United States, CA, Tustin
Joined Apr 2010
I am in for one HK 360 in blue trim.
![]() I need some help on what else I need to buy now, after hours of sifting through the thread I am thinking of getting: SERVOS: TGY-2216MG --being used for rudder/elev HK 929 MG --for ailerons. Motor: NTM 4238 750kv Spinner: Spinner 48mm diam 5mm shaft ESC Hobbyking 70amp OPTO ESC with 5 Amp External UBEC Battery: Turnigy nano tech 2200 mah 4S 25-50C Misc: 10mm black shrink tube Thin CA Battery Straps Self Tapping screws Futaba Connector Caps CF rod 2mmx750mm Ball and roller link Threaded Ends |
I would go with the 2219MGs all around. They're pretty good servos. I use mine in a EF Laser 48" and they're still going strong.
As for the ESC, I've had some bad experiences with the HK ones. I would go with a ZTW instead. You can get the ZTW 70A at Altitude Hobbies for $40 and that includes a built-in 4A SBEC. |
I used the Savox225s on this plane. I have the 2216s on another plane. I believe the 2216s are made by the same plant as the savox, but the 2216s are louder. I'm not impressed with either, but these were very small samples for a small number of flights. |
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
Joined Apr 2010
Yeah, sorry, that's what I meant.
LoneWolfRC is correct. They are pretty noisy. I think they perform reasonably well, though. That being said, I'm in the process of replacing all my "questionable" servos with HS65MGs and HS5085MGs. I guess my skills have progressed to the point where servos actually make a difference. |
There are two things that I would change on your list.
I'd use a 2" Dia. DU-BRO " spinner ( blue) Cat, No. 276 They are around $5.00 dollars, inexpensive and spin true. I would recommend a Gens ace battery 2700mAh 35c 4s. These batteries are excellent and also inexpensive. Just FYI; I also use the TGY-2216MG's all around. I have around 50 flights with no problems. I also would recommend using Du-Bro 2-56 swivel ball links(cat. No. 860) and some 2-56 all thread rod on both ends of all linkages. these are self tapping so, you could adjust both ends. Bill |
Turnigy lipo over nano-tech. I have both and while the nanos look good out of the blocks, my Turnigy's out perform the nanos and they are older. The nano's don't appear to have the longevity... The 70A opto is a little large too, I have the motor your considering and it pulls 50A at 750W with 14x7 APC. I used http://www.hobbyking.com/hobbyking/s...ontroller.html And http://www.hobbyking.com/hobbyking/s...Reduction.html Cheaper and lighter by 20gms (if your weight conscious) ![]() Good luck.... |
Maybe the ESC is slight overkill but that's not really a bad thing and gives you the option of propping up the motor if you want a bit more oomph (I'd be looking to pull 60A though that motor with a Xoar 14x7) Sounds like you are planning on doing carbon pushrods with threded adapters epoxied on, which is exactly how I did mine and they work perfectly. If you are a builder think about knocking up a new rudder as per the plan I posted a few pages back, it really makes a difference. ***EDIT*** One thing i would definitely change is the spinner and prop driver and motor cross mount. to mounto the prop rather than using the collet adapter built into that spinner it would be much better to get the bolt on prop driver that's in the NTM accessory pack: http://www.hobbyking.com/hobbyking/s...sory_Pack.html You also absolutely need a 35mm size cross mount (the 42mm size one wont fit the Slick): http://www.hobbyking.com/hobbyking/s...sory_Pack.html It's pretty easy to break cross mounts doe to hygroscopic forces in flight so get a spare or two and check them regularly) Then you will need a different spinner, Hobbyking is out of the ones you want: http://www.hobbyking.com/hobbyking/s...51mm_Blue.html , but the Du-Bro ones mentioned previously are perfect. |
Joined Mar 2012
I could recommend Zippo Compact 4S 2200 35C, I've got 100 cycles with 58A max discharge, if to compare with a nano that did not exceed 40 cycles
before die. And I'm not impressed with TGY-2216MG(HD-2216MG is the same), I have 8 of them and all got big slop after several flights.
Psssssh
I have have both Zippy Comacts and Nano' and others One thing I have learned is that the Zippys are a great battery for the cost - however poor assembly means that balance leads often fall off or the main OP wires....I would say that they do offer a good output against load for a significant period but do die a death quite sharply towards the end...as for cycling have put mine through 100 odd cycles now and still good... However Nano's are still better.... What I have found is that you can not get these nano's hot unlike Zippys they don't like it and will kill its performance over cycles...but say if you use 2200mAh and get 6 mins - I would recommend getting a 2650 and set the timer the same 6 mins...you will notice the batteries never get hot and even better offer full power till the timer - and no drop off... Zippys will do the same - but do not offer the same kind of power as the nano's One thing I have also noticed - am pretty sure that the Zippy's and Nano's are made in same factory and the cells are graded and packaged differently...I can hold a 2650 3s Zippy and a Nano together and they look exactly the same - size width and height....only difference is the packaging... |
Longview, Tx
Joined May 2008
Here's my Extra 360 with added on rudder. It definitely Harriers better but still not great. I think she's just a little too Porky at 38 ounces and 43" but it's still a blast to fly. Good thing I lurk around here a lot because there's a lot to be learned.
Joined Apr 2010
I already pulled the trigger on the parts I listed, I guess we will see what works and doesn't work in a couple of weeks. I did order both of the accesory packs for the NTM motor, I did not order batteries however, I plan on waiting for either the zippy compacts to be restocked in the us store or gens-ace on hobbypartz
You could also try Glacier or Revolectrix Lipos.
| Thread Tools | |
| Build Log The Official Raven 3M build thread has begun. | Windependence | Sailplane Talk | 1482 | Yesterday 10:08 PM |
| Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread | Tom K. | 3D Foamies | 1256 | May 17, 2013 07:42 PM |
| New Product HK DuraFly Micro Slick 360 2S - Official Thread | will3d4food | Indoor and Micro Models | 865 | May 10, 2013 04:11 AM |
| Discussion Official Hobbyking 720p HD Camera Thread | jaskel | Video Piloting (FPV/RPV) | 409 | Apr 29, 2013 12:22 PM |
| New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread | will3d4food | 3D Flying | 1909 | Jun 21, 2012 02:03 PM |
