Old Mar 15, 2012, 01:10 PM
Sailhigh is offline
Find More Posts by Sailhigh
High Lift Coefficient
Sailhigh's Avatar
SF Bay Area, USA
Joined Feb 2003
Originally Posted by Dave Garwood View Post
Got the in-fuselage servos mounted and some nose weight epoxied in place.
Hanging it from the basement ceiling, I can get it to balance right on the wing rod
by moving the battery pack. Happy day.
Jay said his Multiplex DG-600 balances 78mm behind the LE.
Mine balances 67mm behind the LE (center of the wing rod).
Any of the Gerasis DG-800 flyers have their balance point marked?
Test fly it at 67mm, or move it back a little?
Thanks.
// Dave
Hi Dave,
I would not compare the CGs of the DG-600 of one mfg to DG-800 of another mfg. Each make their variations when they scale down. The LE sweep of the outer wing panels between the two full size plane are different, and the size of tail planes are different also. I would stick with what Gerasis suggest for initial flight and adjust accordingly after wards.
Sailhigh is offline Find More Posts by Sailhigh
Old Mar 18, 2012, 02:39 PM
bie is offline
bie
Find More Posts by bie
bie
maidenflight-postponer
bie's Avatar
Germany
Hi Dave,
just found the manual of the Gerasis DG-800. It says:
CG = center of the joiner
rudder throw = +/- 30 mm
elevator throw = +/- 20 mm
aileron throw = 8 mm down/15 mm up
Also found some remarks I made and they say, that the AUW is 2700 gram.
Hope, it helps and wish you the best for the maiden!
Andy
bie is offline Find More Posts by bie
Old Mar 19, 2012, 02:50 PM
Dave Garwood is offline
Find More Posts by Dave Garwood
Fly like you can still see it
Dave Garwood's Avatar
USA, NY, Schenectady
Joined Mar 2009
Ready to Rock with the DG-800
Andy,
Helpful, and confidence-inspiring.
Mine is 2608 grams AUW.
Thank you very much.
// Dave
Originally Posted by bie View Post
Hi Dave,
Andy
Dave Garwood is offline Find More Posts by Dave Garwood
Sold DG 800 3.6m by Gerasis gottaflyrc Aircraft - Sailplanes (FS/W) 5 Feb 06, 2012 12:33 PM
Sold Gerasis DG 800/360 Scale 3.6m Local Pick Up SoCal tqpham Aircraft - Sailplanes (FS/W) 10 May 07, 2011 01:16 AM
Discussion OLD Gerasis DG-800 build (have glider, what now?) b7gwap Scale Sailplanes 31 Feb 11, 2010 04:54 PM
Discussion Gerasis DG-800 canopy slopemeno Scale Sailplanes 9 Dec 01, 2009 06:08 AM
Gerasis Dg800 Dg 800 orion1210 Scale Sailplanes 3 May 06, 2005 04:35 AM
