Old Mar 12, 2012, 08:08 AM
mtwargo is offline
Find More Posts by mtwargo
PA Team Pilot
mtwargo's Avatar
United States, FL, Orlando
Joined Oct 2008
Originally Posted by dead View Post
Micheal, you starting a thread on that Edge?
Already exists... They've had the plane for a while, just no good videos
http://www.rcgroups.com/forums/showt...5#post21005620
mtwargo is offline Find More Posts by mtwargo
Old Mar 12, 2012, 08:55 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
the Slick is in my hands
I picked it up from the courier's depot an hour ago. First impression is that it was worth the wait. Build quality and finish is first class, I cant fault anything. OK, it doesnt have the extensive carbon and composite materials that are used in some brands but it's none the worse for that, the structure looks well designed and genuinly exceptionally well built. Hobbyking have really improved beyond recognicion compared to the previous model I had from them. Even the build manual (a joke in most HK products) looks acceptable, it's nothing like the detail that you find in PA or EF manuals but fine for someone who has a few models under their belts.
The landing gear area seems to be well thought out but could do with some CA running into the joints as some look quite dry ( a recommendation whatever the brand of plane).
More to follow...
Steve
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Mar 12, 2012, 09:09 AM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Gigity!
bildo baggins is offline Find More Posts by bildo baggins
Old Mar 12, 2012, 10:31 AM
NJSwede is online now
Find More Posts by NJSwede
3D Wannabe
NJSwede's Avatar
United States, NJ, Mendham Township
Joined Jul 2011
Steve
Darn it! Now I won't get any work done for 2-3 weeks as I will be busy reloading the EMS tracking page...
Really looks like HK hit a home run on this one.
NJSwede is online now Find More Posts by NJSwede
Old Mar 12, 2012, 10:52 AM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Congrats steve - hows the build going?....wind is looking good this week, shame its so dark and gloomy..its like staring at a lump of coal in a coal seller out there So hopefully you will get to maiden it this week when some blue stuff shows up
Space Bat is offline Find More Posts by Space Bat
Old Mar 12, 2012, 11:30 AM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
The cut out for the horizontal stabilizer on mine is not "quite" in the same shape as the curvature of the stabilizer, unlike my PA and EF. There are gaps both top and bottom near the front after the stabilizer is all the way in and snug in the middle. I'm going to add balsa and then sand down to shape as I would hate to use thick CA to cover the gaps.
chopper62 is offline Find More Posts by chopper62
Old Mar 12, 2012, 02:23 PM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Hey guys.i just saw an interesting comment on the website
"This plane is awesome. I bought it as a replacement for my 3DHS 51" slick that I recently crashed.
The 3DHS slick was a superb flying plane and judging from the 8 flights I've had with this one it's every bit as good, well done HK!
Build quality is as good as any I've seen.
I'm using a KDA 36-12XL 770Kv motor, turnigy dlux 70A ESC, nanotec 3000maH 25C, APC 15x7, castle 10A BEC, TGY-375DMG servos (TGY-2216MG servos would be better). Servo holes are approx 24x12.5mm. AUW is 1650g, about 100g lighter than the 3DHS slick using the same setup.
Hovers easily at half throttle, flight times are 8-10mins.
Flight characteristics seem very similar to the 3DHS slick, very stable harrier, very easy to hover, good flat spins. Wingtip spins are excellent, they're easier to initiate than with the 3DHS slick and the spin rate is higher.
Recommended CG was perfect at 99mm."
need we say more about this beast?opened her for the 1st time last week and all that went through my mind was WOW!!!!!6s 3d here i come
chop stiX is offline Find More Posts by chop stiX
Old Mar 12, 2012, 03:13 PM
Aberdeen
Joined Mar 2006
That's odd because I just dry fitted mine and it's spot on, better than the EF Edge EXP I built a few months ago. As the openings are laser cut I'd have expected them to be consistent.
Old Mar 12, 2012, 04:21 PM
Joined Apr 2008
The front of the stabilizer is abutted against the fuse ... can't go further. I looked at it against and the second choice is to carve out part of the fuse. I'd preferred the first choice by adding balsa then sand it to fit.
Old Mar 12, 2012, 04:49 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Is it a $120 outa shape
Old Mar 12, 2012, 04:58 PM
Joined Apr 2008
No!
Old Mar 12, 2012, 05:12 PM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Hey Bildo... Do you have to use that crazy clown in your Avatar? You are really scaring the kids
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Mar 12, 2012, 06:29 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
What ever do you mean
Self portrait
Old Mar 12, 2012, 06:37 PM
moxjett is offline
Find More Posts by moxjett
Pug Pilot
moxjett's Avatar
Wichita, Kansas
Joined Dec 2004
People are using HS 65's??? That could not possibly be enough except MAYBE on the ailerons, MAYBE...
Long Leng, You gonna get another one?
I've been flying mine on HS-65MG's Dead, and they've been doing fine. I do need to add these though to get some more throw, especially for the elevator.
moxjett is offline Find More Posts by moxjett
Old Mar 12, 2012, 06:55 PM
moxjett is offline
Pug Pilot
moxjett's Avatar
Wichita, Kansas
Joined Dec 2004
Lame flying I know, but it takes me longer then the average joe to get comfortable with a plane. I also need to either replace the elevator servo with a HS-85MG for get more throw out of the HS-65MG.
HK Slick (5 min 13 sec)
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 534 Oct 10, 2015 06:49 PM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1375 Sep 25, 2015 03:38 PM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 02:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 12:14 PM
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1560 Oct 25, 2014 12:58 AM
