Old Apr 14, 2012, 12:12 PM
NJSwede is offline
Find More Posts by NJSwede
3D Wannabe
NJSwede's Avatar
United States, NJ, Mendham Township
Joined Jul 2011
Originally Posted by JetPlaneFlyer View Post
So it's not just me then It will iron back down but probably eventually replacing is the only option. The good thing is that Ultracote/oracover is a perfect match (at least for the red blue and white ).
That's my plan to. The tape was just a field repair to keep it from peeling off even more.
Haters, are you paying attention? I think we found and confirmed a quality issue!
NJSwede is offline Find More Posts by NJSwede
Old Apr 14, 2012, 12:41 PM
NJSwede is offline
3D Wannabe
NJSwede's Avatar
Joined Jul 2011
BTW, another thing broke for me. Two of the wooden tabs coming out of the fuse that's supposed to hold the cowl screws cracked. I have to admit it's probably...ahemm... builder error, though. Any ideas how to repair and strengthen? I was thinking of gluing a thin sheet of vinyl on both sides to provide strength and better "bite" for the screws.
(No crash, but I think I had weakened the tabs during the build and then they came loose from the air pressure when I was fooling around with high speed passes yesterday...)
Old Apr 14, 2012, 12:57 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
A bit of 1/16" plywood on the inside should do the job on the cowl tabs. I've not noticed any weakness with those tabs on my Slick but on any ARF with those tabs it is quite easy to split the wood if you don't pilot drill. CA soaking the wood helps too.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Apr 14, 2012, 01:27 PM
NJSwede is offline
3D Wannabe
NJSwede's Avatar
Joined Jul 2011
Yup. I had broken my 1.5mm drill bit, so I figured I'd just drive them in instead of taking a trip to the hardware store. Ah, the stupid things you do when you just want to get it in the air QUICK....
Old Apr 14, 2012, 06:08 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
+1 to the CA soak.
I've crashed mine twice as you all know, the second one the motor departed from the cowl mid flight and the cowl tabs held up fine. They, like a lot of my timber is CA soaked, much to our friends amazement after this CA soaking I am still alive, not riddled with cancer and not suffering any long term hallucinogenic issues!!!
bigroger is offline Find More Posts by bigroger
Old Apr 14, 2012, 06:23 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Got a flight on the slick today. It was blowing 25 to 35mph out (very gusty) Still had fun though. I need to measure the amp draw on that motor(sunnysky 2820 800kv) as it killed the Nano 2650 in less than 5 minutes and swelled them up. Where I flew just as hard on the AJ today with the motrolfly 3615 750kv (and the AJ is heavier and puts out much more power to the prop) and got 5 minutes out of it and the batteries were bearly warm. I think the sunnysky motor isn't up to the task of pushing the slick around effeciently. Got to see what I can do about getting a motor in there thats more up to the task
losifanatic is offline Find More Posts by losifanatic
Old Apr 14, 2012, 10:12 PM
ryanotown22 is offline
Find More Posts by ryanotown22
Currently flyin Crack Yak
United States, AZ, Gilbert
Joined Jul 2006
I customized my slick today.. now you can tell the difference between 3DHS AJ Slick and the HK slick.. LOL
ryanotown22 is offline Find More Posts by ryanotown22
Old Apr 14, 2012, 10:27 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
I agree. The new and improved, HK "SUCK"
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Apr 14, 2012, 10:36 PM
Joined Jul 2006
I knew you would like that one hahaha
Old Apr 15, 2012, 12:05 AM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Yuck, blue and black is quite the fashion faux pas!
DaaBears is offline Find More Posts by DaaBears
Old Apr 15, 2012, 12:50 AM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
I thought the title of this thread is "no bashing"
chopper62 is offline Find More Posts by chopper62
Old Apr 15, 2012, 03:32 AM
Ola. is offline
Find More Posts by Ola.
Joined Feb 2011
Mine`s called "Lick" :P
But does anyone know of long servohorns that fit the TGY-2216MG servo`s ?
I made some, but even they arent long enough for max throw, so i`m thinking of buying new.
Ola. is offline Find More Posts by Ola.
Old Apr 15, 2012, 04:36 AM
Aberdeen
Joined Mar 2006
Just make your own. get a piece of carbon or G10 laminate sheet (ebay sell it) and cut your own. Either 1mm or 1.5mm does the job. 1mm can be cut with a strong pair of kitchen scissors which saves some time.
You CA the extension over top of the standard arm and drill a couple of holes through spare holes in the servo arm and pop in a couple of tiny screws.
See photo attached.
Old Apr 15, 2012, 05:24 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
You could also use the sharp tip of an exacto knife as a drill bit by just twisting the knife around, works quite well.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Apr 15, 2012, 06:10 AM
luke352 is offline
Find More Posts by luke352
Australia, QLD, Ipswich
Joined Sep 2008
Small flat blad jewellers screwdriver works great too.
luke352 is offline Find More Posts by luke352
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 539 Mar 29, 2016 03:15 PM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 01:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 11:14 AM
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1560 Oct 24, 2014 11:58 PM
