Old Feb 20, 2012, 09:11 PM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
No, something is wrong. With that motor and that prop you should be getting at least 50 amps....
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Feb 20, 2012, 09:26 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
RC Pilot / Photographer
-= GYRO =-'s Avatar
Joined Nov 2010
Originally Posted by slickg66 View Post
** on a side note, I did have to send a 3620-480 back to Ken to get rewound, after it was running 50kv below specs. He fixed me up and shipped it back inside a week though, so I'm still a loyal customer! **
If this is his first time running up the motor, there is a chance that it wasn't wound up to specs, in which case Ken will test it and rewind if necessary. He stands behind his stuff!
From what others have told me regarding Motrolfly motors, ESC should be set for high timing and 16pwm.
-= GYRO =- is offline Find More Posts by -= GYRO =-
Old Feb 20, 2012, 09:56 PM
mikecopey is offline
Find More Posts by mikecopey
mikecopey's Avatar
United States, FL, Oviedo
Joined Dec 2008
Originally Posted by mongo ea6b View Post
Being the guy who does the video taping for MW, and some of the building of the planes you all have seen on these videos, there is NOTHING retouched, over-edited, fixed or more original than what you see. I'm the one standing there, watching all these maneuvers in the viewfinder, as the plane is, out of the box!
I know all the other guys who build the planes, they all build them EXACTLY as they are instructed by the build information provided, and I will swear on my retired military Officer integrity that the flight sequences are exactly what the plane can and does do!
There are planes that fly better than some others, but what you see and have seen is what you get!
I hope this quiets any non-believers or naysayers about what these planes can and do out of the box! MW just flies them to his limits, which I see routinely and are exceptional to say the least.
Agreed... I have seen a lot of posts on this... I've watched the shooting...And people saying planes won't do what they saw...
mikecopey is offline Find More Posts by mikecopey
Old Feb 20, 2012, 09:59 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
OK. I got it from the local Motrofly agent RC models.
They claim these are the exact same off the shelf motor as ken.
Unfortunately when I tried to measure my rpm with my hand held tacko it peaked at 2250rpm on 2 blade setting. POS....
OK, I ran it on both Plush 40A and also K force100amp esc in case it was the speedy limiting its output. Almost the same numbers.
I also have the 2820-950kv motor, so I bolted it up to the same prop "vox 14x7' and tested it on 3s and got 59A and 690 watts peak. This was on my plush 40A speedy so assume the esc in this case limited the output a bit.
I suspect its not the kv they claim. The dealer actually tells me it is wound to 726kV, but by the sounds of it and the amps it must be wound below 650kV as it seems like the numbers that Tom Kitt is generating on his custom wind motor.
Also the lipo is brand new Turnigy 40C 4s2650mA.
Three cycles on the lipos through the charge to break them in, I was measuring well over 15.5V through the testing.
bigroger is offline Find More Posts by bigroger
Old Feb 20, 2012, 10:03 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
8PWM.
timing I use is around medium.12 ish I think.Will have to find my notes somewhere..8pwm tho I'm sure of for motrolfly. if it works ok on your settings tho rock on.
Manta1 is offline Find More Posts by Manta1
Old Feb 21, 2012, 01:00 AM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Thing of beuty.
Ready to maiden tomorrow.
Still not getting the kick out of the motor I was looking for but I'll play around with timing and PWM settings and see if it gives me more.
Old Feb 21, 2012, 01:12 AM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
BR,
Nice build.
You're going to video the maiden, right?
