Kingston Ontario Canada
Joined May 2006
I put my first Guardian into my Mojo 25 (slab, 3D), using my DX7. On this, I use the Gear switch to select 2D or 3D. I use the AUX2 switch plus its trim slider to be my On/Off/variable Gain switch. Having set up the system and then made some minor adjustments to the pots, I really have no need to touch the variable Gain slider; however, I leave it enabled just so that I can play around with it if/when I get bored My "servo travel" on this Gain (AUX2 channel is set to something like -150% with the switch pulled back toward me. This means that, regardless of where I might have the Trim set at any time, flipping the switch back will completely eliminate the Guardian from the control loop. The major change I made via the computer is to set 3D as the default Mode. I played around with 2D and, yes, it has its uses but, depending upon your personal requirements, you may never need to switch to/from one Mode. You can always set some parameters for 2D to enable more advanced maneouvering, should you choose that mode. Now, this setup is almost as simple as one can get. I happen to have used an AR700 Rx, but this is being moved into another plane and a 6-channel Rx will be installed. I will always be in 3D Mode, whenever I enable the Guardian via the AUX2 switch. My plan in using Guardians (I have at least one more, and probably will add to the collection over time) is to use the AR7000 to do the initial test flying and then substitute a simpler unit, keeping the AR7000 for the next plane, etc. This is just one (cheap) man's thinking! |
-- Tom |
BT is fine, just please don't make me jailbreak to use it. I won't. -- Tom |
Ignore post. I finally figured it out myself.
I just bought a DX8 and figured out how to set ON/OFF-2D to the gear switch, but can't figure out how to set the GAIN to the twist knob-Aux3. The Aux1 socket is empty on the AR6115e receiver. Should the gain plug go in Aux1 socket on the receiver, and if so, how do I get the Aux3 twist knob to operate that gain function. The Mode plug is in the gear socket and that works fine for on/off or 2D. Perfect. Now if one of you guys who understands the DX8 could please tell me how to get that twist knob to adjust the gain I will be home free. Older than dirt and still learning, sorta ! Tom |
View Post |
| JDougherty, Erie | |
A moderator felt this post violated the following rule: Personal Attack.
It is temporarily hidden while JDougherty, Erie
edits it.
Show it to me anyway.
Kelowna , BC
Joined Nov 2008
I too asked that question and that was put on the wanted list they have. Would be nice if the Aux could be used either as dual ailerons or dual elevators...user software selectable.. They recommended using a JR matchbox or equivalent Futaba matchbox or servo reverser.
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
