Katy, TX
Joined Dec 2009
While we are all waiting on the slow boat from China to arrive, we depend on the few beta testers for answers and entertainment
With that being said, any new videos Has anyone tested how well the unit handles slow speed, just prior to stalling. Thanks, FCA. |
I have been using guardian for quite a while, which is the origin of guardian 2d/3d. I can tell you that 2d/3d will not keep your plane from stalling, only speed and power can do that, but I know that it will work like hell to keep it level. I expect nothing but an absolutely amazing piece of equipment, with the guardian 2d/3d -Mike |
Honolulu
Joined Jul 2003
F-4D Skyray direct mode 3d test
Hi Everyone
Got to do more testing on Sunday. With the F-4D sorry Flame747 the person who usually videos for me was not flying today. My other pilots that were flying with me tried to take video and had a very hard time so I don't have any usable video. 1. Test 3D direct mode: First I had to find out my microsecond limits for my controls. I did this using a pulse reader connected to my Aile, Ele, and Rud. Why I did this: When I was playing around with direct rate in 3D I noticed that the Guardian would push the Elevons to larger than normal throws using full stick deflections. I used the servo limit feature to set the endpoints that the Guardian could move the control surfaces to it worked very well. 2. I set the 3D direct mode to .25 Hz I left the Roll and Yaw at 1 Hz. The help file explained that at full stick deflection the Guardian would for example try to roll the plane 360 degrees in 1 second. On the ground this seemed to give me about the throws I wanted. 3. Flying. The plane performed normally on takeoff. When I tried to do some turns, and rolls what a difference, Now I had full aileron authority again, and it did not feel like you were fighting a Gyro any more. The plane was rock solid. 4. In conclusion, the Guardian performed as advertised in Direct Rate 3D. Rock solid flight, and the ability to really carve up the sky while feeling like you were in total control without any slow response, or muted responses. It felt like I was flying the plane without stabilization, but with the rock solid stability, and all the maneuverability that I wanted on tap. |
Honolulu
Joined Jul 2003
F-4D Skyray 2D recover test
Hello Everyone
My secondary testing on Sunday was aimed at using 2D mode as a "panic button" to recover from unusual attitudes. After testing 3D direct rate, I flew in manual to get into a unusual attitude then moved in to 2D mode via a switch to perform a hands off recovery. (wanted to video see above post sorry no video) I was able to perform hands off recoveries from these attitudes. Inverted, inverted dive, inverted dive rolled 40 deg, vertical fast, vertical slow, dive rolled 30 deg. All recovered correctly and right away with minimum altitude loss. The ability for the guardian to recover hands of is very impressive. |
Honolulu
Joined Jul 2003
Hi Flame747
The only slow speed testing I did with the F-4D was in landing approach. And some High Alpha flight, I can tell you that the Skyray does not like to fly slow, however the Guardian did a pretty good job keeping it in the air. Again not very definitive tests as it just not the plane to fly slow. Normally I enter 3D mode and turn up the gain to 100% after gear is down. The stabilization is good all the way to touchdown. If I fly my F-4D without stabilization during short final it is very very easy to get into a PIO and go bunny hopping down the runway. With stabilization on landing is a comparative breeze. |
Joined Mar 2009
Hi Aero65.
Thank you for the most informative reports on your Guardian testing. I was especially interested to hear how the 3D Direct mode would perform. Seems to me that for an everyday sport or scale flyer, 3D Direct is the mode that would give the most natural feel in flying and yet smooth out most unwanted motions of the plane. I experimented with three rage gyros in an ordinary sport plane and experienced that same "carve up the sky" sensation that you describe. Very satisfying sense of absolute control. Until I tried a Split S. It was a real heart stopper due to the reduced pitch authority. I thought for sure I'd hit the ground before completing the pullout. Again, your report on control authority for 3D Direct is most encouraging. One question about the 2D mode that I keep wondering: If you are flying straight and level ("cruise flight") in 2D, and then close the throttle, will the Guardian try to maintain constant pitch attitude ? If so, it seems to me that the plane would slow down and ultimately develop a very high angle of attack while trying to maintain the constant pitch attitude. Ultimately, this could lead to a stall. Have you experimented with this ? Dick |
Between my tx and crashed aircraft
Joined Mar 2006
* landings: losing altitude, but wings level and nose a bit up * the 3D elevator manuever: again, losing altitude, but wings level and nose a bit up |
Joined Mar 2009
I demonstrate that sort of "stabilized stall" to my full scale flying students on a regular basis. But there are several caveats for doing it. First, we don't do it below 2000 feet AGL. Second, on most airplanes you dare not use aileron inputs to keep the airplane wings level. You have to use rudder. Depending on the airplane, and the CG when you perform the stall, it is very likely that you will have a violent roll reversal if you attempt to use ailerons alone. With a stability augmentation system such as the Guardian, the ailerons will respond to any roll motion and could exacerbate what modelers call "tip stall". This is not a criticism of the Guardian, it's just an attempt to understand how the whole system plays out in conjunction with the basic aerodynamics of the airframe. I agree that most 3D models still retain roll control well into the stall, but that's because the propellor flow straightens the relative wind such that the inboard wing is not really stalled in spite of the apparent high nose-up attitude. In addition, the ailerons are usually full span and immersed in propellor flow. Some years ago I was one of the pilot test subjects on a Piper Twin Commanche which had been modified such that the left seat controls ran thorough a computer, which then drove the flight controls. The computer could be programmed to respond in several different modes. One of the modes was called "attitude command", which is somewhat like Guardian 2D/3D in the 2D mode. In the roll axis, it made precision tasks such as instrument approaches very easy. In pitch, attitude command was a delight within a small range of power settings, such as tracking a glide slope on an ILS approach. But it proved quite dangerous with gross power reductions because it did not permit the natural stability of the airplane to lower its nose to maintain flying speed. This feature negated our overall intent to make the airplane safe for an inexperienced or inattentive pilot. Dick |
Rico. |
Katy, TX
Joined Dec 2009
Ok let's go back to basics
From the limited info that's available, the unit needs to be mounted on a flat surface, from experience when I used my FY 20 even though the unit was placed on a flat surface in the model, once the unit was activated it tend to pitch down, and roll to the right Solution - 1 either use trim to keep the model level, it worker but took away from the models flight performance Or 2 shim the unit to achieve level flight without using excessive trim On the FMA Co-Pilot II, one can compensate for any unwanted roll, and pitch by using flight angles, so that the control surface stays level at neutral In short, what options are available to trim out any unwanted pitch and roll tendencies with the guardian Thanks FCA Aero, Al. Keep up the good work |
Great White North
Joined Jun 2008
Folks,
Even when the thermophile based stabilizers were the only game in town (copilot etc), it was always stated that a stabilizer will not prevent a stall. You have to use your throttle. Now you could set level at a silght pitch down, so that with zero throttle, the plane continues to decend stablized, but that may not be what you want when you fly with throttle. Experienced folks can use the guardian leveling in slow speed manuevers, but if you go outside the aerodynamic envelope of your model, no stabilizer can prevent a stall. But if you have enough altitude and power the throttle, the guardian can help restabilize the plane. Basically keep your speed up in 2d mode above stall speed. In 3d mode do whatever you are capable of flying!! This is a great, fun product ! Al |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