KE Spin is offline Find More Posts by KE Spin
Old Feb 21, 2012, 02:56 AM
xzuberance is offline
Find More Posts by xzuberance
Where's my orange kool-aid?
xzuberance's Avatar
Australia, VIC, Boronia
Joined Apr 2010
Sorry for going off topic. Just wondering what are people's thoughts about the HK v3 edge 540 as compared to the slick? Is the new style wing profile any good for 3d? I know some of the pilots who fly the new style edge in the red bull races have said the new wing reduces drag in tight turns. I suppose this is useful for pattern stuff but not for post stall flight?
xzuberance is offline Find More Posts by xzuberance
Old Feb 21, 2012, 04:02 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Subscribed and ordered!!!!!can't wait to take delivery of this babe.JEES shipping is just lank to SA $145 $30 more than the plane,but I'm sure still so worth it I think.i thought long and hard between the Slick and the Domi-8-Trix and after much thought and watching vids I believe this is the best quality plane to get.Just a quick Q,is the slick on the side of the fuse a sticker?or printed on the covering?
chop stiX is offline Find More Posts by chop stiX
Old Feb 21, 2012, 06:27 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
there is certainly somethingwrong as you should be just about melting the motor with a 14x7 VOX.
Bare in mind that the Motrolfly DM2820/750 has been produced with three different winings.. the older motors were 638kv, then they were wound to 680kv, and only since Novemebre or December 2011 have they been produced in the (approx) 720kv winding. Seems to me that you probably have one of the older versions.
With a 14x7 APC my 720kv motor just breaks 1kW (1012W) on a 4s Gens Ace battery, that's peaking at 66Amps and 3.5Kg of thrust. A Xoar is even more power but really getting into melt down territory for the motor IMHO.
Having said that.. the ESC you are using can make a big difference, smaller ESC's (and some brands in general) have higher internal resistance and so limit power. I got a increase in Watts of about 150 just by going from a 50A Castle Ice to a 60A ZTW. I'd highly recommend the ZTW ESC, cheap, compact, lightweight and very low resistance (ZTW are also badged Black Mantis and Mystery)
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Feb 21, 2012, 06:32 AM
Aberdeen
Joined Mar 2006
Originally Posted by KE Spin View Post
BR, I just looked up the specs and they say you could expect 710watts max.
Specs on the Subsonic web site (if that's what you were looking at) for the Motrolfly 2820/750 motor are for the older 638kv winding, the later motors are MUCH hotter... or at least should be
Old Feb 21, 2012, 06:37 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
I have found the same thing with the ZTW esc's as well. Generally compared to a typical economy esc the ZTW will have a lower resistance and will boost performance. The only direct comparison's I can attest to are with Turnigy Plush, EMax, and some other cheap one I have that I don't remember the name of. And the reliability of the ZTW has been perfect, at least with the half dozen I have been using for the last couple years. The only thing I wished they would do is make the batt wires about an inch longer, not a deal breaker though.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Feb 21, 2012, 06:43 AM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Hi JetPlaneFlyer
Do you know where in the UK you can get these motors - or is it strictly ship from US??
Space Bat is offline Find More Posts by Space Bat
Old Feb 21, 2012, 06:58 AM
Aberdeen
Joined Mar 2006
Originally Posted by Space Bat View Post
Hi JetPlaneFlyer
That's a hard one.. There is a dealer in France that sells the same motors under the name 'Pro-Tronik'.. They are basically the same motors made in the same production line as the Motrolfly but anodised green! The problem with them is that you wont know what kv version you will get, the Frech dealer still list it as 638kv on the web site but what it is in reality is pure guesswork.
Second problem in the motor comes in two mounting types. The type Subsonic in the USA sell is the bolt on prop adapeter version, the type sold in the French dealer is a shaft and collet version which makes the motor too long for the Slick. Maybe if you send the dealer and email they could clarify if they can supply the bolt on adapter version, and the kv question, but language may be a problem unless you have good French?
PM me if you want a link to the French dealer.
I'd highly recommend getting a motor from Subsonic, their customer service and expertise is second to non, but they wont ship to Europe So you have to have a friend in the US to forward it on.
Steve
Old Feb 21, 2012, 07:04 AM
Team Hillbilly (UK)
Space Bat's Avatar
Joined Oct 2011
Many Thanks JPF - I have managed to get a dealer page up for the Pro Tronik motors....No UK though
I will ping some of them an email -
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1561 Aug 26, 2016 01:45 PM
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 540 Aug 16, 2016 01:18 AM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 01:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 11:14 AM
