This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Jul 09, 2012, 03:43 PM
Ken Lilja is offline
Find More Posts by Ken Lilja
I'm slow but I'm expensive
Ken Lilja's Avatar
United States, GA, Snellville
Joined Nov 2003
I was thinking of the 8 pin connector on receiver connection harness. Servo extension leads might be a little expensive (unless I make them myself ) And maybe a little messy. But they will work. I'll have to see what I have around.
Ken
Originally Posted by everydayflyer View Post
They are standard servo connectors otherwise they would not plug into the receiver. You can use standard servo extensions which have three leads instead of the only one which is needed except for the Ail. one which provides power to the Guardian as well as the singnal. You could remove the extra leads to save a bit of weight but unless it is a very small / lightweight one the weight shoulld not be an issue.
Charles
Ken Lilja is offline Find More Posts by Ken Lilja
Old Jul 09, 2012, 04:24 PM
TxRider is offline
Find More Posts by TxRider
Keller, TX
Joined Aug 2010
Everydayflyer is right.
I have Guardian installed in a Zephyr so only needed the aileron plus three other channels (mode, gain, elevator). These three I just wired up using a single standard servo lead but with each of the three wires in the lead as a signal wire for the three channels. Worked like a charm!
TxRider is offline Find More Posts by TxRider
Old Jul 09, 2012, 06:15 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
So you guys have to make custom connectors in order for the guardian to work properly
I don't understand the need for these "special harness" you guys are referring to
FCA
On a side note, had anyone gotten a ship notification from Ready made RC
FLAME747 is offline Find More Posts by FLAME747
Old Jul 09, 2012, 08:05 PM
Ken Lilja's Avatar
Joined Nov 2003
No custom connectors required. The supplied harness plugs into the appropriate channels in the receiver with standard 3 pin servo leads (rudder, aileron, elevator, gain, mode and aux as appropriate to your plane) The other end is a single 8 pin plug that plugs into the Guardian. I just need a longer reach than the stock harness. I can use regular servo lead extensions between the harness and the receiver or could make up an extension between the harness and the Guardian. That would need to have the correct type of connector. I guess I will just splice in the extra length of wire to the stock harness.
Ken
FCA
Old Jul 09, 2012, 09:11 PM
jedorme is offline
Find More Posts by jedorme
Joined Jul 2009
Are you stating that you can not get the Gaurdian 2D/3Dto move the servos from netural (centered) to CW and CCW positions even with the POTS turned to their extremes?
With the pot gains at their max positions for my servos ( rud & elev reversed but ail normal), I get little or no movement from the rud & ail when in either 2D or 3D modes & I have set it up for level condition by toggling the Mod/Config switch on my TX & I move the model by hand from this level condition; I get some movement of the elev but less than I would expect to be able to restore the model to the level condition. I'm judging this to some extent by what I observed on the ET demo video on their web site, which I appreciate both involved more of a 3D type A/C, & also may have been made more exaggerated for demo purposes.
I just hooked up with friend with a PC & he is going to download the ET software so I will try next to set up my 2 stab units that way & then reinstall in the FunCub to see how they work. Thanks for the help & I'll also take your hint into the mix of things.
Jed
jedorme is offline Find More Posts by jedorme
Old Jul 09, 2012, 09:14 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Well the OP with the extension question stated that his receiver was far behing the CG thus he wanted extensions so Guardian can go on the CG as suggested.
Those who read my post way back on Guardian in my Min Gremlin may remember that I mounted it way behind the CG ( aprox. 5") and it worked fine there.
I pay $2 each for 3"-12" servo extension, very good quality ones at that.
Can n ot find bookmark for my normal supplier but these are fairly inexpensive and good quality
http://www.3dhobbyshop.com/Servo-Extensions_c_292.html
Charles
Old Jul 09, 2012, 09:21 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
As eluded to, don't be over critical about gyro being mounted on the CG. If the airplane were to vibrate and the center of rotation of the vibration were to be at the CG, then maybe it would be more significant but it does not really happen like that. Helicopters never mount on the CG and they do just fine. I typically mount my gyros where it is convenient. A more critical or significant issue is making sure it's on plane with the horizontal stab and straight with all axis. I've seen people say it is best on the CG but I've never seen that it makes any significant difference. Mount the gyro 3" from CG and if the plane were to rotate 90 degrees, so does the gyro.
Melnic is offline Find More Posts by Melnic
Old Jul 09, 2012, 09:49 PM
alros_100 is online now
Find More Posts by alros_100
Great White North
Joined Jun 2008
I agree with you - although it is recommended, my guardian was never on the c of g of any of the planes I tested it on. So as long as its close it's good enough
Al
alros_100 is online now Find More Posts by alros_100
Old Jul 10, 2012, 12:01 AM
Scott216 is offline
Find More Posts by Scott216
United States, NJ, Mountain Lakes
Joined Apr 2010
Jed
I have a similar issue, but with the rudder and elevator. The ailerons move quite a bit, but I can barely see the rudder and elevator move when I move the plane around by hand.
