This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Feb 07, 2013, 04:21 PM
Snowflake6515 is online now
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
How To Use?
I purchased my seventh, this morning. I now put one in every new plane if I will have to maiden it. I also have one in some challenging (for me) models such as fast EDFs.
What are you specifically interested in doing with a Guardian? E.g., what plane, what is your skill level? Access to experienced test pilots? Etc.
There is a wealth of information in the contributors to this forum so I would be very surprised if you cannot get help.
I've set up two other modelers' planes that flew with the Guardian on first flight, so, as another poster said, most of us are over-analyzing this device. I apologize to the poster for not looking up his name/handle before responding, but he posted a Guardian 101 guide that is so close to what I do that it seems tailor made for immediate success.
Once working, you can always fine-tune it, but not needed to fly and enjoy the benefits of stabilization; especially on windy days.
Michael
Originally Posted by goldsworthy View Post
I own 2 Guardians and have yet to understand how to use them.
Snowflake6515 is online now Find More Posts by Snowflake6515
Old Feb 07, 2013, 08:50 PM
bushpilot05 is offline
Find More Posts by bushpilot05
United States, NJ, Flemington
Joined Feb 2013
I had guardian set up with a dx5 & AR600. it was working but cont. surfaces only moved very small amounts,I didn't think it looked like enough.Just got a dx7 & AR8000 rec. Could not get system to work with new transmitter. Is it ok to bind rec. with guardian connected? I attemted to set up switches and lost control of ail. rudd. ele. Took guardian out and everything works fine. Downloaded software but when pluged in unit with usb nothing happ. Led does not lite.
bushpilot05 is offline Find More Posts by bushpilot05
Old Feb 07, 2013, 11:44 PM
Tomf35 is offline
Find More Posts by Tomf35
Joined Jun 2011
Anybody know, if there will be guardian(in future) with ppm connection or Spektrum satellite receiver port?
So, less wire need to connect.
Tomf35 is offline Find More Posts by Tomf35
Old Feb 08, 2013, 06:53 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I have followed this thread since it started and don't recall any plans or requests for what you described. That said, in a broader sense, I am sure the notion of reducing the overall footprint of the device and wiring is always a goal of the product's continual improvement.
Prof100 is offline Find More Posts by Prof100
Old Feb 08, 2013, 07:13 AM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
How about a firmware update that allows the use of an Ebay serial 4 pin bluetooth module (JY-MCU), and an accompanying Android setup app. This would help greatly for those who install Guardians in scale airframes or in general hard to reach areas (with a USB cable). The board itself can be purchased for under $15 USD. Here's and example of the specs:
Bluetooth protocal : Bluetooth Specification v2.0+EDR
Frequency : 2.4GHz ISM band
Modulation : GFSK(Gaussian Frequency Shift Keying)
Emission power : <=4dBm, Class 2
Sensitivity : <=-84dBm at 0.1% BER
Speed : Asynchronous: 2.1Mbps(Max) / 160 kbps, Synchronous: 1Mbps/1Mbps
Security : Authentication and encryption
Profiles : Bluetooth serial port
CSR chip : Bluetooth v2.0
Wave band : 2.4GHz-2.8GHz, ISM Band
Protocol : Bluetooth V2.0
Power Class : (+6dbm)
Reception sensitivity: -85dBm
Voltage : 3.3 (2.6V-6.0V)
Current : Paring - 35mA, Connected - 8mA
Temperature : -40~ +105 Degrees Celsius
User defined Baud rate : 4800, 9600, 19200, 38400, 57600, 115200, 230400,460800,921600 ,1382400.
Dimension : 26.9mm*13mm*2.2mm
Silverexpress is offline Find More Posts by Silverexpress
Old Feb 08, 2013, 07:55 AM
JayY is offline
Find More Posts by JayY
Foam Temple Pilot
JayY's Avatar
United States, NC, Raleigh
Joined Sep 2012
Deleted
JayY is offline Find More Posts by JayY
Old Feb 08, 2013, 12:07 PM
CurrentDude is online now
Find More Posts by CurrentDude
Flying is Electrifying
United Kingdom, England, Macclesfield
Joined Jun 2011
Ypeeeeee.... My Radian Pro has come today. Putting it together was a breeze - done it in <30 min. I'm really surprised at the finish quality and overall workpersionship (need to be pc )
My PZ Super Cub is nearly 10 years old, going strong and use it regularly even now to check the air conditions - gusty, lifty, direction of wind, visibility etc. I can foresee Radian Pro wud easily outlive SuperCub ...
