South East, MN
Joined Mar 2007
No, it's designed to mount the motor to the front of the firewall.
I've already got the answer from someone else: 1.875 inch == 47.6 MM. So a 48 mm motor will fit. The 3548 motors will fit. However an e-flite Power 25 for example is 55 mm long from firewall to back of prop adaper so it is 17 mm or .5 inch to long to fit inside the cowl of this Slick. Now, how about servo holes. what are their length and width in MM (just the holes not where the screws go in.) |
48mm is very tight, many of the motors i listed would be too long by the time you add a prop adapter. 48mm is in fact the exact same distance as the extreme flight 48" EXP series for which motor choice is also very limited. I'd be pretty sure that the 35-48 type motor wont fit as they are all about 48mm long before prop adapter or X-mount is added, they will be about 58mm once fully fitted out meaning a 10mm gap between spinner and cowl ![]() Interestingly if the 48mm figure is correct, the MTN motor used by Dean in the official build would not have fitted properly Looking again at the video i note that no spinner was fitted and i could see the prop adapter sticking out a bit, so this tends to back up the suggestion that the motor was too long.This is a very critical issue which will have a big impact on motor selection.. it would be good if someone could confirm the dimension. Dimension required = front of motor mount plate to front of cowl, with cowl installed in most forward position. Steve |
Australia, QLD, Hervey Bay
Joined Apr 2008
Costa Mesa, CA
Okay here is an unbiased opinion. It has been said many times in these forums there are only 4 or 5 builders worth buying from. A short list Hobbyking and Turnigy are NOT on. Some may think this plane is a good value. Price and value are usually two different things. R/C flying is NOT easy! It's easy to get frustrated when things are not going right. Why not get the best planes available and eliminate the plane from the equasion?
Steve |
United States, NV, Las Vegas
Joined Nov 2010
| Thread Tools | |
| New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread | will3d4food | 3D Flying | 1910 | Yesterday 11:49 AM |
| Build Log The Official Raven 3M build thread has begun. | Windependence | Sailplane Talk | 1482 | May 22, 2013 10:08 PM |
| Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread | Tom K. | 3D Foamies | 1256 | May 17, 2013 07:42 PM |
| New Product HK DuraFly Micro Slick 360 2S - Official Thread | will3d4food | Indoor and Micro Models | 865 | May 10, 2013 04:11 AM |
| Discussion Official Hobbyking 720p HD Camera Thread | jaskel | Video Piloting (FPV/RPV) | 409 | Apr 29, 2013 12:22 PM |
