How it works
http://en.wikipedia.org/wiki/Inertial_guidance_system
Don't worry about which type of gyro and accelerometer the Guardian uses. The theory is what's important. Here's what that little postage stamp size board use to look like. Check out how many wires are connected to it. The photo is just the mechanical parts of the system. There are other boxes that have the computer and control system that are also contained on the Guardian board. Amazing. I worked on INS systems in the 70s and the INS box alone weighed about 100 lbs and cost $250,000 each from Litton Industries. ![]() http://en.wikipedia.org/wiki/File:LN...m_MVC-876X.JPG Steve |
If you hook up your Guardian to a PC and run the software, you'll find an AHI (Artificial Horizon Indicator) depicting the orientation of the guardian. Early adaptation of accelerometers were prone to errors when shaken, and example would be the SK-720 - A flybarless 3d controller Details of how the software algorithm handles all this is probably proprietary and confidential information. |
Floater,thx for the link but as a person highly interested in gyros, I Indeed care about the brand of chip. I"ll agree that most others won't need to know. Invensense makes it easier on the developer and thus to date, the majority of those boards that pick one of them become highly successful. The BeastX Microbeast was one of the first 3axis heli gyros to use 2 of the earlier ones and the results were very impressive. There are some other chips that are mems but not as developer friendly as the Invensense.
United States, CA, Santa Clara
Joined Mar 2011
The accelerometers are not like a compass that always points down. If a Guardian, or any such device, "woke up" while in a turn the only clues that it's accelerometers were not sensing a direction towards the center of the Earth would be a greater than expected G force and a sense of turning from the Gyros. Actual compasses detecting the magnetic field may be involved also but I think not as they would be more sensitive to motors than we are observing. In any case there must be a, probably complex, algorithm involved to combine the reading from different sensors to provide a consistent "down/up" reference either in the chip or in the firmware. I'm just glad it works so well. This lecture you showed us earlier discusses some of this complexity and was very interesting, thank you. Quote:
http://tutorial.cytron.com.my/2012/0...accelerometer/ Another example and a good easy to understand discussion on Gyro/Accelerometer fusion. http://arduino.cc/forum/index.php/topic,58048.0.html There is a good possibility that the function is already a part of the 6 dof chip. if it is the chip that is being used. http://www.invensense.com/mems/gyro/mpu6050.html The grand daddy of "Gyro/Accel 101" http://www.starlino.com/imu_guide.html I agree that Eagletree has done an awesome job on this Guardian. For $80 we can spend more time enjoying and flying our models than sitting in front of a laptop crunching code. |
Joined Jul 2009
Guardian Problem
I just test flew my PZ T-28 with my Guardian for the first time after everything checked out fine on the ground. Took off with 3 position mode switch in off & at about 2 mistakes high I switched on 2D; immediately I got very erratic behavior instead of stabilization; so I switched off & recovered level flight; then thinking because I reversed the Mode switch channel to put 2D on top, I switched to 3D & the A/C snapped into a spin! By the time I got the stab unit off, pulled the power & began recovering I was on the ground off the end of my grass runway in some heavy cut hay, resulting in some repairable damage to the nose area. But it was such a shock after everything I've read on this site & after everything seeming to be working as required in both modes while ground checking it - all servos & control surfaces moving right direction & only moderately. I have the pot gains at 50% with the master gain wire unplugged, so 40% default times my 50% set should be about 20% actual gain which seemed right for this A/C.
Is it possible that when switching between off to 2D to off to 3D to off that I may have inadvertently caused the unit to reset level flight & trim again over what I set on the ground? Also do you need to reset level flight & trim before each flight? I read the manual that this wasn't necessary, but I did this setting the day before I actually flew it. Anyway, most distressing & confusing as to what to do now. My confidence in the unit is not nearly as great as before, at least until I can figure out what went wrong. Needless to say the other fellows I was flying with weren't very impressed either. Jed |
You have a 15 second window right after the Guardian comes "On" to make changes to 2D level flight, and trims. |
Joined Mar 2011
Some things to check; Is it mounted flat and facing forward? It's easy to inadvertently mount it backwards. Are you sure the pots are set to apply correction in the same direction as the servos? Which way the pots are turned reverses servo direction which could cause the behavior you saw. Did you make any large trim adjustments after setting level, even in flight? Are you sure you have level set properly (at least close) on the ground? Try setting the plane on its wheels on a flat surface and setting level. Safest to work on this with prop removed or motor disabled. Turn 2D mode on, the surfaces should stay neutral. Don't touch the transmitter again. Now move the plane carefully on each axis individually and make sure Guardian is correcting each in the proper direction. EG: lift the tail and see if Guardian applies up elevator. Pick the plane up and wave it around to some "unusual" attitude. Now "fly" the plane by manually turning it in the direction each surface is deflected until that surface neutralizes. EG: If you are seeing left aileron, rotate the plane left until the aileron is neutral. Repeat for each axis. The plane should be back in the same level orientation it was when you started. |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
