Old Feb 20, 2012, 03:26 PM
mongo ea6b is offline
Find More Posts by mongo ea6b
United States, FL, Orlando
Joined Dec 2010
Real Deal
Being the guy who does the video taping for MW, and some of the building of the planes you all have seen on these videos, there is NOTHING retouched, over-edited, fixed or more original than what you see. I'm the one standing there, watching all these maneuvers in the viewfinder, as the plane is, out of the box!
I know all the other guys who build the planes, they all build them EXACTLY as they are instructed by the build information provided, and I will swear on my retired military Officer integrity that the flight sequences are exactly what the plane can and does do!
There are planes that fly better than some others, but what you see and have seen is what you get!
I hope this quiets any non-believers or naysayers about what these planes can and do out of the box! MW just flies them to his limits, which I see routinely and are exceptional to say the least.
mongo ea6b is offline Find More Posts by mongo ea6b
Old Feb 20, 2012, 05:33 PM
long leng is offline
Find More Posts by long leng
zürich
Joined Jun 2008
ok, have some pics from the build.
was just in my building room to do the last bits.
Name: hk slick 035.jpg
Description: the hs 5065 fits in
Name: hk slick 036.jpg
Description: the airtronics / sanwa sdx 762 needs a bit of sanding
Name: hk slick 037.jpg
Description: hs82 way too long
Name: hk slick 064.jpg
Description: going clos with the flame opens the foil a little, so the ca goes into the wood rather then running on the foil
Name: hk slick 067.jpg
Description: this helps to know where the middle is
Name: hk slick 073.jpg
Description: standard is 3 hinges. i added one more (the second from left)
Name: hk slick 074.jpg
Description: dumb mistake. i mounted the stab and forgot the elevator. had to cut
Name: slick hk 074.jpg
Description: i prefer to drill then solder.
drill it, ply it and shrink it
Name: slick hk 057.jpg
Description: the standard pushrods fit perfectly
Name: slick hk 058.jpg
Description:
Name: slick hk 062.jpg
Description: i wanted to have stronger ones, so  i had to enlarge the holes
Name: slick hk 065.jpg
Description: the ones i used instead
Name: slick hk 070.jpg
Description:
Name: slick hk 072.jpg
Description:
Name: slick hk 075.jpg
Description: cutting the box to put the cross behind the firewall?
wont be much wood left around the screws
Name: slick hk 076.jpg
Description:
Name: slick hk 078.jpg
Description:
Name: slick hk 086.jpg
Description: took the cf- landing gear from the aj slick
Name: slick hk 087.jpg
Description: bigger wheels, 13g each, they absorb a lot of energy
Name: slick hk 088.jpg
Description:
Name: slick hk 089.jpg
Description: hacker a 30 too long
Name: slick hk 090.jpg
Description: could have moved the canopy a little more frontways but not much
Name: slick hk 083.jpg
Description: the servoarms are 27mm, this is the max lenght for elevator as it would touch the stab otherways.
with the 27mm you would get more throw than you want...about 80degrees. 20mm servoarm could be enough. havent tested it.
at the rudder the same, 27mm is mo
Name: slick hk 080.jpg
Description: big surprise when measured cg.
the plane was very tailheavy!!!!
instead of the 4s 2200 i had to enter a 4s 3300 and put it far in the front to get cg right.
my servos in the tail are about 22g each
Name: slick hk 092.jpg
Description:
Name: slick hk 091.jpg
Description: welcome a new plane in the hangar.
the weight without pack is 1321g and with the 3300er pack 1645g.
for the maiden flight i programmed 55 degrees elevator up and down, rudder max and aileron 47 up and 43 down
Name: slick hk 095.jpg
Description: big big shock when i turned the motor on.
this flew away
Name: slick hk 096.jpg
Description: and this stayed in!!!
does anyone now whats going on????????
long leng is offline Find More Posts by long leng
Old Feb 20, 2012, 05:45 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Thanks for the pictures, very very helpful in helping me make my decision, did you use the back collar on the hacker, c-clip is not enough
3drcparts is offline Find More Posts by 3drcparts
Old Feb 20, 2012, 05:54 PM
ryanotown22 is offline
Find More Posts by ryanotown22
Currently flyin Crack Yak
United States, AZ, Gilbert
Joined Jul 2006
awesome great pics keep em coming
ryanotown22 is offline Find More Posts by ryanotown22
Old Feb 20, 2012, 06:06 PM
zürich
Joined Jun 2008
thx you too.
