Old May 04, 2012, 01:12 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Mine were like Jets. They were not really useable at around 75 cycles. My gen ace and genesis batteries at 100 cycles still performed as good as new (I bought new ones at the time of my 100 cycles to test)
losifanatic is offline Find More Posts by losifanatic
Old May 04, 2012, 01:55 PM
Depronicus is online now
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
What's the best source for Gens Ace?
Depronicus is online now Find More Posts by Depronicus
Old May 04, 2012, 02:04 PM
Sippin the Koolaid!
Joined Oct 2007
hobbypartz, nitroplanes, ADChobbystore. Take your pick
Old May 04, 2012, 02:08 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Hobbypartz or Nitroplane (same folks). Wait until late May 2012, Helidirect is bringing out a new line of kick arse lipo for helis and planes at reasonble price.
chopper62 is offline Find More Posts by chopper62
Old May 04, 2012, 03:39 PM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Exactly what happened to me 65 cycles on the nanos and about to hit the bin. Sky's and gens 100 flights and can't tell the difference from new
bryansifsof44 is online now Find More Posts by bryansifsof44
Old May 04, 2012, 06:07 PM
Sippin the Koolaid!
Joined Oct 2007
Got my attention
Old May 04, 2012, 08:16 PM
flybyfaith is offline
Find More Posts by flybyfaith
Joined Apr 2007
Tested the slick today with the apc 15-8 prop,turnigy 3040 480kv.
No problem with this prop,good power 6min mix flight and the motor was just warm,put back 1600mah.
flybyfaith is offline Find More Posts by flybyfaith
Old May 05, 2012, 12:58 AM
bonner is offline
Find More Posts by bonner
Tree Trimmer
bonner's Avatar
alex va.
Joined Oct 2008
Servo Question
Hey Guys can this servo be used in the HK Slick? Turnigy 380MAX Micro Servo (Metal Gear) 4.1kg / .16sec / 17.4g
Under the specs it says designed for glider use. What is the difference between this and a airplane servo? Its shown in stock and I need four for a new HK slick.
bonner is offline Find More Posts by bonner
Old May 05, 2012, 02:18 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
The Turnigy 380max are the same servos as the Bluebird BMS380max. they are what I used when I first built my HK Slick. These are my thoughts from earlier in this loooong thread:
The 380max servos got the job done and have tons of torque but they are a bit slow and imprecise. Centring was also not brilliant so it was impossible to properly trim the model to consistently fly dead straight, nothing extreme but I certainly noticed an improvement when I fitted the digital Savox’s. They are also a little bigger than the holes in the airframe so you need to open the holes up a bit.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old May 05, 2012, 08:24 AM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
MMMM, the 380max are the same servos I have and I finally pressed the buy button on a blue slick.
I've had them sitting here for 2 years because I purchased them for my e-flite extra 32 but they were physically to small for it. I would much rather not buy new servos AGAIN.
How much surgery did you have to do when you switched from the 380's to the Savox's?
creapyd is offline Find More Posts by creapyd
Old May 05, 2012, 09:16 AM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
I had a few flights after the repairing the motor mount and I'm pleased to report that it flies well. As I got more comfortable and fly lower and slower, I found out first hand what you guys meant by it suddenly dropping a wing. I didn't crash from it, but it caught me off guard several times.
*edit* then again, my left wing leading edge has a dent at the root from the previous crash, so this probably caused or magnified the effect.
I'm thinking of getting the AJ slick after my HK slick expires. Do you guys know if;
- the Turnigy Aerodrive SK3 - 3548-840kv motor is a good fit on the AJ slick
- if the servos mounting plates are similar or bigger. I intend to transfer all the electronics over.
miketre is offline Find More Posts by miketre
Old May 05, 2012, 10:12 AM
Aberdeen
Joined Mar 2006
To fit the 380max servos i had to take 1.5mm from each end of the servo cut-out and just a fraction from the sides.
To use the Savox's i basically had to put that wood back again. I just cut little bits of ply and CA'ed them in the end of the slot. the width you can leave because you only have to remove a sliver anyway.
Old May 05, 2012, 10:52 AM
creapyd is offline
Prefectionist
Joined Mar 2007
As a simple sport flying option would these servos work?
No hard 3d, very small throws.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Old May 05, 2012, 06:36 PM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
I would be afraid to fly anything but a small foamy with a $3.77 servo
Gravitycheat is offline Find More Posts by Gravitycheat
Old May 05, 2012, 07:35 PM
Sippin the Koolaid!
Joined Oct 2007
Originally Posted by gravitycheat View Post
i would be afraid to fly anything but a small foamy with a $3.77 servo
+1.
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 539 Mar 29, 2016 03:15 PM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 01:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 11:14 AM
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1560 Oct 24, 2014 11:58 PM
