Honolulu
Joined Jul 2003
Hi Gadget 99
You can have it upside down, more importantly the printed plane needs to point fwd. However you do need to be able to get to the axis adjustment pots on the top during the initial flights. I mistakenly installed my first one with the plane pointing backwards and it still worked. However won't do that again lol now that I know. |
USA, CA, San Diego
Joined Apr 2007
With similar systems (e.g. FY-20A) you should permanently turn off turn coordination when using gyro stabilizer. The purpose of turn coordination is to compensate for adverse yaw when the plane rolls. But the stabilizer will do that for you. If you have coordination mixes turned on in your TX, then the gyro is told to over-compensate for the yaw. Frankly I'm not sure I could tell the difference, but I have adjusted my TX so that when I'm in the GYRO-ON flight mode, mixes are turned off. |
USA, CA, San Diego
Joined Apr 2007
So to answer a later question, you can install these devices with any 180 degree rotations, then adjust the pots. You might even be able to install with 90 degree rotation, then switch some of the outputs to different servos. (E.g. the output labeled "elevator" would go to the ailerons.) I'll have to try it when I get one. a
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
