This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Jul 21, 2012, 09:03 PM
choochoo22 is offline
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
Originally Posted by jedorme View Post
I'm concerned about accidentaly bumping the slider so think I will probably use the switch
Jed
That's a good concern and could happen with a slider or a switch and could also be left in the wrong position from some previous aircraft or taking it out of your car, forgetting to set the proper value. For that reason and another I suggest adjusting the upper limit on your gain channel to the maximum usable gain on the model. That way you don't have to worry about taking off with a wildly oscillating plane or creating one in flight by bumping the control. The following is a process to follow to determine the maximum usable gain, but this is a bit beyond where you are now. You need to get flying first and come back to this later.
Originally Posted by choochoo22 View Post
I think it would be helpful for new Guardian flyers to have a plan on how to establish good settings for the on-board pots. Here is my take on it, I'm sure those with more experience will comment.
If you have a knob or slider for master gain and are trying to tune the pots for your aircraft, here is a methodology that should work pretty universally:
  1. Setup your pots for max gain in the proper direction.
  2. Set your tx for 3D HH and the master gain to zero.
  3. Fly at "normal" speed, that you use most commonly with this plane.
  4. Always using small steps, increase the master gain until you can "feel" the Guardian start to have an effect.
  5. Increase the master gain slightly.
  6. Use a burst of full throttle and watch carefully for oscillation and be ready to back off.
  7. Note the axis on which the oscillation was observed and back off the throttle and back down the master gain slightly. If no oscillation, go back to step 5.
  8. Land without further change in the master gain.
  9. Note the position of the master gain, eg. 40% of knob rotation, back down the oscillating channel to this same value.
  10. Fly again and go back to step 5, repeat until there is no oscillation with the master gain at max.
At this point you can use the full range of your knob to tune the gain in flight knowing you won't encounter oscillation at any setting even if you accidentally bump the knob or takeoff without pre-setting it properly. With the knob at max you will get all the gain your plane can use. You could still encounter oscillation in a high speed dive and need to back down the master gain in such situations. If you want to confirm that you are getting all the gain you can use, increase each pot slightly and test for oscillation again.
One modification; If you fly with a wide speed envelope, you may want to follow the procedure for oscillation at low speed in step 6 instead of full throttle. This will yield higher gain values on the pots that may be more useful flying at low speeds, hovering, etc. but will require you to be vigilant and back the master gain down when flying at higher speeds to avoid oscillation.
choochoo22 is offline Find More Posts by choochoo22
Old Jul 21, 2012, 09:52 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
The gyro menu is useful after you've figured out the perfect gain for phase of your flight , and it's a bit more time consuming so take you time setting it up
As for the sliders I am comfortable using the sliders
I might map the mode function to the right slider
Had my heli set up with the left slider controling the helicommand and right slider controlling the gyro gain
Anyways have fun
More testing tomorrow
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Jul 22, 2012, 01:42 AM
jedorme is offline
Find More Posts by jedorme
Joined Jul 2009
ChooChoo2 & FCA -
Again many thanks for this very helpful advice & I really do accept the fact that flying with the Guardian is not a slam dunk proposition. So I will definitely only fly initially without any Master Gain inputs & just using the 50% gain set on the pots, which if I am correct in my understanding, with a default setting of 40% master gain, will really only give me about 20% real gain. I think that might be enough to start out with the T-28 since it is already kind of "uber" stable to begin with.
But I do have to confess, that at least for me, the interaction of the pot gains & the master gain, coupled with the variables of all the different set up options for the transmitters being used out there, is one of the more mystifying aspects of basic flying with the Guardian. And I'm not even going to think about or comment on all of the many advanced features that ET has made available in this little micro wonder.
I just cant wait to get my T-28 in the air with it, but unfortunately I won't be able to do so for the next week at least due to a social engagement taking me out of town during that time. But again, I really appreciate all of the valuable info & advice given on this forum. Cheers,
Jed
jedorme is offline Find More Posts by jedorme
Old Jul 22, 2012, 03:01 AM
Rick
Joined Mar 2011
To be honest, I don't think Eagle Tree thought this part through very well. It's really a nomenclature and description problem, not a functional problem but...
When someone says they have a Guardian installed in their new "Super Widget" and it's working great with 30% gain, I have no idea what that means. Is it:
  • The pots are set at 30%?
  • The master gain is at 30%?
  • Both are at 30%?
  • They have done some math and the pot gain times the master gain equals 30% overall?
  • Are they considering the master gain as 0-100% or 0-200%?
  • Is the gain wire disconnected, which applies 40% to the pot gain?
Depending on the answers to those questions, 30% can mean many very different gains. About all you can take from that is that you should probably start with a pretty low gain for the first time on yours.
Even if you have an identical Super Widget and you somehow knew how to interpret all of the above, you would still need to go through your own tuning because:
  • Even identical airframes are not identical.
  • Your CG may be different.
  • Your servos are probably different.
  • Your linkages are probably different.
  • Your transmitter may be sending a different pulse width even with the same settings.
  • Your style of flying is probably different.
People want to take a shortcut by asking someone else for their settings but in the end everyone needs to work out their own settings anyway.
Setup help is a different matter, however. This can be confusing and some advice getting things hooked up correctly can be a big help.
Old Jul 22, 2012, 03:28 AM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
  • Both are at 30%?
Good point there Chooch but when first using and setting up the Guardian the question about initial gain settings is to simply to get in the ballpark. My setup in my elevon only Superfly with a DX6i only has two position flap switch which I have configured to toggle between 2D and 3D. Master Gain is NOT connected on the limited capability DX6i because it has no proportional slider or knob. That said, I am thinking of plugging it into the gear switch so I can turn the Guardian off and on. I am flying mine with 50% gain on the pots. No master gain adjustment connected.
