This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Jul 23, 2012, 12:54 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Thanks for the input silverexpress, guess I need to buy a 3D plane
As for the screen shots I posted, do you see anything i can tweak?
BTW as stated earlier - 2D is flawless, will try to get some video next weekend.
Thanks again,
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Jul 23, 2012, 01:15 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Thanks again,
FCA
FCA,
I am new to using a Guardian as well. My plane is a delta (Superfly) and it's operating off a radio with no slider or proportional knob (DX6i). So, my gains are set with the pots only. With no rudder I only have roll and pitch to adjust. My pot settings are at 50% with no oscillations. In 2D mode and 10-15 mph crosswind the stabilization is incredible. I can literally lay the radio on the ground. 3D mode has yet to be explored. That said, looking at your gain settings they are much lower than mine.
Bill
Prof100 is offline Find More Posts by Prof100
Old Jul 23, 2012, 01:19 PM
FLAME747 is offline
Katy, TX
Joined Dec 2009
Thanks for your input Bill, btw I searched Youtube earlier and saw 2 videos of a superfly delta with ET Guardian installed, are those your video? if so she looks pretty solid
FCA
Old Jul 23, 2012, 01:41 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Thanks again,
FCA
Pickup a 3D plane and stick a Guardian in it. You'll be blown away on the fun factor it adds. The touchiness of non-stabilized exaggerated control surfaces go away. What you get is a pattern like flyer that can pitch, roll, and yaw on a dime.
Try a 3dhs, Precision Aerobatics, e-flite...etc... you'll be surprised how much the Guardian tames these wild beasts.
Anyhow, I found videos of people doing knifedges with the PZ T-28 on youtube, so there must be a setup recipe floating around these forums. Have you been able to do it without the Guardian? CG I know is very important on manuevers like this.
Silverexpress is offline Find More Posts by Silverexpress
Old Jul 23, 2012, 01:43 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
FCA
Yes, those are the first two flight videos of my Superfly with a Guardian. The stability in a crosswind was jaw dropping. I didn't explore 3D mode much because of the wind.
Old Jul 23, 2012, 01:55 PM
Stagger Wing is offline
Find More Posts by Stagger Wing
Joined Jul 2012
Originally Posted by Deadstick 8409 View Post
If you have to ask, you probably should not consider doing it. It may be a little tougher than he was alluding to also. It would certainly work on analog equipment, but not guaranteed (at all!) on a microprocessor controlled encoder.
I have quite a few flights on this with my tufflight bouncer. All I can say is WOW. I want one of these for each model I own now. Bravo Zulu to Eagletree. For learning hovers and what not, it is a great device. Slowly turn down the gain on a slider as you get more proficient. Next it is going in my Polaris for video work.
Thank you. I have already forgot it.
Stagger Wing is offline Find More Posts by Stagger Wing
Old Jul 23, 2012, 03:17 PM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Got one of these on the way to try out in a big 3D foamie... will be interesting to see how it works... will report back and post videos in a week or so.
cdee
cdee is offline Find More Posts by cdee
Old Jul 23, 2012, 05:25 PM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
fitted one of these in a p/z bf109,
must say very impressed with it..
a Q.. the pc 3d mode display both 3d settings are enabled.
do i disable one..
dazza44 is offline Find More Posts by dazza44
Old Jul 23, 2012, 06:06 PM
Your customer
Joined Dec 2009
do i disable one..
Try it with the Head Holding disabled. This is the component of the 3D mode that allows you to hold an orientation - which is not typical of warbirds. What you have left is 3D direct rate (systems response to stick input), and it'll primarily dampen out the wind.
Old Jul 23, 2012, 06:58 PM
gtlavin56 is offline
Find More Posts by gtlavin56
Joined Oct 2011
Hi Guys
after reeding all the information and your discissions about Guardian 2D/3D, I am quite sure that you can answer this simple question for me, because you know eagletree system in such detail or at least you can redierct my question to the right forum, as follows:
I need help, really, I being trying to set the RTH in my skywalker with the guardian system, however for some rason when a try to use the simulator to verify my settings there is a notice in the screen that says: "Tilt Model is full Backwards". Please let me know your commets I will appreciate a lot!!! Thanks
gtlavin56 is offline Find More Posts by gtlavin56
Old Jul 23, 2012, 08:03 PM
lesodell is offline
Find More Posts by lesodell
good till the first drop
lesodell's Avatar
michigan usa
Joined Jan 2005
Ok here is a good question when are we going to see a app for the guarding ? i can see a bluetooth plugin thats goes in the guarding and then the readout on my smartphone ok even better my iPad , o by next week would be even better
lesodell is offline Find More Posts by lesodell
Old Jul 23, 2012, 08:29 PM
yurstruly is offline
Find More Posts by yurstruly
Chicago, USA and Manila, Philippines
Joined May 2007
The only thing im concerned is your "roll rate"... it seems like in 11:00 o clock? while the rest is around 2:00 oclock . If my understanding is correct, that is not countering your roll rate if you plane bank right and the roll rate will do nothing to corrrect it to bank towards left to stabilze? Also, you might need to increase your pot setting or master knob/slider in all axis to see how it holds and move on 3D mode.. Your setting could be on the low side...
Back to roll rate, can you do a static test how the aileron turns at that current setting and let us know..
Ok guys I've been playing around with the Guardian installed in a PZ T-28, So far the 2D mode is flawless, did some additional tweaking yesterday and again in 2D mode the plane, landings are amazing
I did post before that I have the remote gain mapped to a slider, that slider position was left in the middle - it's my understanding, the unit is working off of the current pot settings - See pic of the 2D tab setting
now 3D mode is not performing as I had hoped it would, when I release the sticks it fails to hold it, i tried to do inverted and knife edge it only held for a brief moment
Can someone look at the attached screen shots of my Guarding setting and let me know if anything is "off" in the 3D tab
FCA
yurstruly is offline Find More Posts by yurstruly
Old Jul 24, 2012, 02:36 AM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
thanks for that ill turn hh off...
Old Jul 24, 2012, 11:48 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
First off that depends on which way the servo dirrection is. X amount of gain (correction) could be 11 O clock or 1 O clock . Most important thing is that corretion is indeed in the correct direction.
I have suggested using 10 O Clock or 2 O Clock (depending or servo direction) as a staring point.
Old Jul 24, 2012, 01:51 PM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
I do not yet have my unit but was reading through the manual and one item that was not clear to me was the bullet point about 2/3 the way down on page 3...
"Ensure your Transmitter Pitch/Roll throws are set for 100% if applicable."
Is this talking about the travel limits on the transmitter set up for the channels? In some cases in order to prevent binding or to get equal throws of a control surface you may not have the "ATV" or "Travel Adjust" set to 100%, does this matter, or is the statement above referring to something else?
Thanks in Advance
cdee
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
