Old Feb 17, 2012, 03:56 PM
Dave Garwood is offline
Find More Posts by Dave Garwood
Fly like you can still see it
Dave Garwood's Avatar
USA, NY, Schenectady
Joined Mar 2009
Build Log
SCALE BUILDER VIRGIN: Gerasis DG-800 build
After 105 RC model builds, comes my first "real" (fiberglass) scale sailplane, a 3.6 meter DG-800 from the Gerasis kit.
My question today is: What adhesive is recommended for securing the canopy clear part to the light gray canopy surround?
The canopy clear part looks and feels like all the vacuum formed canopies I have seen in the past.
The light grey canopy surround rail is a "slippery" plastic, like Dura-Lene or 35mm film cans holders.
Candidates in my mind are:
1. Beacon Adhesives QUICK-GRIP
2. Pacer Formula 560 CANOPY GLUE
3. Ponal EXPRESS
4. EPOXY - after roughing up both sides
Advice from those who have solved this problem will be appreciated.
// Dave
I am aware of and thankful for these RC Groups threads:
THREAD: OLD Gerasis DG-800 build (have glider, what now?)
http://www.rcgroups.com/forums/showt...gerasis+dg+800
THREAD: Nearly wrecked my Gerasis 3.6m DG-800!
http://www.rcgroups.com/forums/showthread.php?t=1320479
Dave Garwood is offline Find More Posts by Dave Garwood
Old Feb 17, 2012, 04:00 PM
jtlsf5 is online now
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Dave,
Use the canopy glue. Water based, dries clear, all the right things for something as visible as a canopy.
Hope you've been keeping well.
JT
jtlsf5 is online now Find More Posts by jtlsf5
Old Feb 17, 2012, 05:14 PM
Lbuff1 is offline
Find More Posts by Lbuff1
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Dave, Pro's like Dennis Brandt and others use Zap A Dap A Goo. I learned from them and it works very well, Its like a shoe goo type material.
LEN
www.RcAerotowing.com
www.RcAerotowing.com/forum
Lbuff1 is offline Find More Posts by Lbuff1
Old Feb 17, 2012, 10:11 PM
s2000 is online now
Find More Posts by s2000
so. cal.
Joined Jan 2006
Dave, Zap a Dao a Goo is the bomb! Years ago when I was doing movie models with Larry Jolly, I learned that this stuff was the best for holding clear canopies on model Helicopters that were going to be blown up, we DID NOT want the canopy to blow off the fiberglass fuselage in one piece since we had high speed cameras close in on the model, we found the the Goo made the clear canopies shatter in a very scale manner, this stuff dries totally clear, it is far superior to any other product I have used. Dennis B.
s2000 is online now Find More Posts by s2000
Old Feb 18, 2012, 07:34 AM
Joined Mar 2009
All purpose workshop adhesive and sealant
JT, Len, Dennis,
Two votes for Zap-a-Dap-a-Goo. I think I'll try that.
What's more, I found half a tube of the stuff in my toolbox.
The tube says:
- All purpose workshop adhesive and sealant
- Bonds virtually everything
- Remains flexible
- Works where others won't
Thank you, gents.
// Dave
Old Feb 26, 2012, 12:52 PM
Joined Mar 2009
Canopy glue success
The Zap-a-Dap-Goo II worked great as canopy glue.
I think RC-56 Canopy Glue would have worked fine also - there was plenty of surface area.
The RC-56 Canopy Glue cleans up with water until it sets up.
The Zap-a-Dap-Goo II cleans up with Goo Gone after it's cured.
I wanted a tint that looks like the cap on the tint spray can. I might have overdone it.
We'll see if the pilot figure is visible out in the sunlight.
// Dave
Old Feb 26, 2012, 01:00 PM
Joined Mar 2009
This horizontal looks way too small to me
Remembering that I am a (fiberglass) scale plane newbie, the 3.6 meter DG-800 horizontal stabilizer looks way, way, way too small to me.
