Old Feb 28, 2012, 09:25 PM
Dave Garwood is offline
Find More Posts by Dave Garwood
Fly like you can still see it
Dave Garwood's Avatar
USA, NY, Schenectady
Joined Mar 2009
Gerasis DG-800 control movement specs
Originally Posted by bie View Post
Hi,
donít worry, I can confirm: The stab definitely works as it should (at least it did in the last 15 years)Ö Andy
Andy,
If I recall correctly, you said the Gerasis DG-800 was one of your 2-3 top favorites out
of 50 planes you have built and flown. That observation gave me a lot of confidence
as I began building this kit.
However, I do not have the instructions, so I ask your advice on control surface throws.
My ailerons move UP 17 mm and DOWN 12 mm as installed now.
In your experience, is that enough aileron movement?
Is that enough aileron differential?
// Dave
Dave Garwood is offline Find More Posts by Dave Garwood
Old Feb 28, 2012, 10:58 PM
slopemeno is online now
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
My Gerasis DG-800 flies fine, small stab and all.
Not much to tell, really. It thermals surprisingly well, and is very stable. It makes nice fast carving passes at the slope, loops amazingly well (great energy retention over the top) and can be rolled fairly easy for a scale plane.
On the spoilers, mix 5% up elevator on your landing mix. It slows down if you give it a moment, and you can really slide in on the landing.
On your aileron throws, that sounds like more than I use. I'd set up some dual rates. I have my rudder mixed in with my ailerons so thermal turns are low effort. My suggestions would be to leave your rates mix open on your radio when you maiden it, and season to taste.
Question: What did you do for an elevator servo? I had a bunch of double centering with the stock elevator snake, so I finally got frustrated enough to remove the rudder and post, and mount a JR-341 servo inside the vertical stab. I made the shortest-possible
servo output arm and a very short pushrod up to the elevator. Works *perfect*.
slopemeno is online now Find More Posts by slopemeno
Old Feb 29, 2012, 08:13 AM
Joined Mar 2009
Very fine starter white wing kit for Dave
slopemeno,
Thank you for the flight report and setup tips.
Looks like I found a very fine starter scale kit.
Love your NorCal travel and slope flying location reports.
I have flown at Goat Rock. You make me want to fly at Navarro Bluffs County Park.
I agree with you on the ZIPPER and Bowman's COMANCHE.
Photo of Dave at Davenport with COMANCHE - same trip as Goat Rock trip.
We got a lot of flying time with the DAW 1-26s from pullouts along the PCH.
Ah, the memories come flooding back.
// Dave
Old Feb 29, 2012, 09:33 AM
this space for rent
slopemeno's Avatar
Joined Jan 2003
If I can I'll assemble the DG-800 tonight and give you my throws. It flies like a big 60" racer- like a Sparrow or Fun-1, in my opinion.
Yeah, we're lucky. It's expensive as all get out to live here, but the flying makes up for it.
Old Feb 29, 2012, 04:04 PM
Joined Mar 2009
DG-800 throws
slopemeno,
Any time in the next week works for me. Thanks.
Man-o-man, this is music to my ears.
// Dave
Old Feb 29, 2012, 05:29 PM
Joined Mar 2009
Short elevator linkage
I had been reading about elevator centering problems and I decided to discard the snake
and put the elevator servo in the tail. I spent lots of time figuring how I mount it inside the
vertical, but I was not happy with any linkage I could think of, so I decided to mount it in
the elevator. How's this for a short linkage?
// Dave
Old Feb 29, 2012, 08:42 PM
this space for rent
slopemeno's Avatar
Joined Jan 2003
There you go- that's as short as possible. I have a Spectrum that I want to try that on.
Old Mar 01, 2012, 04:48 AM
bie is offline
bie
Find More Posts by bie
bie
maidenflight-postponer
bie's Avatar
Germany
Hi Dave,
since the DG-800 is dismantled right now for renovation purposes (there are some cracks in the fuselage and I have to reinforce the fuselage) I can’t measure the aileron movement right now, sorry!
But I second Slopemeno’s remarks regarding this topic.
You’re servo installation of the elevator-servo makes me envy you! Perfect!
Do you want to fly on slopes? If so, do you expect rough landings? If so, I have to tell about a not so perfect landing with the DG-800 I had some years ago at Hahnenmoos Pass in the Swiss Alps: It was pretty rough and on first - hmmm - impact (it still was a "landing" after all, because no part of the plane separated from each other ) the horizontal stab broke right in the middle above the rudder fin!
