Old Aug 09, 2012, 05:03 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by peter24 View Post
Could someone point me in the direction of some ball links suitable for this plane. As i want to change the supplied ones for carbon rod and ball links. Im not sure what size i need. Thanks.
I used 2mm threaded solder adapters and epoxied in 2mm carbon rod, sand the end of the rod down slightly or open up the solder socket with a 2mm drill, it's a rock solid joint. The ball links then screw onto the M2 threaded adapter.
M2 Threaded solder adapter: http://www.giantshark.co.uk/threaded...-p-403721.html
M2 ball link: http://www.giantshark.co.uk/ball-rol...-p-403726.html
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Aug 09, 2012, 05:29 PM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
I used these (with washers between everything)
http://www.hobbyking.com/hobbyking/s...idproduct=8231
http://www.hobbyking.com/hobbyking/s...dproduct=12308
http://www.hobbyking.com/hobbyking/s...dproduct=21187
http://www.hobbyking.com/hobbyking/s...idProduct=6969
I used steal threaded M2 rod for my pushrods. Epoxied one side and thread screwed the other. Very strong and still adjustable.
creapyd is offline Find More Posts by creapyd
Old Aug 10, 2012, 01:13 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Originally Posted by xzuberance View Post
Got fed up with the whole deal and took the fuse back from oz post. Fixed (more like patched) all of the damage save for the crumple and hole in the covering. Was gonna fix these issues when the EF local distributor here had a 1 day deal for the 48" edge. Bought that and am gonna use the stuff originally planned for the slick in it. Planning to sell off slick 'as is' for anyone interested, but I might end up building it if there are no takers. Kinda lost interest with the slick after all the fiasco I had with the posties and HK. Still have my skywing, 3dhs and PA birds to keep me occupied, so it doesn't really matter. Though if Steve has indeed for the 'cure' for the wing drop I might just build it and fly it like stole it
Oh Ok cool.I now remember you said screw it,your fed up with posties and HK regarding this.
Have you got the Skywing MXS?they are awsome planes.I got one aswell,though it needs some repair work.I must get my lazy ass into gear and fix it up.they are awsome huckers.
Peter I used 2mm CF rod and 2mm ball links from HK.the CF is epoxied into the ball link.and used M2 bolts with washers and 2 nut locking against eachother with some threadlock
chop stiX is offline Find More Posts by chop stiX
Old Aug 10, 2012, 01:14 AM
peter24 is offline
Find More Posts by peter24
kings lynn, norfolk uk
Joined Sep 2007
thanks for the replies guys,
peter24 is offline Find More Posts by peter24
Old Aug 10, 2012, 01:37 AM
chop stiX's Avatar
Joined May 2011
Here's what mine looks like.I have since put CF horn extensions on.
http://www.rcgroups.com/forums/attac...mentid=4912611
Old Aug 10, 2012, 05:16 AM
Aberdeen
Joined Mar 2006
Very nice....but get those bolts cut down
Old Aug 10, 2012, 07:03 AM
chop stiX's Avatar
Joined May 2011
I did now when I put the CF horn extensions on
Old Aug 10, 2012, 03:37 PM
Nukiwi is offline
Find More Posts by Nukiwi
Now, what does this button do?
Nukiwi's Avatar
Christchurch. NZ
Joined Dec 2009
Time for another pic then?
Nukiwi is offline Find More Posts by Nukiwi
Old Aug 11, 2012, 04:05 AM
chop stiX's Avatar
Joined May 2011
lol ok
Just so ya'll can see.I have about 75* on elevator now and ailerons 60* more or less
Old Aug 14, 2012, 01:05 AM
chop stiX's Avatar
Joined May 2011
Ok guys back to an ancient topic we discussed ages ago regarding air vents.I never posted what mine looked like so here it is
Old Aug 14, 2012, 02:45 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Should I build my FPV setup, or this plane, after I get my daughter's fun cub built?
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Aug 14, 2012, 02:55 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I'd go bigger than that. If you have a bigger egress than ingress for air, there will be negative pressure, and it will be less likely that your canopy will fall off. At least that is my understanding.
Old Aug 14, 2012, 08:42 AM
chop stiX's Avatar
Joined May 2011
If you have a canopy that works with magnets maybe so.but this is more than sufficient.I get good airflow.if my canopy comes off,that will mean the whole fuse will have to basically shatter in midair....so don't have the problem with pressure.
Steve can you maybe repost your vent for us.I do think you did when we discussed it at the timejust so we can compare
Old Aug 14, 2012, 08:43 AM
chop stiX's Avatar
Joined May 2011
Build this 1st
Old Aug 14, 2012, 09:14 AM
creapyd is offline
Prefectionist
Joined Mar 2007
I've got 40 flights on mine and I have ZERO air outlet. Same on my Money shot and E-flite Extra 300.
My motor get's hot, but that's more because I'm pushing it very hard. Nothing else is even warm.
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 534 Oct 10, 2015 06:49 PM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1375 Sep 25, 2015 03:38 PM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 02:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 12:14 PM
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1560 Oct 25, 2014 12:58 AM
