JPF: that distance from the motor mount plate to the cowl you are looking for is 48-49mm.
Thats allowing a 1-2mm overlap at the back of the cowl for the canopy to clip under. |
Latest blog entry: full scale
Of the motors I listed in post #17 not one of the 3s motors are short enough. For 4s motors only the following will fit without a huge spinner gap: NTM Prop Drive Series 42-38 750kv Turnigy L3020B-600 (a bit low on the kv though) Of non Hobbyking motors the choice is also very limited, the EF torque 2814T/820 will fit and the Omega 130 will also go in, but both are a bit on the small side for this model IMHO.. Probably the best option would be the Motrolfly DM2820 series. I cant help but think that Hobbyking have slipped up pretty badly in making the motor mounting design that is unsuitable for 90% of the motors on the market that are powerful enough to fly the model in the manner intended. Most of their own motors don't fit properly, including all the motors that Hobbyking list as being compatible and the actual motor used in the flight video Of course if you don't object to a big ugly spinner/cowl gap then it's not an issue ![]() Steve |
zürich
Joined Jun 2008
how do you like the rest of the kit? |
zürich
Joined Jun 2008
your list of the motors is good. think i would take the motorfly too. havent finished the build, will do it tomorrow and if weather is flyable i ll fly it as well |
I'm still seriously thinking of getting one but shortening the motor box to take a Scorpion S3020 that i have spare.. I'd need to take 12mm (1/2") off the box. Steve |
Guys, I plane to mount the Motrofly 2820-750 in mine.
Initial fit looks great with no more than 2mm gap to the spinner. Mind you this is not a 3548 size but should have more than enough power on 14x7 Vox with 60A esc on 4s. Long leng.... the quality so far looks as good as any of the other two EF or 3dhs to be honest. I would have liked to have some carbon or G10 in the landing gear mount area to stiffen things a little, but doesn't really matter. I've added some carbon strips (0.5 x 3mm) to those areas to add some stiffness to the formers plus a couple of 2mm carbon rids a bit further back to run across the fuse like the EF planes get. I did also notice that the canopy has little G10 type tabs at the aft corners like the EF planes do for protection from dropping, nice little touch. Just finishing up CA flooding to the formers, and motor box areas before I begin bolting it together. I am gonna run a HS85MG in the elevator, so I have a bit of wood work to do next to open up that hole area. |
zürich
Joined Jun 2008
any pics about the reenforcements? what servo do you use for rudder? take care, if its too deep, it will come out of the other side of the fuse |
OK, added some photos.
I've added comments to the photos. So far 4 carbon strips added and the 1 2mm rod across the fuse.
Looks nice Roger. I would suggest adding some vertical supports from the the top of the aft side of the LG plate up to the battery tray, as that will be the area that will want to twist up on hard impact...
Oh, Also, it looks like there is a LOT of daylight in the fuse walls where the wings attach? Am I seeing correctly? That looks very fragile if I am seeing correctly? |
Like the addition to the landing gear mounting plate supports. Should have done that to my first balsa edge 540. Bought that from oz company dolphinco. Same one that was sold in the US and UK under the cermark and overlander brands at one stage. Had many landings with it left stock for a long time (including some hard bounces). It finally gave up on me 2 weeks ago after a light landing. Damage is fixable but the hassle of fixing it is the thing. The moral of the story for me is that I should beef up that area if planning on playing around with an untested/unfamiliar brand.
Dead,
yes well spotted there is a lot of daylight in the wing attachment area. It is designed like that, the wings insert into the fuse and butt up against a ply insert that runs the full length of the wing attachment area. Really does look and feel strong. Other makers, 3dhs, PA and EF butt attach the wings and rely on the thumb screw and anti rotation pins to hold the wings in place. These wings fit very snuggly inside the hollowed out area and up against the ply section of the fuse. There really is a lot of ply in this fuse. Dean was right previously when he stated they were very solid. My little beef up carbon inserts were just in case, so far there is no fuse flex during assembly. My EF edge on the other hand by this stage I had cracked the fuse balsa half a dozen times putting everything in. The landing gear area has double ply formers in front and back and plenty of support. I'll add a couple of extra carbon strips in the vertical runs for support in that direction. Probably not a big issue whilst I run the Al legs. Carbon legs will mean extra support required to take the shocks. |
| Thread Tools | |
| Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread | Tom K. | 3D Foamies | 1256 | May 17, 2013 07:42 PM |
| New Product HK DuraFly Micro Slick 360 2S - Official Thread | will3d4food | Indoor and Micro Models | 865 | May 10, 2013 04:11 AM |
| Discussion Official Hobbyking 720p HD Camera Thread | jaskel | Video Piloting (FPV/RPV) | 409 | Apr 29, 2013 12:22 PM |
| Build Log The Official Raven 3M build thread has begun. | Windependence | Sailplane Talk | 1481 | Apr 15, 2013 08:15 PM |
| New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread | will3d4food | 3D Flying | 1909 | Jun 21, 2012 02:03 PM |