janole, can you describe me about the back collar. have you any picture how this looks and works? cant really understand whats going on
Old Feb 20, 2012, 06:20 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
see the collar and grub set screw, these go on the shaft at the back of the motor
Old Feb 20, 2012, 06:21 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
lousy photo, but you can enlarge the photo here on the website
http://www.aero-model.com/Hacker-Brushless-A30-10L.aspx
Old Feb 20, 2012, 06:40 PM
zürich
Joined Jun 2008
ahhh, thx a thousend times!
you mean to fix it with the ring. yeah, thats logic. how dumb, the vox prop is unusable now and they are hard to find here. will take an apc.
Old Feb 20, 2012, 08:13 PM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
I have to admit I was pretty bent when I saw the orange, glad it's not around anymore. I do have an objective opinion, I fly what works at the level I do. So I fly PA and E/F, great planes. If a PA team pilot is on board here it lends a lot of credability. I'm a mere mortal, I LIKE the violent stuff, gimme' one and I'll WRING it out and give you an objective opinion. Take all the video you want. People ask me to fly their planes all the time and I give them an objective opinion. Again flying is easy landing is hard so HAPPY LANDINGS!
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Feb 20, 2012, 08:46 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Ok Guys.
Just fired up my motrofly Dm2820-750 for this plane with 4s and a vox 14x7 prop.
Measured the amps that peaked at 40A and 624watts roughly.
Bit disappointing I think for a 4s setup. I was expecting something well over 800W with that prop and 4s setup.
bigroger is offline Find More Posts by bigroger
Old Feb 20, 2012, 08:48 PM
wyo69cowboy is offline
Find More Posts by wyo69cowboy
USA, WY, Cody
Learned that one the hard way myself on a bigger brushless--even more important there with greater pull and more weight. Pulled the c clip off...
Let us know how she flies!
wyo69cowboy is offline Find More Posts by wyo69cowboy
Old Feb 20, 2012, 08:56 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Originally Posted by bigroger View Post
Ok Guys.
BR, I just looked up the specs and they say you could expect 710watts max. The 624watts you are getting seems low. The motor information said that on 4s at 50a you should get the 710w max. I'm wondering if the ESC is limiting the current down to 40a.
What ESC you using?
KE Spin is offline Find More Posts by KE Spin
Old Feb 20, 2012, 08:59 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
That does seem low. Are your batteries OK ?
losifanatic is offline Find More Posts by losifanatic
Old Feb 20, 2012, 09:00 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
Ok Guys.
Roger,
I have a Motrolfly 2820-950 that I'm running on my Extreme Flight RC 48" MXS-EXP (GREAT airplane by the way) and I get 900w at 60a with a 12x6.
Granted I'm running (200kv x 15v) 3000rpm faster than you, so I can't compare my numbers with the prop you're using. Maybe a 15x7 or 15x8 might get you better results. I did have to "prop-up" from Ken's recommend 15x7 to a 15x8 on the 4315-480kv motor I've got in my 3DHS 59" AJ Slick (GREAT airplane by the way), to get the performance I wanted. Either way, the Motrolflys are GREAT motors, I have two and they're excellent!
Good luck mate!
** on a side note, I did have to send a 3620-480 back to Ken to get rewound, after it was running 50kv below specs. He fixed me up and shipped it back inside a week though, so I'm still a loyal customer! **
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Feb 20, 2012, 09:02 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Ok Guys.
hmm you can prop up some with those numbers but lets talk esc settings and batteries.
I get around 700 watts with mine.My KV may vary a tad from yours tho.
Manta1 is offline Find More Posts by Manta1
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Discussion Official Hobbyking 720p HD Camera Thread jaskel FPV Equipment 539 Mar 29, 2016 03:15 PM
New Product Turnigy SLICK 3D 1.3M -HOBBYKING Official Build Thread will3d4food 3D Flying 1978 Jun 24, 2015 01:26 PM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 11:14 AM
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1560 Oct 24, 2014 11:58 PM
