Espritmodel.com Heli Air
Old Aug 08, 2012, 10:43 AM
Burke, VA
Joined Sep 2009
Originally Posted by JetPlaneFlyer View Post
So I taped on a depron foam extension to the rudder to create more vertical stab area:
It sure isn't pretty..... Any bets on if it cured the wing rock? You have until the video uploads to make your predictions.
Steve
My guess is no, I've messed around with designing small flat wing foamies( I realize this may not relate to a balsa model with air foiled surfaces, but it's just my guess) and I found that extending the top of the rudder and therefore the height of the balance tab dosn't help wing rock. But if you extend the height of the vertical stab and keep or reduce the size of the balance tab it does seem to help wing rock. I like the experimentation on this plane, it's kind of brought this thread back to life although not quite as entertaining.
jetinteriorguy is online now Find More Posts by jetinteriorguy
Old Aug 08, 2012, 10:45 AM
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Three for 'no'.. video 50% uploaded.. any more opinions?.. Anyone for "yes it will be a complete cure"?
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Aug 08, 2012, 10:56 AM
Aberdeen
Joined Mar 2006
ok.. prepare to be amazed:
HK Slick 'A-rockin' or maybe not (2 min 22 sec)
Old Aug 08, 2012, 11:09 AM
Santi
DaaBears's Avatar
United States, TN, Nashville
Joined Nov 2003
Hard to tell there when you're just going around in circles. Can't really see a right wing drop when you're constantly turning left..
How did it feel?
DaaBears is offline Find More Posts by DaaBears
Old Aug 08, 2012, 11:10 AM
3D Wannabe
NJSwede's Avatar
United States, NJ, Mendham Township
Joined Jul 2011
Steve, you are a genius! And I frickin' really mean it!
Care to share the dimensions of the rudder extension, 'cause I'm going to cut some depron RIGHT NOW!
NJSwede is offline Find More Posts by NJSwede
Old Aug 08, 2012, 11:11 AM
United States, CA, Sebastopol
Joined Dec 2010
How did it feel?
He was turning left in the previous video too... the one where it was rockin' and rollin'
erkq is online now Find More Posts by erkq
3D Wannabe
NJSwede's Avatar
Joined Jul 2011
How did it feel?
He was flying the exact same circuit in the previous video and it was rockin' like I wouldn't come knockin'
Old Aug 08, 2012, 11:16 AM
Aberdeen
Joined Mar 2006
How did it feel?
I think if you compare the two videos the difference is night and day.. I did do one right hand circuit in the vid but for some strange reason I always feel more comfortable going left when harriering, not just with the slick, with all my planes.
the limitations of the flight envelope in the vid are due to me, not the model.
If 'felt' 100% better, maybe not quite as stable as the EF edge but not far off.
Old Aug 08, 2012, 11:21 AM
Santi
DaaBears's Avatar
Joined Nov 2003
It definitely looked much better than the first video. I think you probably have found a few, of an unknown number, of design flaws that contribute to the poor post stall handling... Props on the experiment! Don't you wish HK would have done these trials and addressed these issues before releasing this plane!
Old Aug 08, 2012, 11:22 AM
Burke, VA
Joined Sep 2009
Does this induce any unwanted coupling in KE flight? If not it seems you have made a silk purse from the proverbial sows ear. Nice job, now all you need is some balsa, strip the covering off, add the extension or build a new one and put some covering on and your good to go. The only problem is if you value your time off like I do I would rather be flying than fixing the problem. But if you like to fool with it and already have the plane then what the heck, looks like the results are well worth it. If I already had the plane I would do it.
Old Aug 08, 2012, 11:27 AM
Prefectionist
South East, MN
Joined Mar 2007
I wouldn't trust taped depron for knife edge.
But it does appear that an even larger rudder would definitly help the wing rock. Have there been any pictures comparing the HK rudder to the AJ Rudder?
creapyd is offline Find More Posts by creapyd
Old Aug 08, 2012, 11:28 AM
Aberdeen
Joined Mar 2006
ok.. it was 3mm depron, it extended roughly 75-80mm in height and maybe 35mm out the rear tapering to zero at the bottom of the rudder.. I've attached a better photo.
After the video flight I trimmed the foam down to something that looks a lot better, the idea being that once I find the smallest size that still works I'll build a new rudder. The size that I trimmed down to was 55mm high and 10mm at the rear. Unfortunately some wing rock came back but it was still a lot better, it's probably going to be a compromise between best stability and still looking reasonably ok.
If anyone else wants to experiment with different sized and shapes of extension that would be cool. the wind came up for me and it was pointless testing any more.
I'll upload a vid of the second flight with the trimmed down extension.
PS.. I taped a bit of 1.5mm carbon rod extending over the leading edge of the depron and over the leading edeg of the balance horn... this stiffened the foam up a bit.
Old Aug 08, 2012, 11:31 AM
Aberdeen
Joined Mar 2006
The extension was to flimsy to test in high speed flight but I didn't notice any undesirable effects other than looking butt ugly. In the ideal world I'd extend the fixed part of the vertical stab but that would be a lot of work.
Burke, VA
Joined Sep 2009
Yeah your most likely right on that. If the prop didn't blow it off it would at least deflect it enough to not get a true feeling for the effect.
Old Aug 08, 2012, 11:35 AM
Aberdeen
Joined Mar 2006
Very good point, and I guess stuff like this is the hidden work the the likes of 3DHS and EF have done to get their models to fly the way they do.
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1256 May 17, 2013 07:42 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Indoor and Micro Models 865 May 10, 2013 04:11 AM
Discussion Official Hobbyking 720p HD Camera Thread jaskel Video Piloting (FPV/RPV) 409 Apr 29, 2013 12:22 PM
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1481 Apr 15, 2013 08:15 PM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1909 Jun 21, 2012 02:03 PM