Scott216 is offline Find More Posts by Scott216
Old Jul 10, 2012, 12:03 AM
Scott216 is offline
Joined Apr 2010
Reset Trims?
Should I reset the trims settings on my DX7 transmitter to neutral? The Guardian instructions seemed to state this, but I am a little confused about it.
Old Jul 10, 2012, 12:35 AM
otrcman is offline
Find More Posts by otrcman
Joined Mar 2009
Yes, it's true that the rate gyros don't care about being on the CG. Angular rate is angular rate, whether you measure it at the CG or in the nose, tail, or a wing tip.
I think the concern is for the accelerometers. When you rotate about the CG the accelerometers feel no change. But if you roll an airplane with a normal force accelerometer at the wing tip, of instance, the accelerometer will feel the rolling acceleration and deceleration and think the whole airplane is increasing or decreasing G's.
Dick
otrcman is offline Find More Posts by otrcman
Old Jul 10, 2012, 01:40 AM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Here's an interesting experiment - If you have a UMX Beast 3D or any of the smaller AS3X planes, rotate it +-30 deg (the more deg the better) in the pitch axis back and forth and at the CG. Take note of how reactive the elevator is in response. Now take the plane by the nose and hold it at arms length, and this time pivot your arm at the shoulder in the pitch axis of the plane. Make sure you hold the plane rigid - don't pivot your elbows, wrists, or fingers but just your shoulder.
You'll notice that the elevator will become less responsive and in fact may not even move. If the AS3X had gain adjustment you would be able to increase the gain to compensate. What's happening is simple - the AS3X see's less of a rotational motion about it's gyro(s), and instead experiences more of an arc.
If you have a big plane and you mount it far down the tail, you'll run the risk of running out of gain.
You can probably perform the same experiment on the Guardian before it is mounted.
Silverexpress is offline Find More Posts by Silverexpress
Old Jul 10, 2012, 01:54 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
This is a common misconception. If you can manage to wave your stiff outstretched arm through the same +-30 degree arc as you accomplish with just your hand and at the same speed you will get the same deflection response from a gyro system. Gyros respond to angular acceleration and the angular acceleration is the same everywhere on a rigid body.
EDIT: Of course, if you are using accelerometers, it's a different story. But the AS3X used in your example doesn't have any.
erkq is online now Find More Posts by erkq
Old Jul 10, 2012, 02:39 AM
Your customer
Joined Dec 2009
Can you provide us some numbers. That would be cool and it would help me better understand.
Here's some stuff I found for reference:
http://www.siliconsensing.com/technology
http://sensorwiki.org/doku.php/sensors/gyroscope
https://sites.google.com/site/mkokto...nd-calibration
http://www.youtube.com/watch?feature...&v=dn9O7adrO_M
Shock and Vibration Rejection of MEMS Gyroscopes (1 min 38 sec)
How It Works -The Vibrating Gyro- (Science And Stuff) (2 min 1 sec)
Introduction to MEMS "Micro-Electro-Mechanical System" (8 min 59 sec)
Sensor Fusion on Android Devices: A Revolution in Motion Processing (46 min 27 sec) Note: Start at 8:40. He begins to talk about Sensors - Accelerometers, Gyros, Compass...etc..., and then how you can use them together to obtain better motion detection. This is a real good presentation. In regards to software, "Sensor Fusion" is one key element that seperates the good from the bad in these stabilization devices we are using.
coriolis effect (2-11) (2 min 12 sec) The gyro sensors used in our hobby utilize the Coriolis effect to detect motion about an axis. If I've understood it correctly and as applied to a mems gyro, the center of the merry-go-around represents the center of the gyro sensor, and the ball represents the vibrating "proof-mass". I'll ask around a bit to confirm this though. So, what happens when the rotating merry-go-around is made to travel about an arc instead of rotating about its axis?
If you have an android based smartphone, you can download programs such as, "Sensor Meter" (free), "Sensor Insider" (not free, but works much better), and Android Sensor Box (free and an excellent app that tells you what sensors you have). Some of these allow you to graph in real time the response of the sensors in your smartphone (gyro's, accelerometers, magnometer, gps...etc...). Doing so will give you a glimpse of how these sensors work.
http://androidforums.com/android-lou...ids-gyros.html
Here's a neat video, but is his explanation enough to satisfy our attempt to understand?
RC Gyro Positioning Demonstration (5 min 51 sec)
Old Jul 10, 2012, 10:39 AM
Great White North
Joined Jun 2008
Once you have flown and trimmed the plane with guardian installed and turned off, land and then perform the guardian reset trim gesture . You don't reset trims in your radio
Al
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 01:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 10:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 10:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 05:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 01:19 AM
