Feb 06, 2013, 09:37 PM
United States, PA, Boalsburg
Joined Mar 2012
Originally Posted by flying-llama
In 2D mode, the rudder is in rate mode, so when the plane is not rotating in yaw, the rudder does not move. While the plane is rotating in yaw (yaw left or right), you should see the rudder move a little to counter the yaw. You may need to turn up the yaw gain and/or rotate the plane quickly on the yaw axis to see the rudder visibly move much.
My memory of the manual description: in 3D heading hold mode (your probable 3D mode), the AHI is relative to the last attitude (orientation, etc.) that the 3D heading hold remembers and is trying to return to. In 2D mode, the AHI is relative to "level" as determined by your last reset of "level". So 3D heading hold and 2D put the AHI relative to 2 different reference orientiations.
Do not remember about when the Guardian is off.
Thanks, that helps.
