Old Aug 08, 2012, 03:09 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by erkq View Post
I've been mostly lurking here. Looks like a nice plane. But I do have an AJ Slick 51 that doesn't rock like that for sure! Would a gyro on the ailerons be a cheap fix? The rocking is slow enough a gyro could easily keep up. I know it is usually considered cheating but this plane has potential and that rock looks like it could be damped out pretty easily.
Yeah, I tried a gyro, a full 3-axis job. It did pretty much prevent the rock but it couldn't catch it when the wing dropped, leading to my crash. I'm not seeing the drop now so maybe the gyro would do the job but I'm going to try to figure out the cause if i can rather than cover it up with a gyro.
As Chop Stix says; the gyro would also make certain manoeuvres impossible so it needs to be switchable, which is a bit of a pain.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Aug 08, 2012, 03:25 AM
Aberdeen
Joined Mar 2006
Originally Posted by NJSwede View Post
Wow! That was pretty impressive! However, the mystery remains: What's causing the wing rock???
While flying the Slick this last time and watching the video i got to thinking that the wing rock looks a bit like 'Dutch roll' The cure for Dutch roll is usually to make the vertical stab larger. The vertical stab/rudder on the HK Slick actually looks like it plenty big enough as it is, but maybe it's getting blanked by the fuselage/wing and horizontal stab when the plane is in high alpha?
So my next experiment will be to tape a foam extension onto the rudder to increase the area and see if that makes any difference. if it does it would be easy enough to build a larger rudder.
Old Aug 08, 2012, 07:11 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
I just had a weird thought, I wonder if a spoiler made of triangular stock on the LE of the right wing would help. This would be similiar to the ones used on some full sized planes. On full sized planes this helps with stalling and may do the same on an rc plane. I would give this a try but none of the planes I have exhibit these problems, they either are crashed and trashed or I just avoid buying them based on info gleaned from RCG.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Aug 08, 2012, 07:24 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
I think we have discussed that way back in the thread where Steve said he thought of that.but they won't really have any effect poststall.remember in 3d we want the wing to stall...especially in harrier so they won't help.those were made to delay stall on a plane,so will be quite irrelevant here.Well that's if I understand aerodynamics right
chop stiX is offline Find More Posts by chop stiX
Old Aug 08, 2012, 08:02 AM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Originally Posted by JetPlaneFlyer View Post
ok here's the video, all comments welcome other than "your flying sucks".. I've got feelings!
Have you tried harriers with a higher angle of attack? Get the nose up to 45-50 degrees instead of the lower ~30-40 it was at and what does it do?
Video made me dizzy by the way... I guess I'm too used to flying at organized fields and keeping the plane in front of me. It seems very strange to fly in a big circle with me in the center.
ryan_m is offline Find More Posts by ryan_m
Old Aug 08, 2012, 09:03 AM
Rohan_P is offline
Find More Posts by Rohan_P
Rohan_P's Avatar
Australia, SA
Joined Aug 2009
Does anyone have photos comparing the rib profiles of the HK slick and the 3DHS one? Or say comparing to an EF EXP airfoil?
How different are they really?
Maybe shots of the root and tip airfoils? Because someone said that the HK airfoil gets fatter towards the tips, no?
Rohan_P is offline Find More Posts by Rohan_P
Old Aug 08, 2012, 09:28 AM
Burke, VA
Joined Sep 2009
Oh yeah, now that you mention it I do recall something to that effect. But isn't the problem a tip stall, which is the main problem aside from wing rock? Maybe this would at least eliminate that disastrous characteristic even if it doesn't improve the 3D aspect of flying. That would still be an improvement worth exploring. If it didn't help it would be easy enough to remove the spoiler.
Old Aug 08, 2012, 10:11 AM
Aberdeen
Joined Mar 2006
Generally the higher the AoA the worse the rock.. it was at 45 deg and more in patches on the vid but it gets too unstable for comfort (for me)
Old Aug 08, 2012, 10:19 AM
NJSwede is offline
Find More Posts by NJSwede
3D Wannabe
NJSwede's Avatar
United States, NJ, Mendham Township
Joined Jul 2011
That's evidence against the problem being caused by partial stalling of the wing, since the higher the AoA, the higher the probability that the entire wing is stalled. Right?
I love a good mystery!
NJSwede is offline Find More Posts by NJSwede
Aberdeen
Joined Mar 2006
So I taped on a depron foam extension to the rudder to create more vertical stab area:
It sure isn't pretty..... Any bets on if it cured the wing rock? You have until the video uploads to make your predictions.
Steve
Old Aug 08, 2012, 10:21 AM
NJSwede is offline
3D Wannabe
NJSwede's Avatar
Joined Jul 2011
It's a "no" from me, Steve!
Old Aug 08, 2012, 10:25 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
hahahahahhahaha.NO!!!!!and Steve has found out the hard way that gyro only makes it worse and will surely cause a crash.think what that darn thing will want to do in KE spin or a blender or poptop.......I don't want to go into the whole gyro thing again and offend people by my thoughts on using a gyro in a plane....so I'll zip ithehehehe
Really... that's uncalled for. I can see why you can't discuss "the whole gyro thing" without offending people. Offending people just comes naturally I guess. You jumped down my throat with no provocation a while back. You apologized. I'm glad I never accepted 'cuz here you are again.
BTW, my fully AS3X-ized UMX Sbach can do both poptops and blenders. I don't think there's enough mass to swing into a KE spin. But having the wing oriented vertically should pose no problem for a gyro.
However I can see a gyro leading to a crash. It masks stuff until it's too late. Happens when hovering a Beast 3D a lot. Once it breaks out it's really all over... there's nothing left to recover.
erkq is online now Find More Posts by erkq
Old Aug 08, 2012, 10:36 AM
Aberdeen
Joined Mar 2006
ok one for 'no'.. anyone else want to have a punt? Video is 15% uploaded.. be quick
Old Aug 08, 2012, 10:38 AM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Steve
I guess no... I did however find a solution to the problem at hand.. I Sold the HK and bought 2 AJ slicks!
DaaBears is offline Find More Posts by DaaBears
Old Aug 08, 2012, 10:42 AM
Aberdeen
Joined Mar 2006
ok.. two for 'no'... And selling the HK Slick doesnt count as a solution
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1561 Aug 26, 2016 01:45 PM
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 540 Aug 16, 2016 01:18 AM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 01:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 11:14 AM