Why do I tell? You’re servo brings in some additonal weight to that relatively delicate part of the plane. I had to reinforce the stab with an additional spar (made of balsa) - maybe you might want to do the same...
Andy
bie is offline Find More Posts by bie
Old Mar 01, 2012, 06:58 AM
Joined Mar 2009
Reinforce the horizontal stab, and the elavator
Youíre servo brings in some additonal weight to that relatively delicate part of the plane. I had to
Andy
Good advice. I will reinforce the reinforce the stab.
I was thinking also of strengthening the section between the elevator halves.
Thank you.
// Dave
Old Mar 01, 2012, 07:27 AM
MTT is online now
MTT
Find More Posts by MTT
MTT
I care about rising air !
MTT's Avatar
United States, OH, Norwood
Joined Feb 2002
Agree with all the previous posts...
Placing the servo in the horizontal stab will cause a lot more stress on the vertical fin on rough landings...
Instead of operating on the vertical fin to reinforce it, I recommend you install the elevator servo somewhere in the bottom of the fin, with a short pushrod to the elevator.
another possibility :
Install bellcrank in the fin, the servo in the fron of the fuselage, and connect it to the bellcarnk with a bowden type pushrod.
since it will be an almost straight line from the servo to the bellcrank, there should be no issues with binding or centering.
MTT is online now Find More Posts by MTT
Old Mar 01, 2012, 08:26 AM
bie is offline
bie
bie
bie's Avatar
Germany
David,
thatís the way to go, if you want to keep the servo in the stab - or either follow the direction, that Michael suggests.
In my DG-800 the elevator-servo is built into the upper half of the fin.
Andy
Old Mar 01, 2012, 10:52 PM
this space for rent
slopemeno's Avatar
Joined Jan 2003
I actually had the same issue a few years ago- hard to believe I've had that DG since 2000...
I was flying at Fourcorners in Marin County, and seeing just how far/high I dared fly away (high enough that Sean Sharif said, very deliberately "Don't...take...your...eyes...off...of....it." ) and decided to make a huge screaming pass. Flew past and landed and half the horizontal stab was hanging down about 20 degrees. Maybe I pulled up a little hard on that pass.
I stripped the covering, and the stab is covered in some paper-thin balsa. I repaired the break with a couple of layers of 3/4 oz E-glass cloth, and recovered the stab. No problems since.
A gunsmith friend of mine made the bellcrank that's inside the elevator. It's similar to the Brodak control line flap/elevator bellcranks, but the horn is oriented at 0 degrees to the tips.
Old Mar 03, 2012, 04:06 AM
pchewn is offline
Find More Posts by pchewn
Pat Chewning
USA, OR, Beaverton
Joined Sep 2009
What size is that joiner rod, and how much does the plane weigh?
pchewn is offline Find More Posts by pchewn
Old Mar 03, 2012, 05:09 AM
AirBornOne is offline
Find More Posts by AirBornOne
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
Andy,
// Dave
Hey Dave,The 800 looks great! I think we all would like to see more picts.
My MPX DG600 is @ 3.6m span so should be close to your 800.
I've attached the setup from MPX to get you started.When I setup my DG-600 accordingly it was just Fab.
Skies.
Jay
P.S. My H-stab measures just over 25-1/2" & 4-5/8" chord (w/elev.)
For pchewn, the DG-600 wingrod is 12mm X 300mm. How does that compare to yours Dave?
AirBornOne is offline Find More Posts by AirBornOne
Old Mar 04, 2012, 09:25 AM
Joined Mar 2009
pchewn,
My wing rod is 10 mm diameter, 300 mm length. Made of steel.
Let give you the weight when I get nose weight and fuselage servos installed.
Preliminary balance test indicates I need about 17 ounces of nose weight.
I just glassed the inside of the front compartment. That added 2.2 ounces.
// Dave
Sold DG 800 3.6m by Gerasis gottaflyrc Aircraft - Sailplanes (FS/W) 5 Feb 06, 2012 12:33 PM
Sold Gerasis DG 800/360 Scale 3.6m Local Pick Up SoCal tqpham Aircraft - Sailplanes (FS/W) 10 May 07, 2011 01:16 AM
Discussion OLD Gerasis DG-800 build (have glider, what now?) b7gwap Scale Sailplanes 31 Feb 11, 2010 04:54 PM
Discussion Gerasis DG-800 canopy slopemeno Scale Sailplanes 9 Dec 01, 2009 06:08 AM
Gerasis Dg800 Dg 800 orion1210 Scale Sailplanes 3 May 06, 2005 04:35 AM
