originally Posted by NJSwede View Post
Very poorly.
I'll just buy two 2450:s and see if they feel any different from my 3000:s... If they're far superior, I'll just buy more...
NJS- It all depends on you motor setup weight and so forth.
I don't think 3000mA will make this plane too heavy and may also make your CG arrival a bit easier.
I have the Motrofly 2820-750 and 40C4s2200 lipo and have my lipo pushed a long way forward to get the right CG.
As always, the lighter the better but if you have the Watts to play with and light a bit of heft I'm sure this plane could handle it.
Losi could 3D his 3dhs 51" slick with 4000mA lipo quite fine in his culdesac no less. Better pilot than me for sure but showed it was possible.
bigroger is offline Find More Posts by bigroger
Old Mar 13, 2012, 11:10 PM
NJSwede is offline
Find More Posts by NJSwede
3D Wannabe
NJSwede's Avatar
United States, NJ, Mendham Township
Joined Jul 2011
I'll be running one of the motors I have on my bench. Either a Turnigy SK3 3548 700kv (665W) or a NTM PropDrive 3548 840kv (815W). Both motors easily haul my much heavier MoneyShot vertical without breaking a sweat, so from a T:W perspective I'm probably fine. Time will tell. I'll probably pick up some lighter batteries just to see what they feel like. Maybe they will make my flying less crappy.
NJSwede is offline Find More Posts by NJSwede
Old Mar 14, 2012, 12:51 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by QUEBRANTAHUESOS View Post
Well guys always my doubts, you know I have this engine sitting around here for a while and now I wonder if it would be possible to install it directly to the motor box of this bird?, I mean without any fixing, thanks for the comments.
TGY AerodriveXp SK Series 42-40 750Kv / 600W
Model: SK42-40 750
That's similar to the motor that Michael used in his video, so it should work well in this plane. The only modification was due to the bolt holes on the cross mount being set wider apart than those pre-drilled in the plywood motor mount plate. Michael's builder added a stiffener plate behind the mount plate and re-drilled new holes.. there is a photo in the thread somewhere.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Mar 14, 2012, 06:13 AM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
A heavier setup is preferable for some as it gives more kinetic energy. It's really personal preference. I would say a light 3000 would be fine but a boat anchor not so much. Batteries art quite a bit in mah/wt ratio.
bildo baggins is offline Find More Posts by bildo baggins
Old Mar 14, 2012, 06:15 AM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Originally Posted by erkq View Post
+1 I use these in my AJ Slick 51 and love them! They can be had for less than $30 and charge at 5C though that's getting to be less unusual these days. Perfect for this size bird.
I need some bats myself. May look into'em
Old Mar 14, 2012, 06:21 AM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Speed gives you kinetic energy
Weight will hamper speed/kinetic energy and increases time to change energy states, will increase velocity vector slowing ability to turn in smaller air space...
I may be wrong on this though
Space Bat is offline Find More Posts by Space Bat
Old Mar 14, 2012, 06:31 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
JPF
How's your build coming on? any updated pics?
chop stiX is offline Find More Posts by chop stiX
Old Mar 14, 2012, 06:52 AM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
http://www.csgnetwork.com/kineticenergycalc.html
Old Mar 14, 2012, 06:54 AM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Increase in mass increases kinetic
On down lines fo sure and given same speed of course
Old Mar 14, 2012, 07:11 AM
Team Hillbilly (UK)
Space Bat's Avatar
Joined Oct 2011
I will concede for the sake of the thread not going off topic
However if you would like to discuss - further I am happy to explain why you can't truly equate mass times speed as kinetic energy as there is so many factors when using the physics in flight vehicles....out of the thread
Old Mar 14, 2012, 07:30 AM
Aberdeen
Joined Mar 2006
Originally Posted by chop stiX View Post
JPF
Thanks for the interest.. It's coming along slowly as i dont get much time during the week for building. I have thoroughly CA'ed all the joints around the motor box and landing gear and I've glued in the horizaontal stabiliser. Not much to take a photo of to be honest unless you are interested in a particular detail.
I've ordered up some ball joints and 2mm threaded solder connectors. Plan is to use the connectors and ball joints on the end of carbon rod pushrods. I'll see how this shapes up once i get to that part of the assembly. I'll see if i can get the surfaces hinged and servos installed tonight. The rudder servo I'll leave out of the tail until I'm sure the CG is looking ok. I've got Friday off so should be able to get it finished then.
I also need to swap out the motor bearings as one was a bit noisy when i was bench testing. It must have got damaged when I crashed the last model in which the Scorpion was installed.
Steve
Old Mar 14, 2012, 07:32 AM
NJSwede is offline
3D Wannabe
NJSwede's Avatar
Joined Jul 2011
Hrmmm... You mean mass times speed squared divided by two, right? But let's try to stay on topic. It would be nice if HK could just ship my plane soon!
Old Mar 14, 2012, 07:36 AM
Aberdeen
Joined Mar 2006
Pontius,
It took them a week to ship my Slick which was frustrating at the time but instantly forgotten once it arrives. So what colour did you go for?
Steve
Old Mar 14, 2012, 07:43 AM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
I think inertia is what really needs to be referenced with the increased mass of bigger battery rather than kinetic energy.
Tumbles, spins, snaps will all look and feel better with a bit of mass behind them. Ever wonder why ultra light foamies are ordinary at tumbles? Its the inertial of the airframe.
Old Mar 14, 2012, 07:46 AM
NJSwede is offline
3D Wannabe
NJSwede's Avatar
Joined Jul 2011
Originally Posted by JetPlaneFlyer View Post
Pontius,
Steve
I went for the orange one. Thought it looked better.
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 539 Mar 29, 2016 03:15 PM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 01:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 11:14 AM
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1560 Oct 24, 2014 11:58 PM
