Old Feb 17, 2012, 04:01 PM
dwmumford is offline
Find More Posts by dwmumford
Bountiful, Utah
Joined Dec 2003
How much downthrust on Skybench Big Bird XL electric?
I am currently building the Ray Hayes Big Bird XL using a Turnigy outrunner 3536-1100 motor with 12-6 prop. I should be plenty of power to get the sailplane up quick.
The plans show a geared motor setup, but I've read it is very slow and lacking much power. The plans for the electric conversion with that slow puny geared motor shows 2 degrees down thrust and 2 degrees right thrust. Should I stay with that off-set or use more?
Any of you have good experience with Turnigy motors from China?
dwmumford is offline Find More Posts by dwmumford
Old Feb 18, 2012, 05:49 AM
Highride is online now
Find More Posts by Highride
Michigan's Upper Peninsula
Joined Sep 2007
Dw,
Can't help you on the thrust angle, but someone will chime in with some info for you.
Turnigy motors...I only have one and that's in a 2.5m ship. I was a bit leery at first eventhough the designers of the plane recommended the Turnigy for power. I cannot recall the model number but it is rated at 650Kv. The first thing I did when I received the motor, was to take it apart and have a look. I am not a technician, but the motor is nicely finished and performs very well with two seasons and many, many flights.
Dave
Highride is online now Find More Posts by Highride
Old Feb 19, 2012, 09:09 AM
Hawksnest is offline
Find More Posts by Hawksnest
Hawksnest's Avatar
United States, PA, Perry
Joined Apr 2002
Dave, I just set up a Skybird for electric. I have 3 BigBirds flying with electric For a 30 sec. climb to altitude, I don't worry too much about downthrust. I just program a little down elevator into the throttle, and fly the plane. Wait until you have it flying to do this, in the meantime, I just eyeball a little downthrust and a very little right thrust in the mount. Bill G
BTW, how you doing Dave?
Hawksnest is offline Find More Posts by Hawksnest
Old Feb 19, 2012, 01:49 PM
Bountiful, Utah
Joined Dec 2003
Hi Bill,
good to hear from you! I am doing well except I have not done nearly as much flying the past few years as I'd like. This Big Bird XL has been sitting with the wing half done for 4 years. My time is pretty limited. Well, in January I decided to finish this project by spring no matter what. So the wings are finished with servos mounted in the wings ready to cover. The fuse is what I am working on now.
I will just use the 2 degrees down and 2 degrees right thrust as Ray Hays plans show. I am a little befuddled about how to handle the nose and motor construction, but I will figure it out. I purchased the aeronaught folding prop and turbo spinner for air flow. the BB XL should be a nice flyer.
Dave
Old Feb 19, 2012, 03:06 PM
Hawksnest's Avatar
Joined Apr 2002
I have an XL I've been flying ever since Ray announced it, maybe 5 years ago. I just last year converted it to E power. It's a good flyer, you will like it. Bill
Build Log Skybench Big Bird XL yachtie Thermal 77 Feb 25, 2013 12:08 AM
Discussion Electric Big Bird XL animalsmom Electric Sailplanes 3 Mar 07, 2012 10:38 PM
Discussion how much wing incidence and downthrust with KFm2? JayJay76 Foamies (Scratchbuilt) 25 Oct 05, 2011 12:50 PM
Build Log Skybench Big Bird XL 4 Sale jzcode43 Electric Sailplanes 2 Oct 05, 2008 10:51 PM
Discussion Servos for Skybench Big Bird XL jzcode43 Slope 3 May 24, 2008 10:43 AM
