Joined Oct 2011
Snowflake,
fortunately I bought 2 Guardians - did some tests with the second unit. Same results on the workbench (no pc hookup yet). HOWEVER i used a new model in my DX8 set it up one by one - and the servo glitching movement on the ailerons came from my sub trim values on ailerons. I have read nowhere that the guardian is having problems with subtrim values from the TX? I only experience this on the ailerons, rudder and elevator subtrims have no such effect? I would have thought that the initail set level / trims procedure (first 15sec.) would tell the guardian that subtrim values to be considered as "neutral stick inputs"... Michael |
United States, ME, Wells
Joined May 2008
Subtrim and Guardian
Michael,
Others have reported problems with sub-trim, but I use sub-trims if I cannot mechanically find a 90o servo arm position. I have never had a problem. I think you are right that resetting should take into account sub-trim. After all, on most transmitter monitor screens, the sub-trim is shown as a value away from zero and appears to be indistinguishable from regular trim. Excessive sub-trim might be a problem with the Guardian over-driving a servo, but that is also true for regular trim. It does seem odd that two units exhibit similar behavior. Michael Quote:
I use a Turnigy 9X. Can't afford fancy gear. I dont have any jitter problems at all. You can see from previous pics I use HK analogue servos (15148) and HXT 900. Nothing fancy at all. This leads me to think some TXs or RXs may be the problem? Trims on the TX are always neutral as I adjust the mechanical linkages to zero.
Guardian 2D/3D artificial horizon roll in 3D mode
I have a Guardian 2D/3D sytem installed in an E-Flite T34 Mentor with Hitec Aurora 9 TX and a Hitec Optima 7 RX. I have the “Mode” mapped to channel 6 with Gyro 1 and switch “E” setting 0 at 100%, switch setting 1 at 0% and switch setting 2 at 100%. This allows me toggle the switch towards me in a off-2D-3D configuration. I have the “Gain” of the Guardian mapped to channel 7 and Aux1 and Left Slider (not to Gyro2 because it won’t work –trust me it won’t) with the setting at 100% and end point set at 140%.
Everything on the airplane’s control surfaces are functioning with the Guardian as expected. My problem occurs only when plugged into the software via the USB port. Everything works perfectly except when I toggle my TX to 3D mode. When I flip the switch on my TX the computer screen rolls the artificial horizon about 7% to the left. I have reset the level flight countless times along with the servo recalibration. Battery is fully charged, telemetry verifies Voltage. I have saved the profile and reloaded or reset the factory defaults many times. I have shut down the program and rebooted the computer. I have checked the USB cord many times. I even disconnected the wiring harness from the Guardian and it still occurs. Am I missing something here? Any help is appreciated! |
I thought of that and tried holding the airplane in a cockeyed position and then waggled the controls and then set it down. Same problem remained. I unchecked the software boxes in the 3D menu and hit apply and tried it again with the problem remaining. I then did countless combinations with the airplane at different angles and waggling the controls but to no avail. I have noticed that it does the same thing in 2D occasionally and very briefly. I think it is in the Guardian. I am going to order a second unit and see if it duplicates the problem. I will then load the profile from the first Guardian into the new unit to see if it duplicates. I will take precautions to save the second units factory default in its own profile first.
I am getting a "feeling" that it is a bug in this single unit. |
If so, what is your reaction/experience? For $19 plus shipping, it is tempting . . . |
Between my tx and crashed aircraft
Joined Mar 2006
http://www.rcgroups.com/forums/showt...1035605&pp=100 Two things that I can see: 1. If I want gyros on all 3 axes, I will need 3 of these: $57 2. It looks a bit large for smallish foamies (what I fly) |
I haven't been happy with Detrum products. ESC rated at 30 amps that shuts down after 1 minute at 24 amps. Cheap servos that strip gears. I replaced them with JR. I won't go near Detrum again. Better off with the Orange 3 axis Gyro at $17. I have 2 and they work very well and are tiny. They don't give you options like the EagleTree though.
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
