Old Oct 14, 2003, 02:04 PM
ricfoust is offline
Find More Posts by ricfoust
Reading, PA
Joined Sep 2003
Question
correct hookup for pressurized fuel tank
Hi Guys,
What is the correct hookup on the cap of a pressurized fuel tank? I know the line in tank with clunker goes to carb. But... does the vent line in the tank with curves up into the bubble of the tank hook up to the muffler pressure valve? When the tank is full won't this push fuel into the muffler? Are these the only two lines needed going into the fuel tank cap?
The Rookie
ricfoust is offline Find More Posts by ricfoust
Old Oct 14, 2003, 03:12 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
Yes it will push fuel into muffler. Tells you the tank is full!
You can go as described or have a third line for fueling which needs to be plugged except for refueling.
4*60 is offline Find More Posts by 4*60
Old Oct 14, 2003, 03:29 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
You just disconnect it when you fuel, so it does not fill the muffler.
Old Oct 14, 2003, 05:29 PM
therotund1 is offline
Find More Posts by therotund1
Carrying a lot of weight!
therotund1's Avatar
West Tennessee
Joined Jul 2003
Or you can leave the pressure line hooked up while you fill PROVIDED that it the muffler is below the cylinder/head (I.E. horizontal or inverted mounted engine) and pointed down. When fuel drools out, tanks full!
Dave,
drooler....
therotund1 is offline Find More Posts by therotund1
Old Oct 15, 2003, 08:39 AM
ricfoust is offline
Reading, PA
Joined Sep 2003
Thanks guys!!!!!!!!!
Pressurized fuel tank question.. IronKnees Fuel Plane Talk 14 Dec 20, 2005 06:04 PM
Plug for CFRP fuel tank reinking Composites Fabrication 2 Jun 20, 2005 01:20 PM
Question Looking for a fuel tank MatjesDuo Fuel Plane Talk 7 Nov 28, 2003 02:30 PM
