Old Feb 22, 2012, 06:02 AM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Yep, its all standard setup as you would for any of 3dhs, PA or EF planes. Actually easier than my PA ADX to put together.
bigroger is offline Find More Posts by bigroger
Old Feb 22, 2012, 07:20 AM
xsubsailor is offline
Find More Posts by xsubsailor
Pants on the ground
xsubsailor's Avatar
exit 26 Jersey
Joined Jul 2007
Subscribed
xsubsailor is offline Find More Posts by xsubsailor
Old Feb 22, 2012, 08:48 AM
xzuberance is offline
Find More Posts by xzuberance
Where's my orange kool-aid?
xzuberance's Avatar
Australia, VIC, Boronia
Joined Apr 2010
Originally Posted by bigroger View Post
long leng.
The weight of the plane I notice a little bit compared to a 1200g plane.
The Dean guys ran the much heavier motor and esc than me so I'm still perplexed how he got his weight lighter than me.
I'm using HS85MG on the elevator, HS65MG on the rudder, MG14's on the ailerons.
Maybe the 85MG in the elevator contributes to the cg being more towards the tail.
I'm sure the other things I discussed will just need me to adjust to the plane rather than it being a bad plane.
Certainly handles a lot of violent stick work yesterday without too much complaining.
Rog, I think Dean ran a 2200mAh Nanotech which may be lighter than a 2200mAh 40c Turnigy
xzuberance is offline Find More Posts by xzuberance
Old Feb 22, 2012, 09:08 AM
MrRican is offline
Find More Posts by MrRican
Joined Feb 2011
I just spoke with Michael Wargo and he is at the field. The latest update is that he really like it. I got some picture of my built and like everybody knows I put together this airplane overnite. Im going to include my personal opinion about HK Slick.
MrRican is offline Find More Posts by MrRican
Old Feb 22, 2012, 09:13 AM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Originally Posted by MrRican View Post
I just spoke with Michael Wargo and he is at the field. The latest update is that he really like it. I got some picture of my built and lke everybody knows I built this plane overnite.
Hi Vince -
As I guess you have build a lot of MW's planes, what is your overall impression of the design, rigidity are there plus points and negatives that you can throw light on with regard to the build quality and general build of this plane...
Space Bat is offline Find More Posts by Space Bat
Old Feb 22, 2012, 10:07 AM
MrRican is offline
Joined Feb 2011
My biggest consern was the rear end. Built quality its ok for the price. The Rudd and elev mount wall is to soft. I added epoxy and CA to motor box to provide rigidity. Mike's Slick are spinning NTM Prop Drive 42-38 with a VOX 1 and produce around 3.05 Kg of thrust. One more thing that I would change is the landing gears for carbon fiber. Servos needs longer arms, sepecially elevator Overall the airplane was easy to built, Mike is very happy and impressed with the performance. No wing rockking.
Old Feb 22, 2012, 10:13 AM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
hey Vince, what servos and battery are being run? Any problem getting CG?
3drcparts is offline Find More Posts by 3drcparts
Old Feb 22, 2012, 10:18 AM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
How did the 42-38 motor fit within the cowl? HK is recommending 35-48 motors which are 10 mm longer. Did you have to use spacers to get the prop outside the cowl or is HK recommending motors that are technically to long to fit?
creapyd is offline Find More Posts by creapyd
Old Feb 22, 2012, 10:19 AM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
I may have missed the post but, if you can, please inform as to servos, motor, esc, and percentage throw for the ail, elev and rudd. Thanks.
Btw, can the rudd and elev mounting wall be re-enforced easily to make it stronger?
chopper62 is offline Find More Posts by chopper62
Old Feb 22, 2012, 10:20 AM
MrRican is offline
Joined Feb 2011
Well Mike still at the field. I used the HK 929 servos for aile. and Turnigy TGY-2216mg. for rudd and elev. For battery he used a turnigy nano-tech 4s 2200mha 45c. he already flew the slick and last night we checked the cg with the 2200 4s and balanced perfect. You still have plenty room to play with.
Old Feb 22, 2012, 10:34 AM
vhuang168 is offline
Find More Posts by vhuang168
United States, CA, Sunnyvale
Joined Mar 2011
Can you elaborate? Maybe some pictures when you can? Did you add epoxy to strengthen it?
Vincent
vhuang168 is offline Find More Posts by vhuang168
MrRican is offline
Joined Feb 2011
I had no problem with the cowl. The ony problem I had was the motor mount. I had to modified. I took mesurement of the motor mount, cutted two pieces of 1/16 of ply, expoy it together glue it to the back of the motor mount and drill new holes.
Old Feb 22, 2012, 10:38 AM
creapyd is offline
Prefectionist
Joined Mar 2007
When you say you modified the motor mount, was this to extend it? shorten it? or make it wider?
Old Feb 22, 2012, 10:40 AM
MrRican is offline
Joined Feb 2011
Vincent
y
I had worked with Michael's PA, Twisted Hobbies, HK,etc, and I alway use expoxy where the motor box connect to the firewall, in and outside. Also CA to all the joint.
About the pictures, yes, I have some pictures of my built. I been busy responding to all your questions. I had plans to post them today but it going to take me a wild.
Old Feb 22, 2012, 11:00 AM
Joined Mar 2011
y
I was refering to your comment about the rudd and elevator mount wall being too soft.
Vincent
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 539 Mar 29, 2016 03:15 PM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 01:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 11:14 AM
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1560 Oct 24, 2014 11:58 PM
