Eagle Tree has had a different Guardian that many use for FPV for a veryy long time and perhaps that is the one you have and if so you need to post in that thread. |
Joined Jul 2012
Hello Forum,
Pls help me with Guardian issue. I am from Vietnam where FPV is very new hobby. I have got an eagle tree system together with the Guardian. At first everything work without any problem but later after some testings, the elevator doesn't work when guardian is enable. Gradually the aileron is also died. I have tried to rerun servos analys wizad many times but nothing is better. When Guardian is disable, everything is back to work normally. Pls kindly share me your solutions. Thanks. Nhut |
Great White North
Joined Jun 2008
You are asking about a different guardian product. Please post your question here at the guardian Add on page Al |
United States, CA, Santa Clara
Joined Mar 2011
You don't need a 7 ch rx. Your transmitter doesn't know you don't have a 7 ch receiver and ch 7 still operates. If you mix the switch on ch 7 to your gear ch (5?), by playing with the mix ratios and subtrim you can get multiple gain values on the gear channel. Think of it as a bicycle with 2 sprockets in front and 2 or 3 sprockets in back. By changing both sprockets (switches) you can have 4 or 6 gear ratios (gains). Even just using the gear switch alone it doesn't have to be 0% or 100%, it can be any low and high gain value you want by adjusting the travel limits on the gear channel.
Guardian 2D/3D Gain
OK I finally hooked up Guardian to an 8 Ch. receiver bound to one of my Ace MicroPro800 Transmitters so that I could learn how the remote gain works.
Ace MP8K is a bit strange as it does not have EPA or Reverse per say but uses 1.10ms / 1.50ms / 1.90ms as normal ( full ,100%) servo range 1.50ms being centered /netural. With Guardians Pots turned full C.W. and Remote gain disconnected ( 40% default) the Guardian has to be turned up on its' edge(rotated) 90 degrees to get full servo defelction ( correction) in 3D mode. With Remote Gain connected and 1.10ms input there is no responce (corrections) from the Guardian. It is same as if it were set to off or not even connected at all. With remote gain set at 1.50 ms the Guardian provides max. servo deflections(corrections) when rotated 45 degrees or roughly twice as sensitive as the default ( no gain connected). From 1.50ms to 1.90 ms supplied pulse there is no change ,that is 1.50 ms will provide enogh gain to enable Guard to move servo full travel one direction when Guardiad is tilted to a 45 degree angle from level. Now the tricky part. If remote gain is greater than 1.50 ms Guradian does not seem to respond any faster even if you increase gain to 1.90 ms with guardian starting level however if gain is set at 150 ms then raised to 45 degree angle where full servo deflections is obtained and then yo start to lower Guardian to say a 22 degree angle and then increase the gain to 1.90 ms the Guardian will cause the servo to regain part of the correction it gave up during the lowering from 45 to 22 degrees. If anyone understands this I will really be surprised. Everyone really needs to do as I have done and use an extra receiver,battery and Guardian out of the aircraft so that there are no dangers of binds linkages/ control surfaces etc. and just play with it. I intend to leave this test setup connected for a while so I can perhaps answer questions as the come up. Charles |
Katy, TX
Joined Dec 2009
Charles from what you described, I would assume it because guardian response is greatest at the initial moment is senses roll or pitch
A very simple way to see how quickly the servos react and initial range of motion would be to have the plane level with normal gain, tilt or pitch see what the control surfaces do, Put plane back to level, increase gain then tilt and pitch again. Bet you will see a faster response and greater range of travel 1 of my units will be going up next weekend, let's see how the guardian performs in a solid 170mph fun jet FCA |
I agree with Flame, quite often, gyro response can't always be viewed statically. Many heli gyros I've used WON'T difflect in a way you expect them to even in heading hold mode. What I see almost always is when I wiggle the plane, the more gain, the more the surfaces move. Wiggle the plane in a consistant manor say 30degrees ore more movement then flip the switch to see if the speed of the control surface movement is more with a higher gain. I know this is not yeild something you can quantify to others but I expect it should be visible.
OK explain to me how so,meone wiggles a 20 pound aircraft 30 degess or so or simplie any larger than say 5 foot WS.for that matter.
I do not have any issues and never have. Please remember I was / am a beta tester and posted about excellent Guardian performance months ago. Since John Q has started receiving their's there have been post which complained of extremlty little or even no control surface movement with Guardian enabled . I believe those who are experiencing issues rather real or just do to lack of understanding wopuld like to have a repaeat means to varify if their unit is functiong correctly and to the extent of a know functioning unit. Charles |
Katy, TX
Joined Dec 2009
That's a little testy, everyones been following your post and appreciate all of your input on this unit
For those who are having issues I am pretty sure they will iron them out of they go over the manual and do a proper setup Some also like me did not have the previlage of having a test unit, I doubt you got it right the 1st day We did not just get up oneday and became experts My units will arrive shortly, I will do my best to provide other users will advise once I have it installed FCA |
I did find one combination of two position switches which would control the three Gaurdian Modes but problem was both Sw. had to be move in combinations and if one was in the wrong position results could be extremly unpleasent. I did not want to have to be sure of fliping two switches to the correct position under emergency situation. Charles |
Perhaps I should crawl back under my rock and leave this thread to those with more people's skills. Charles |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
