Old Mar 09, 2012, 01:36 PM
NJSwede is offline
Find More Posts by NJSwede
3D Wannabe
NJSwede's Avatar
United States, NJ, Mendham Township
Joined Jul 2011
Originally Posted by ryanotown22 View Post
wait its a 3 1/2 minute flight the suprise is that it crashed and didn't go 5 minutes.
If it breaks up in the air I want to know. I'm about to pull the trigger on a 3DHS AJ Slick 51", but if this is as awesome as it sounds, I may reconsider...
NJSwede is offline Find More Posts by NJSwede
Old Mar 09, 2012, 01:46 PM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
This plane already has MTwargo and a few others who have put it through fairly rigorous paces. It's up to snuff.
creapyd is offline Find More Posts by creapyd
Old Mar 09, 2012, 03:00 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Still no sign of my Slick being released from customs but I am making progress with the build despite not having the actual plane. I completed by re-wind of my Scorpion SII-3020/1110kv and the new kv at third time of asking came out just where I wanted at 750kv. It pulls 880W at 59A on a Xoar 14x7, I think this should be just about ideal for the Slick.
Test run on the motor highlighted a noisy bearing which must have been damaged when the last plane that the motor was installed in crashed, so I'll need to change the bearings out.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Mar 09, 2012, 06:43 PM
YellowJacketsRC is online now
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Jet, that sounds awesome! 880 watts on a 166 gram motor? Wow that will be a rocket!
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
Old Mar 09, 2012, 06:49 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
RC Pilot / Photographer
-= GYRO =-'s Avatar
Joined Nov 2010
I get that out of my SunnySky 2820-950 with either a 13x6 or 12x7 on 4s.
My SunnySky 2820-800 kicks out 810w on a 14x7 on 4s.
They both weight the same at 140g (not including x-mount or adapter)
Check them out: http://epbuddy.com/index.php?main_pa...roducts_id=188
-= GYRO =- is offline Find More Posts by -= GYRO =-
Old Mar 09, 2012, 07:04 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Gary, those are nice looking motors.
Can you really run the 2820-800 on 4s with 14x7 prop? Seems the amps would be very high? What amp rating can these motors take?
bigroger is offline Find More Posts by bigroger
Old Mar 09, 2012, 07:06 PM
-= GYRO =-'s Avatar
Joined Nov 2010
I've only ground tested the 14x7, but it was 52amps, and I've been flying the -950 around at 58a no problem. They don't publish a max amp rating, but I've found that these motors definitely need some cooling air over them when operating in the 50-60a range. The highest temps I've seen in-flight so far are 115F.
Old Mar 09, 2012, 09:25 PM
3Dplank is online now
Find More Posts by 3Dplank
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
Is there any other videos of this plane in action?
3Dplank is online now Find More Posts by 3Dplank
Old Mar 09, 2012, 09:47 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Thanks Gary.
They do look like really good value motors.
810W on 4s 14x7 seems OK, I wonder how much of that is heat loss versus actual prop watts?
Old Mar 10, 2012, 01:48 AM
bonner is offline
Find More Posts by bonner
Tree Trimmer
bonner's Avatar
alex va.
Joined Oct 2008
Originally Posted by JetPlaneFlyer View Post
This is good news!.. Strange though how we seem to be getting totally inconsistent information from those who have the Slick.. Long leng for instance fitted a 52mm long Hacker motor and took photos (posted earlier in the thread) of the prop adapter sticking out by at least 10mm and the cowl as far forward as it could go. Now your 49mm long motor reportedly fits fine with 2mm of cowl to spare?.. how can this be? I wonder if the design has been changed in later delivery versions?.. Seems unlikely but there has to be some explanation.
You didn't by any change use a spinner that extends back behind the rear on the prop did you?.. Some spinner designs do this.