Prof100 is online now Find More Posts by Prof100
Old Jul 22, 2012, 07:41 AM
miksterr is offline
Find More Posts by miksterr
Melbourne, Australia.
Joined Jul 2006
I don't think so but you can set the travel limits on your two 2 pos switches to give you your choice of 2D-3D, or 2D-off, or 3D-off on the mode switch and any low-high gain values you want on the gain channel, including zero gain.
If you aren't bothered by opening up your TX I'm sure it could be modded to change the 2 pos switch to a 3 pos one. Would just need a 3 pos, on/off/on switch and some resistors.
Mike.
miksterr is offline Find More Posts by miksterr
Old Jul 22, 2012, 12:34 PM
Rick
Joined Mar 2011
John_T
One way Eagle Tree might make the gain less ambiguous (RE: http://www.rcgroups.com/forums/showt...2#post22230926) is to display the overall gain in use for each channel on the main page of the PC interface in real-time as the user makes changes to transmitter settings and Guardian pots. This would also be a useful setup tool something like a servo monitor on a transmitter.
This would require the receiver to be powered-on while the USB is connected, not sure if this is a problem but I haven't seen any warnings about it. In fact, it might be helpful to have the Guardian pass through the 5v from the USB to the rx so a motor battery is not required in the plane. This would be safer but there might be complications.
Old Jul 22, 2012, 08:03 PM
Stagger Wing is offline
Find More Posts by Stagger Wing
Joined Jul 2012
Mlke: why the resistors and where?
Stagger Wing is offline Find More Posts by Stagger Wing
Old Jul 22, 2012, 09:31 PM
Deadstick 8409 is offline
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
If you have to ask, you probably should not consider doing it. It may be a little tougher than he was alluding to also. It would certainly work on analog equipment, but not guaranteed (at all!) on a microprocessor controlled encoder.
I have quite a few flights on this with my tufflight bouncer. All I can say is WOW. I want one of these for each model I own now. Bravo Zulu to Eagletree. For learning hovers and what not, it is a great device. Slowly turn down the gain on a slider as you get more proficient. Next it is going in my Polaris for video work.
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Old Jul 22, 2012, 09:35 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
John_T
+1 I'd also like a digital display of the pot settings even if the receiver isn't connected. It would help setting the pots and remembering what the settings are. I'm sure we could look in the config file put on the screen would be cool.
Thanks in advance, Bill.
Steve
Floater73 is offline Find More Posts by Floater73
Old Jul 22, 2012, 11:29 PM
bobandris is offline
Find More Posts by bobandris
LSF 004 - AMA 5055
bobandris's Avatar
United States, CA, Saratoga
Joined Dec 2000
I'm just now installing my Guardian in my T-28. Thanks for these pot gain suggestions. Are you using the master gain control on your TX, & if so what range of adjustment of the pot gains? Are you using a Y cord for the aileron servos or separate TX channels? Is your Onboard Dual Aileron Mixing enabled or disabled? I'm having a problem getting the Guardian to control both ailerons in the same amount - one is getting more correction input than the other. Thanks.
Jed
Jed,
Had the same problem with the ailerons. My plane was initially setup with dual ailerons on two separate channels. The default for the Guardian is to do the aileron mixing for you. Therefore mine was being mixed by the transmitter and again by the Guardian. If yours is setup that way, just change no. 9 on page 11 of the manual to be option 1 (Off).
Bob
bobandris is offline Find More Posts by bobandris
Old Jul 23, 2012, 06:29 AM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
John_T
+1 on showing the gain values in the PC interface. Also add the remotely adjustable gain pots using the PC interface for less accessible Guardian installations.
Silverexpress is offline Find More Posts by Silverexpress
Old Jul 23, 2012, 10:10 AM
flynut67 is online now
Find More Posts by flynut67
United States, AZ, Sedona
Joined Feb 2009
I ordered mine, put it in my U CAN DO 60 electric and all I can say is WOW! One other guy in my club ordered at the same time. We both showed up on the same day for our maidens and he want at least 2 more. I just ordered 1 more. As for dual elevators, I ended up using a Y harness and moving one of the servo control horns to the other side so they work together! Thought about opening one up to reverse it but this was easier! Turned the gains all the way up on the unit and adjust them with a slide on my 9CAP. Seems to work perfect! Hope they can work a RTL for the data port! Lots of guys interested in that!! Three others in my club already looking to order after seeing mine work!! Way to go ET!!!
flynut67 is online now Find More Posts by flynut67
Old Jul 23, 2012, 11:48 AM
FLAME747 is offline
Katy, TX
Joined Dec 2009
Ok guys I've been playing around with the Guardian installed in a PZ T-28, So far the 2D mode is flawless, did some additional tweaking yesterday and again in 2D mode the plane, landings are amazing
I did post before that I have the remote gain mapped to a slider, that slider position was left in the middle - it's my understanding, the unit is working off of the current pot settings - See pic of the 2D tab setting
now 3D mode is not performing as I had hoped it would, when I release the sticks it fails to hold it, i tried to do inverted and knife edge it only held for a brief moment
Can someone look at the attached screen shots of my Guarding setting and let me know if anything is "off" in the 3D tab
FCA
Old Jul 23, 2012, 12:27 PM
Your customer
Joined Dec 2009
FCA
PZ T-28 is not a 3D plane. It does not have the over exaggerated control surfaces needed for knifedge or a symmetrical airfoil for the main wings. I wont say its impossible, just make sure you've got it setup to do it. Also, make sure you have enough throw for elevator and corect cg to do inverted.
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