The vertical stabilizer looks as it should to me.
Did I get the wrong part? I'm fearful I won't have enough elevator authority.
I'm very tempted to build a larger horizontal - at least add a larger elevator?
Attached are photos of others or my horizontals so you can see what I'm used to.
Advice for the newbie, please.
// Dave
Old Feb 26, 2012, 01:29 PM
Thermaleer is offline
Find More Posts by Thermaleer
Florida
Joined Jul 2004
Looks about right Dave, but your canopy.....Beware of letting it sit in the sun! Ask me how I know! Great job with the zap goo!
Thermaleer is offline Find More Posts by Thermaleer
Old Feb 26, 2012, 02:20 PM
Joined Mar 2009
Thermaleer
Good tip. Thanks.
I'm very lucky it cleans up with Goo Gone, even after curing.
// Dave
Old Feb 26, 2012, 02:27 PM
rcsoar4fun is offline
Find More Posts by rcsoar4fun
Corpus Christi, Texas, United States
Joined May 2003
This is a common issue with the smaller scale stuff. The stabs are very small compared to r/c stuff. Normally it is an issue in slow flight and particularly off winch/highstart launches. Most scale stuff will do very unscale maneuvers if launched like the average TD bird.
rcsoar4fun is offline Find More Posts by rcsoar4fun
Old Feb 26, 2012, 06:51 PM
Lbuff1 is offline
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Dave,
The Stab is fine, also, you will only have VERY little control throw in he elevator. It never seems like enough sitting on the bench. In the air, its perfectly fine.
len
www.rcAerotowing.com
Old Feb 26, 2012, 08:35 PM
SZD16 is online now
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
What Len said......set the elevator for what the plans say and then set dual rates at 50% of that just in case you need less throw.
SZD16 is online now Find More Posts by SZD16
Old Feb 27, 2012, 05:06 AM
bie is offline
bie
Find More Posts by bie
bie
maidenflight-postponer
bie's Avatar
Germany
Hi,
donít worry, I can confirm: The stab definitely works as it should (at least it did in the last 15 years)Ö
Andy
bie is offline Find More Posts by bie
Old Feb 27, 2012, 12:10 PM
Sailhigh is offline
Find More Posts by Sailhigh
High Lift Coefficient
Sailhigh's Avatar
SF Bay Area, USA
Joined Feb 2003
Dave,
Plane looking good so far. Make sure you have some ventilation holes in the cockpit floor (if any), otherwise your dark canopy will warp under the hot sun. Stab size is fine and you'll find in modern scale planes you won't need much elevator movement for pitch authority.
Sean
Sailhigh is offline Find More Posts by Sailhigh
Old Feb 28, 2012, 09:18 PM
Joined Mar 2009
Tiny Dancer tail parts
rcsoar4fun, Len, SZD16, Andy, Sean,
Thank you Gents, for your reassurance. I'll go with my factory-supplied Tiny Dancer tail parts.
I'm not planning to winch launch this one. Aerotow and slope only.
With any luck maiden flight will be at Spring Cumberland Fly for Fun next month.
I got my wings done. Pair of Airtronics 94761s for ailerons, single 94322 for spoilers
Thank you.
// Dave
Sold DG 800 3.6m by Gerasis gottaflyrc Aircraft - Sailplanes (FS/W) 5 Feb 06, 2012 12:33 PM
Sold Gerasis DG 800/360 Scale 3.6m Local Pick Up SoCal tqpham Aircraft - Sailplanes (FS/W) 10 May 07, 2011 01:16 AM
Discussion OLD Gerasis DG-800 build (have glider, what now?) b7gwap Scale Sailplanes 31 Feb 11, 2010 04:54 PM
Discussion Gerasis DG-800 canopy slopemeno Scale Sailplanes 9 Dec 01, 2009 06:08 AM
Gerasis Dg800 Dg 800 orion1210 Scale Sailplanes 3 May 06, 2005 04:35 AM