If UK customs ever release my Slick i will be able to see for myself, this is the fifth day they have been sitting on it
I'll take some pictures tomorrow ( Sunday) and post them. I just used the prop adapter that came with the motor and everything fits fine. A friend of mine did the assembly of mine and his.We are using exactly the same setup on both planes. SK3-3548-840 Turnigy Aerodrive SK3 - 3548-840kv Brushless 1 Reserved
TSB60A Turnigy Super Brain 60A Brushless ESC 1 Reserved
TGY-2216MG Turnigy Digital high torque bearing servo 16 4 Reserved
CFSA-001 Carbon Fiber Servo Arm Extensions (5pc) 1 Reserved
T-USBLink Turnigy USB Linker for AquaStar/Super Brain 1 Reserved
OR23-602x10 Ball and roller link 4.8x3x17mm (10pcs/bag) 1 Reserved
AM2003-15x5 Twisted 15CM Servo Lead Extention (Futaba) 2 1 Reserved
ORS-WS-M2x12 Self Tapping Screws w/shoulder M2x12 (10pcs/ 2 Reserved
HLFT-01 Polyester Velcro Peel-n-stick adhesive side 1 Reserved
AM2003-60x5 Twisted 60CM Servo Lead Extention (Futaba) 2 1 Reserved
bonner is offline Find More Posts by bonner
Old Mar 10, 2012, 03:29 AM
Aberdeen
Joined Mar 2006
thanks, yeah I'm very happy with the way the motor is performing considering this is the first motor I've ever hand wound. I had three goes to get the kv I wanted, first effort i messed up and got 415kv.. then I was very close and got 810kv.. third time lucky I got the exact 750kv I was looking for. Each time I've wound it I got better at it so taking three goes to get it right ins't such a bad thing. motor winding has a certain therapeutic quality to it anyway.
I could have just went with the 810kv but I think the 750 winding will be safer. The object of good winding is to cram as much copper in as possible and I must have done ok because the motor weight has gone up to 175g which must mean I got a bit more copper in there than the factory winding. Weight is not really an issue as it seems that the Slick needs a motor of at least 170g up front to balance.. I'd much rather have weight in the nose in the form of copper making the motor more powerful and efficient rather than lead.
Steve
PS.. The Slick is still in customs. According to Parcel Force 5 days in not unusual but they said if it's not out by Monday (which it looks like it wont be now) then they will start an investigation to see what's happened to it..... I have visions of a endless warehouse stacked to the ceiling, like the closing scene of Raiders of the Lost Ark
Old Mar 10, 2012, 08:34 AM
They Call him Dead!
Joined Jul 2003
Thanks Gary.
The stats on that motor show 13 x 6 being the largest suggested prop on 4s. It states 881 watts at 60 amps.
So the lower watts with higher amps on a 14 x 7 suggests to me that you are over propping. The other interesting thing is that you are ONLY getting 52 amps on 13 x 7. Based on the charts with a 13 x 6 at 50 amps, I would expect the 14" to push much more watts.
Gary, what lipo are you using and how new is it? Also, what is your elevation?
Old Mar 10, 2012, 08:45 AM
-= GYRO =-'s Avatar
Joined Nov 2010
I'm at 2700ft MSL. And for the motor, it sounds like you're quoting the numbers for the -950 motor, which is exactly what I'm getting with the 13x6. I put the 14x7 on the -800 motor, and the manufacturer didn't provide any test data with that prop on 4s.
Old Mar 10, 2012, 10:04 AM
Aberdeen
Joined Mar 2006
Good news on my Slick, it's been processed by customs and will be released for delivery on Monday, so should arrive with me on Tuesday. There has been duty charges made but not as much as I feared
Steve
Old Mar 10, 2012, 10:26 AM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Steve
Excellent news - you pre-pay ?? I guess the sales manifest with the declare down has assisted here.....
You win some you lose some with customs having said that had no issues with orders from HK - had more hassle with stuff from the US....
My time will come am sure....for china imports
Space Bat is offline Find More Posts by Space Bat
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1561 Aug 26, 2016 01:45 PM
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 540 Aug 16, 2016 01:18 AM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 01:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 11:14 AM