I'm now wondering where to place the Guardian. Any light JayY or anyone else care to throw???
Cheers
CurrentDude is online now Find More Posts by CurrentDude
Old Feb 08, 2013, 03:05 PM
Michael
Joined May 2008
USB and PC
What OS are you running on your PC? I am running Windoz 7 (Pro on PC laptop and Home on MacBook Air under Parallels.)
There are directions on the site that worked perfectly, for me, on both computing systems.
I did make sure that I did NOT have the PC software running until AFTER I had plugged in the USB cable and allowed the driver to be installed. Windoz 7 does seem to install the correct driver.
Feel free to PM me with your environment and I can try and walk you through it.
Michael
Originally Posted by JayY View Post
The control surfaces only move small amounts when you move the TX sticks or when you leave the TX sticks alone and move the model? If the latter, small amounts are what you want, large movements by the Guardian will likely lead to oscillations. If you need more or less control surface movement, this is under control of the combination of the master gain input, if you've hooked it up to your receiver, and the three gain screws on the top of the Guardian, one each for yaw, roll, and pitch.
The receiver should bind just fine as long as the ESC is connected to the throttle output of the receiver and the bind plug is inserted. It shouldn't matter what else you have connected to the receiver, whether servos, the Guardian, or nothing.
Not sure what to tell you about the USB connection, that doesn't sound right at all. When I connected my Guardian to my PC the first time using a micro USB cable it took about a minute for Windows 7 to find and install the device driver. After I installed and started the Eagle Tree Data Recorder program it found and connected to the Guardian immediately.
Old Feb 08, 2013, 05:00 PM
Grantham Kid is online now
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
Originally Posted by CurrentDude View Post
Ypeeeeee.... My Radian Pro has come today. Putting it together was a breeze - done it in <30 min. I'm reallty surprised at the finish quality and overall workpersionship (need to be pc )
I'm now wondering where to place the Guardian. Any light JayY or anone else care to throw???
Cheers
I only have a standard Radian, not the Pro so I have no idea how much space you have in it. Even with mine I had to dig a bit of foam out of the receiver bay to fit all the gear in. This is where I mounted the V2 Gyro and I moved the receiver up forward of the battery. Hope this helps.
Grantham Kid is online now Find More Posts by Grantham Kid
Old Feb 08, 2013, 05:15 PM
Joined Feb 2013
USB & pc
Using windows vista, i'm afraid I may have a bad guardian. I applied a ticket to eagle tree support to see what they have to say. I see no reason why soft ware wont run. The fact that I have no LED on guardian scares me ! Thanx for your input.
Old Feb 08, 2013, 05:17 PM
JayY is offline
Foam Temple Pilot
JayY's Avatar
Joined Sep 2012
Deleted
Old Feb 08, 2013, 08:10 PM
Corona44 is offline
Find More Posts by Corona44
Australia, NSW, Windsor
Joined Apr 2006
Grantham Kid, A slight off topic question but I'm curious why you need a servo reverser in your Radium glider? It's only got two servo's and just about every TX go do channel reverse either via switches or via a software menu?
Corona44 is offline Find More Posts by Corona44
Old Feb 08, 2013, 08:43 PM
Joined Oct 2012
Because, when I fitted the gyro, the servo went in reverse. When I swapped the reverse switch in the gyro it worked opposite to what it should have. This was the only solution as the radio I use for the glider is basic and not reversible. Clever guy to notice that. :-) It is a 36mhz Radio that has superb range and has had little use. Ideal for a basic glider. I was taking video with the Radian the other day and could barely even see it in the distance. Didn't dare take my eyes off it.
Old Feb 08, 2013, 08:46 PM
Joined Oct 2012
The relocated receiver is mounted with regular Velcro. There is plenty of room for the stock 1300 mAh battery with the receiver there, a larger battery might not fit.
Jay, I use 1800 and 2200 batteries in mine. They fit fine.
Latest blog entry: A bit about me
Old Feb 08, 2013, 08:55 PM
Joined Oct 2012
I use Vista and it works perfectly. There was mention some of the micro B usb cables don't have a power supply and won't work. Can you try another cable?
This may account for no LED.
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
