Old Nov 21, 2012, 05:59 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Hi Christian.it's a guess by looking at it.Yes he did,but he mentioned himself that it's not 100% the same
Steve aka Jetplaneflier post a few pages back on the correct one.hope that helps
chop stiX is offline Find More Posts by chop stiX
Old Nov 21, 2012, 06:26 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by auer640 View Post
Hi Slick pilots,
I damaged the rudder in the last transport in my car. So I have to re-cover the rudder with Oracover film, but I'm not sure what color-code will fit.
In earlier posts I saw, that some people have made a bigger rudder for the Slick. They should now the right color.
3 films seem to fit:
Oracover OrangeOracover fluorescent Orange
or Oracover fluorescent signal Orange
Can anyone of you help me, as I don't have a hobbyshop nearby to check the right color.
br,
Christian
The film HK use on their Slick seem to be the exact same colours that 3DHS use on theirs.. on that basis the colours are:
  • UltraCote, Orange - HANU877
or
  • Oracover Orange 21-060
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Nov 21, 2012, 06:35 AM
auer640 is offline
Find More Posts by auer640
Austria, Tir., Innsbruck
Joined Sep 2012
Thanks guys,
I'll try Oracover Orange 21-060 for my repair.
br,
Christian
auer640 is offline Find More Posts by auer640
Old Nov 21, 2012, 01:12 PM
Starving Bushman is offline
Find More Posts by Starving Bushman
Starving Bushman's Avatar
United States, VA, Alexandria
Joined Nov 2011
Question for you guys. This is my first balsa plane so I'm real new to this. The question I have is where do I get the ball links I keep reading about? I was going to use the stock ones but the more I read about them failing the less I want to use them.
Starving Bushman is offline Find More Posts by Starving Bushman
Old Nov 21, 2012, 01:14 PM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
You'll need new ball links and push rods. The rods that come with the kit are too thin. Get the next size up and matching ball links that will fit on that rod. If you have a local hobby shop that would be best, I'm not sure off the top of my head what size it was that you would need. If someone has the size, you could order online as well. I used the Dubro ball links.
DaaBears is offline Find More Posts by DaaBears
Old Nov 21, 2012, 01:30 PM
Aberdeen
Joined Mar 2006
the way i did it:
M2 ball link: http://www.hobbyking.com/hobbyking/s...0pcs_set_.html
M2 thread adapter: http://www.hobbyking.com/hobbyking/s...0pcs_set_.html
Carbon rod: http://www.hobbyking.com/hobbyking/s...2_0x750mm.html
So you cut the carbon rod to length, sand down the ends a bit (or run a 2mm drill into the end of the thread adapter) so the rod is a snug fit and epoxy the rod into the thread adapter. Then just screw the ball link on and repeat at the other end of the pushrod.... And there you go, a fully adjustable carbon pushrod, super 'trick' and super easy.
You can get the same components at pretty much any decent hobby store. you can also use piano/music steel wire instead of the carbon rod and solder it into the thread adapters.
Old Nov 21, 2012, 01:31 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I am using the stock hardware. I do not recommend that you use the stock hardware, *BUT*** if you do, file flats with grooves on the rods where the ez connector mates, and make sure it doesn't slip. Use loc-tite.
As far as ball links, you could get them from hobby king. Check the size, but here is an example: ball and roller link
Here is another example.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Nov 21, 2012, 01:53 PM
Joined Nov 2011
Thanks guys!
Old Nov 22, 2012, 12:13 AM
bonner is offline
Find More Posts by bonner
Tree Trimmer
bonner's Avatar
alex va.
Joined Oct 2008
Thanks guys!
Hey John; I picked up some Du-Bro 2-56 swivel ball links(cat. No. 860) and some 2-56 all thread rod at Hobby Hanger in Chantilly.
Plenty strong for all the Slicks. Both ends are adjustable because, the ball links are self tapping. works very nicely! Bill
bonner is offline Find More Posts by bonner
Old Nov 22, 2012, 06:43 AM
Hoverin is offline
Find More Posts by Hoverin
3D apprentice
Hoverin's Avatar
Australia, WA, Mandurah
Joined Mar 2012
Originally Posted by Arcright View Post
Hi Guys
A short update to my woes, the new cowl turned up so that was good the weight of the model was down to 58oz which I think helped with the way itís flying. Unfortunately I managed to rip the under carriage off the only spare I had was from a extinct Eratix so what with the repair plus some blocks of ply to bring the recess out flush the weight is back up to just under 60oz.
Also one of my fellow flyers came up to me yesterday and jokingly said have I put the wings on the right way round, I gave him a puzzled stare and he pointed out the right hand wing has a flatter top profile compared to the left wing. I picked the model up and had look and he was right although the difference is subtle it looks almost as if someone and run a sanding block along the top of the outer third of the wing ribs.
Now I donít know if this would have any affect on the flying but would it be possible if this is whatís giving me some of the quirky behaviour.
Arcright
Hi Arc, did you completely destroy the old U/C? What do you mean by erratic flying? Have you had someone look over it for you? Is it a CG issue?
Hoverin is offline Find More Posts by Hoverin
Old Nov 22, 2012, 03:03 PM
Joined Nov 2011
Good info. Thanks Bill.
Old Nov 23, 2012, 03:19 PM
Wing-span is offline
Find More Posts by Wing-span
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
Good idea
Wing-span is offline Find More Posts by Wing-span
Old Nov 24, 2012, 02:19 AM
kinshas is offline
Find More Posts by kinshas
kinshas's Avatar
Philippines, Calabarzon, Calamba City
Joined Mar 2012
Originally Posted by chop stiX View Post
Ahhh damn sorry to hear repairable or completely toast?where's the vid?
Look at this!Name: DSC01174.jpg
Description: Crashed HK Slick
Two days of flights!
Description: two days of flights
So, as you see the left wing got large damage, I guess it does not make sense to repair, anyway I have another one and it's flying awesome!
kinshas is offline Find More Posts by kinshas
Old Nov 24, 2012, 04:18 AM
chop stiX's Avatar
Joined May 2011
Damn that's terrible.Sorry to hear.ouch expensive 2 days
Old Nov 24, 2012, 07:33 AM
Hoverin is offline
3D apprentice
Hoverin's Avatar
Joined Mar 2012
Originally Posted by kinshas View Post
Look at this!
Oh man, that's a lot of carnage. Sorry to see that mate... At least your still in the air with a spare....
Imagine the cost if these were big name brands
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 539 Mar 29, 2016 03:15 PM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 01:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 11:14 AM
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1560 Oct 24, 2014 11:58 PM
